POV-Ray : Newsgroups : povray.beta-test : So I managed to recreate the segfault... Server Time
15 Jan 2026 22:30:07 EST (-0500)
  So I managed to recreate the segfault... (Message 1 to 2 of 2)
Subject: So I managed to recreate the segfault...
Date: 26 Jan 2009 18:55:01
Message: <web.497e48b7f49e5fc3122a8da90@news.povray.org>
At last, POV has segfaulted in balcony.pov again! This time with coredump
enabled.
Let's see what gdb has to say:
    Core was generated by `povray -D -O~reference-output-exp.png render.ini`
    Program terminated with signal 11, Segmentation fault.
Uh-huh... so far nothing new... okay, tell me, wise gdb, *where* and *why* did
it segfault? Let's see:
    #0  00x00000000005b0c83 in ?? ()
Duh. Why do I get the feeling that this is *not* where the error actually
originated...?
Well, how about a stack trace then?
    (gdb) bt
    #0  0x000000000005b0c83 in ?? ()
    Cannot access memory at address 0x430030d8
Great. That would have been too easy, wouldn't it?
Blood-stained excrements of a male bovine.
Chris, or someone else with access to the source code - can someone please check
whether I might have made any stupid blunder in the implementation of the "trace
ticket" mechanism? It's currently the hottest candidate for causing (or
triggering) the trouble.
Anyone with expertise about whether this could actually be the symptom of a
stack overflow?
Subject: Re: So I managed to recreate the segfault...
Date: 26 Jan 2009 19:14:31
Message: <497e51e7@news.povray.org>
clipka <nomail@nomail> wrote:
>     (gdb) bt
  Compiler optimizations tend to cause these things... (or a million of
other things as well)
