POV-Ray : Newsgroups : povray.beta-test : radiosity changes in 35a Server Time
28 Mar 2026 03:30:42 EDT (-0400)
  radiosity changes in 35a (Message 1 to 5 of 5)
Subject: radiosity changes in 35a
Date: 20 Feb 2010 23:45:01
Message: <web.4b80b93246cfe53b6a1983ea0@news.povray.org>
It was mentioned in another thread that beta 3.7 treats radiosity differently.
How has it changed, or where can I find information on that? Of the greatest
importance to me, is how radiant intensity calculated for radiosity is
influenced by diffuse and ambient settings (both global and object).
Subject: Re: radiosity changes in 35a
Date: 21 Feb 2010 03:25:58
Message: <4b80ee16$1@news.povray.org>
Your best source of information are the release notes. They come with every
beta and are available on the download website.
	Thorsten
Date: 21 Feb 2010 13:23:27
Message: <4b817a1f$1@news.povray.org>
Mostly, all object must have ambient set to zero unless they are to
actualy emit light. This have not changed since radiosity was introduced.
Diffuse determine how an object will affect it's surrounding depending
on the illumination it receives. No major changes from previous versions
in the basic principles.
The main differences is in HOW the sampling is actualy done and the
multi-threaded capability allowing you to benefit from multicore CPUs
and multiple CPUs.
Also, some radiosity settings work a little diferently in the beta.
/Most/ radiosity should render the same as with version 3.6.
For all radiosity scenes, whatever the version used, you should have:
#default{finish{ambient 0}} early in your scene. Best place: before any
#include and #declare of texture and material.
Seting ambient_lights 0 or some very small value is NOT something to do,
as it will screw things whenever you have some ambient light source.
The purpose of that setting is to tint the ambient component of the finish.
Then, check any include and alter them so that they don't set any
ambient unless the finish obviously should emit light, as the Luminous
finish.
Date: 24 Feb 2010 00:45:05
Message: <web.4b84bc72d4787a256a1983ea0@news.povray.org>
> and multiple CPUs.
> finish.
> Alain
I've implemented that setting. I now use:
#default{finish{ambient 0 diffuse 1}
It's a good idea, but I run into trouble with skies. Since radiosity (by my
experiment) uses both ambient and diffuse light, I get into a juggling act with
trying to illuminate both the camera and the scene evenly. It's hard to balance
the direct light from the sky to make it look natural, and have the right
illumination level in the shadows. I use light groups to colour balance as well,
so things can get complicated.
I believe this setting would be over-ridden by libraries, which isn't too great.
Of course, it won't affect textures defined in your sources.
The weird thing for me now is that radiosity doesn't seem to respect (or
understand) light groups. I know this is a curious complaint, and even way ahead
of my own needs, but it raises interesting questions in my mind...
Such as, should the radiosity for an object be calculated using only the light
sources in its light group?
Currently, it seems to me that this is not the case.
Date: 24 Feb 2010 16:42:07
Message: <4b859d2f$1@news.povray.org>
>> and multiple CPUs.
>> finish.
>> Alain
Any finish that set ambient to any valus always override the default.
That's by design. Otherwise, there would be no way to have any texture
other than the default.
Several include libraries where made for versions 1, 2 and early 3
before radiosity's introduction. Several textures used unrealistic
ambient setings to "make them look good". metals.inc and golds.inc are
main offenders in that domain and use some insane ambient values for all
defined textures.
Some textures from stone.inc and texture.inc also have high ambient
finishes.
Radiosity sampling don't bother with actual light_source. If an object
is illuminated, it have an effect on the radiosity samples.
So, any object, not part of a light_group, near an object in a
light_group WILL receive some light indirect from that object in exactly
the same way it would if tere was NO light_group at all.
Same thing for any object IN a light_group near any object outside it's
own light_group. Those will be affected by the indirect light from any
nearby object.
If, for any reason, you don't want the objects from the light_group to
affect the radiosity sampling, you can add "no_radiosity". Keep in mind
that this will also disable those object radiosity effect on other
objects from the light_group.
That flag is valid ONLY with the latest and future betas.
It act just like no_reflection, no_shadow and no_image.
no_radiosity make the affected object invisible to radiosity rays.
