POV-Ray : Newsgroups : povray.beta-test : Advanced diffuse_back Beta34 example scene Server Time
26 Oct 2025 21:24:44 EDT (-0400)
  Advanced diffuse_back Beta34 example scene (Message 1 to 9 of 9)
Subject: Advanced diffuse_back Beta34 example scene
Date: 23 Aug 2009 16:05:00
Message: <web.4a91a0706c7a541b390a3800@news.povray.org>
I just installed beta 34 and started by trying the new translucency example, but
it runs so slow, so, is every effect necessary to see that isolated feature or
what can I rip off from the file?
Subject: Re: Advanced diffuse_back Beta34 example scene
Date: 23 Aug 2009 18:45:47
Message: <4a91c69b$1@news.povray.org>
Disabling photons should speed it up. You can also try reducing the
radiosity quality settings.
Date: 24 Aug 2009 10:50:01
Message: <web.4a92a80da8690497b9b7d49a0@news.povray.org>
Thanks, I just hadn't well read your syntax tip so now that I have I tried a
minimal scene. It works fine and renders fast. I have one question:
For realistic results is the sum of the front and back diffuse value + specular+
ambient supposed to stay below one, or just the two diffuse values can go up to
one besides the rest of the ordinary values?
Date: 24 Aug 2009 13:12:54
Message: <4a92ca16@news.povray.org>
If you disable the photons, you'll see that it's MUCH faster. Only
looking at the radiosity pretrace, it's around 10 times faster without
photons than with.
Date: 24 Aug 2009 13:19:11
Message: <4a92cb8f$1@news.povray.org>
The front plus back values sum should be less or equal than one. Also,
as before, the total diffuse plus the ambient should add to one or less.
BUT, there is nothing preventing you from having diffuse 1,1 if you want to.
The specular/phong hilights can give a total larger than one when
combined with the oter parameters.
Date: 24 Aug 2009 17:41:01
Message: <4a9308ed$1@news.povray.org>
> to.
I /think/ you're wrong, theoretically:
- Light reflected in a rather directed fashion is unavailable for
diffuse reflection, and therefore the diffuse term(s) [1] should be
reduced accordingly when using specular or phong highlights.
- Ambient, on the other hand, is used not to model what happens with
incoming light, but how much incoming light there is in the first place,
by specifying an "input" term to add to whatever comes from regular
light sources. The idea is to model light scattered diffusely from other
objects onto this one, and should therefore be proportional(!) to
other(!) nearby objects' diffuse term. (Unless ambient is used to model
glowing objects of course.)
[1] As for backside vs. frontside diffuse term, it should be noted that
light making it though to the other side of the object is unavailable
for diffuse reflection on this side.
Date: 24 Aug 2009 22:40:01
Message: <web.4a934e31a86904972205c79a0@news.povray.org>
Does that mean that all the rest should add up to one and the back diffuse can
still go anywhere between 0 and 1 again? (sorry to ask again)
I know any values are allowed, I'm just asking for realistic limits
Date: 25 Aug 2009 02:21:59
Message: <4a938307$1@news.povray.org>
No, sorry, that's a misunderstanding; what I meant to point out was that
to get realistic results, when you increase back-side diffuse value (=
more light gets through to the other side), you should decrease the
front-side diffuse value accordingly (= less light stays on /this/ side).
Thus, you should make sure that:
   diffuse(front) + diffuse(back) + specular + phong  <=  1.0
Date: 25 Aug 2009 04:20:00
Message: <web.4a939daea86904972205c79a0@news.povray.org>
Thanks. This way seemed more logical from the start but that's perfectly clear
now.
