![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello
While running PovRay 3.7/39 (but I got the same pb with earlier releases)
through an INI script on long (several hundreds) sequences of images, after some
time, PovRay stop, and I get a message like the subject of this post. The path
and name of the supposedly missing file, displayed in the message window, are
absolutely correct. If I restart the script, restricted to the end of the
sequence, things go on for a few steps, then block again. And so on. If I
restart PovRay, things go on for a large number of steps.
Is there some kind of pile, with an adjustable length ?
Windows Vista Home Premium, Intel Q6600, 4Go memory, plenty of disk space.
Many thanks !
43oasis
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 10/21/2010 05:53 AM, 43oasis wrote:
> Hello
> Many thanks !
> 43oasis
Has your process ever worked? In your opening sentence you seem to be
saying that you've had the same problem with previous releases? Does
your process work on version 3.6 ... if so maybe this news group is
where you need to be. If you're trying to debug a new process, perhaps
one of the other news groups would be a better fit. Does your scene
render fine on it's own? Maybe your INI file needs some work. A tiny bit
more detail would be helpful.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hello
> Many thanks !
> 43oasis
I got the same error in an animation using the command line options. The
"missing" file was the source scene file been rendered. The error appens
near the end of the parsing process.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Hello
>> Many thanks !
>> 43oasis
Here, "after some time" means "after a number of frames". "number of
steps" stand for "number of frames".
As I said in my previous post.
Most of the time, the scene get parsed, THEN the error hit me.
The suposedly missing file is always the scene file currently been rendered.
Starting the animation from an ini file have no impact as the error can
appen with +kff100 on the command line.
It NEVER appens on the first frame but ALWAYS after some frames have
been successfully rendered, usualy less than 20 here.
It don't depend on the architecture of the machine used. (Windows XP
pro, AMD Athlon 1400MHz, 1Gb RAM, NO SSE support)
It appens using the ordinary and the SSE version.
In my case, the same animation was completed on version 3.6, a few years
ago... Revisiting some old scenes. So, it's not due to a new scene.
Also, in my case, it appened with previous versions of 3.7.
I almost never do animation of 100 frames or more.
It never appened to me with animations of less than 100 frames, but it
may be pure chance.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> Hello
>>> releases)
>>> after some
>>> The path
>>> window, are
>>> the
>>> If I
>>> space.
>>> Many thanks !
>>> 43oasis
> rendered.
> may be pure chance.
> Alain
ha-ha ... are there two of you now? I saw and unfamiliar user name and
thought I was directing traffic. You're and old hand at this and
certainly would have done your homework before asking for help, wasn't
trying to suggest otherwise ... just for the heck of it I had at the
docs and there didn't seem to be any mention of a 'limit' so I'm not
sure what to think ... acts like a pointer without a home (now that's a
wild guess)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm getting a similar message when trying to render scenes with lots of
objects. ~ 600000 objects.
This is happening about every second render.
Possible Parse Error: Cannot find file 'tenement01p1.pov', even after
trying to append file type extension.
Parse Error: Cannot open input file.
Render failed
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
