POV-Ray : Newsgroups : povray.beta-test : windows beta 32: an access violation error? Server Time
26 Apr 2026 01:44:38 EDT (-0400)
  windows beta 32: an access violation error? (Message 1 to 10 of 11)
Subject: windows beta 32: an access violation error?
Date: 5 Apr 2009 13:40:00
Message: <web.49d8eca11e1b8c8fddfb8aa70@news.povray.org>
I have tried to change the "subsurface.pov" file in POV-Ray and I tried to save.
....A window alert:
   * An access violation exception was generated at address 0x10008455 *
I have Windows XP SP3, POV-Ray beta 32, 32 bit no-SSE2 (pvengine.exe)
Carlo
Subject: Re: windows beta 32: an access violation error?
Date: 5 Apr 2009 13:55:00
Message: <web.49d8efe3710555cf68105bc50@news.povray.org>
Did you perhaps try to save the file while it was being parsed?
Date: 5 Apr 2009 14:00:00
Message: <web.49d8f12d710555cfddfb8aa70@news.povray.org>
After rendering finished.
Closed and reopened POV-Ray, several times.
I try uninstalling and reinstalling?
Carlo
Date: 5 Apr 2009 14:50:00
Message: <web.49d8fca8710555cffa5a96850@news.povray.org>
Problem solved manually.
Array.inc and subsurface.pov are in: property > attributes > "read only" mode.
Carlo
Date: 5 Apr 2009 15:14:05
Message: <49d902fd@news.povray.org>
  Still an access violation exception is a bug, regardless of the reason
why it happened...
Date: 6 Apr 2009 08:25:28
Message: <49d9f4b8@news.povray.org>
> ....A window alert:
Strange ... I get "cannot overwrite read-only file" in both Vista and XP (I
have code in the editor that explicitly catches this issue: or so it is
supposed to do).
Can anyone else replicate this?
-- Chris
Date: 6 Apr 2009 08:49:00
Message: <5hujt45pcc1glkaqd12d74sjstha89epdn@4ax.com>
On Mon, 06 Apr 2009 22:25:20 +1000, Chris Cason
<del### [at] deletethistoopovrayorg> wrote:
>> ....A window alert:
>supposed to do).
Not in Vista.
Regards
Date: 6 Apr 2009 08:50:01
Message: <web.49d9f9a5710555cf2983f9e20@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> > ....A window alert:
> supposed to do).
When running POV from the Visual Studio IDE, I keep getting access violations
when attempting to write to a file currently being parsed, or write protected,
like:
Unhandled exception at 0x03258455 in pvengine32d.exe: 0xC0000005: Access
violation reading location 0x00000000.
So far I didn't bother about them, as I just considered them some effect of
working in the IDE.
These asserts seem to happen deep in the bowels of Windows, somewhere during the
execution of handle_main_command(), but the exact location seems to vary. Right
now, I have it jam in the "NotifyModifiedChange" case - obviously because "s"
is pointing to 0x00000001.
However, it seems that the assert is not necessarily related to the write
attempt as such: When I open a write-protected file, then modify it, and then -
without saving - just switch focus to the IDE, I get a crash as well (in this
case in EditPassOnMessage()).
To me, this look suspiciously like a pointer already going wild much earlier,
when loading the write-protected file in the first place.
Date: 6 Apr 2009 16:15:00
Message: <web.49da6275710555cf33f5eb8b0@news.povray.org>
> ....A window alert:
> Carlo
The summary of my situation:
1) I have a pov file in read only mode, I open it with the beta 32,
   I try to save it:
   ...and I am forced to close.
2) Same result with the beta 31.
3) With POV-Ray 3.6.1.c i have a big problem:
   * AppName: pvengine.exe AppVer:3.6.1.3 ModName:cmedit32.dll
     ModVer:3.6.1.3 Offset:0000ae20                            *
4) With MegaPOv 1.2.1:
   * EAccessViolation:EAccessViolation *
   ...then to remedy at the problem I need only press the Button *OK*.
My system: XP SP3, POV-Ray beta 32, 32 bit, SSE
....I have these problems. Only me?
(I feel like a fish out of water...) :-)
Carlo
Date: 8 Apr 2009 21:39:14
Message: <49dd51c2$1@news.povray.org>
"Carlo C." <nomail@nomail> wrote in message
news:web.49da6275710555cf33f5eb8b0@news.povray.org...
>> to save.
>> ....A window alert:
>> Carlo
>   I try to save it:
Dunno, in Vista I get the proper "Can't Overwrite Read-Only file messages"
In 3.6 and in 3.7 beta 32.
To set/clear the read-only attribute just select the file from windows,
right click properties, and use the check-boxes in the general tab.
I'm perty sure it's the same in XP.
