POV-Ray : Newsgroups : povray.beta-test : installer POV-Ray 3.7 beta 38 issues Server Time
23 Apr 2026 08:35:46 EDT (-0400)
  installer POV-Ray 3.7 beta 38 issues (Message 11 to 19 of 19)
Subject: Re: installer POV-Ray 3.7 beta 38 issues
Date: 3 Aug 2010 02:59:51
Message: <4c57be67@news.povray.org>
On 3/08/2010 15:36, stevenvh wrote:
> I'm not going to fight over this, but beta 37 let me *choose* where to install
> the program. And I didn't install it in Program files.
You probably ran it elevated the first time (this does provide the choice).
Or something else changed on your system. Our revision control system
confirms that the only change in the setup project between 37 and 38 were
the text strings related to the beta version.
If elevation or system change doesn't explain the issue, then something is
strange is going on.
-- Chris
Date: 3 Aug 2010 12:10:00
Message: <web.4c583ea387ca3686c0721a1d0@news.povray.org>
What's elevation? (Yes, I should know, but I only went to school 'til I was 25!)
Date: 3 Aug 2010 12:54:00
Message: <4c5849a8$1@news.povray.org>
It refers to elevated privileges. You picked "run as administrator" to run
it, or you logged in as the administrator, or some such.
Basically, you gave it permission to write to Program Files before you
started it.
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 3 Aug 2010 13:21:21
Message: <4c585011@news.povray.org>
> started it.
  I didn't know there was such a feature in Windows XP (which is what the
OP is using, as far as I can see).
Date: 3 Aug 2010 14:04:37
Message: <4c585a35$1@news.povray.org>
There is. Most people don't know about it because by default the accounts
most people use are administrator accounts. So chances are the OP was
already running it elevated. (I think XP makes it harder to get to, also, so
it's less obvious there's a way to run things with someone else's privilege.)
In any case, that's what "elevated" means in Chris's post, even if the
distinction isn't applicable to the problem being experienced. :-)
Date: 3 Aug 2010 14:30:03
Message: <4c58602b@news.povray.org>
  I installed beta 38 on a WinXP system using an account which as admin
privileges, and it did install it in the application data folder, so at
least I can confirm that part.
Date: 4 Aug 2010 15:17:37
Message: <4c59bcd1@news.povray.org>
>> started it.
When running windows XP, you have administrator provilege by default.
But, yes, you can "run as..." with XP: Just right click some executable
and sellect that option.
Date: 5 Aug 2010 22:27:55
Message: <4c5b732b$1@news.povray.org>
On 7/31/2010 4:46 AM, stevenvh wrote:
> 2. The uninstaller (for both beta 37 and 38) deletes the settings from the "My
> Documents" folder. Isn't the whole idea of placing them there to retain them
> when a new version is installed?
What do you mean by "settings"? Do you mean stuff like INI files and
sample scenes?
http://isometricland.com
Date: 5 Aug 2010 22:39:57
Message: <4c5b75fd$1@news.povray.org>
> sample scenes?
For clarification, other types of settings are things you can't (or
normally shouldn't) modify yourself, such as the last INI file used to
create a rendering, or the last directory in which you opened/saved a
file, or the list of 10 most recently edited files...
