POV-Ray : Newsgroups : povray.beta-test : Windows beta 36, re-render insert menu bmp Server Time
30 Jun 2024 13:31:58 EDT (-0400)
  Windows beta 36, re-render insert menu bmp (Message 1 to 6 of 6)
Subject: Windows beta 36, re-render insert menu bmp
Date: 20 Mar 2010 10:55:00
Message: <web.4ba4e0e43c19084d50054230@news.povray.org>
When I try to re-render the insert menu bitmaps, there is an error with the
Shapes.pov file.
line 474: Parse Error: Unexpected additional '.' in floating-point number
line 474 is:
  <2.6, 0>, <3.6.9>, <4, 1.1>, <3.4, 2>, <3, 1>, <2, 1>
The second vector has two decimal points
I tried to register with the bug tracker, 12hrs and still no comformation email.
The user name StephenS is now used, not sure what I did wrong. I got the message
at the bottom about checking your email.
Stephen S
Subject: Re: Windows beta 36, re-render insert menu bmp
Date: 20 Mar 2010 15:21:27
Message: <4ba52037$1@news.povray.org>
> Shapes.pov file.
> line 474 is:
>    <2.6, 0>,<3.6.9>,<4, 1.1>,<3.4, 2>,<3, 1>,<2, 1>
> Stephen S
Version 3.6 assumed that <3.6.9> was <3.6, 0.9> and that trick has been
used to shave a character or two here and there.
Versio 3.7 don't assume that any longer and no longer accept that
construction. You need to change <3.6.9> to <3.6,.9>
In fact, it's not a bug but a correction of an inconstency.
Date: 20 Mar 2010 16:21:53
Message: <4ba52e61$1@news.povray.org>
The problem occurs in the Shapes.pov which is distributed with
POV-Ray so I'd call that a bug (in the pov file, of course).
Date: 21 Mar 2010 08:24:38
Message: <4ba61006$1@news.povray.org>
According to FlySpray (the POV-Ray bugtracker) you registered
successfully, so you should be able to log in by now. I also sent an
email to the address you provided in your account, to check whether
there's a typo or other problem with it, but it didn't bounce, so I have
no idea what went wrong (unless you didn't receive that email of mine
either, in which case there would indeed be something wrong with your
email account).
Date: 21 Mar 2010 10:50:00
Message: <web.4ba631e192b7a99b46320e180@news.povray.org>
> successfully, ...
After the account timed out, not completing the registration, I re-submited and
it worked (today local time).
Stephen S
Date: 21 Mar 2010 19:12:48
Message: <4ba6a7f0$1@news.povray.org>
Ah, okay... so maybe just a typo in the email address, or a glitch in
the matrix, or some such...
