POV-Ray : Newsgroups : povray.beta-test : Problem with "no_image" and transparency? Server Time
7 Apr 2026 06:30:24 EDT (-0400)
  Problem with "no_image" and transparency? (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Problem with "no_image" and transparency?
Date: 25 Sep 2007 04:15:00
Message: <web.46f8c270aff96f2fcb86afba0@news.povray.org>
It does not happen in 3.6.
Transparent or semi-transparent parts let the background color of the scene
show through, as it should be.
Date: 25 Sep 2007 05:10:00
Message: <web.46f8d032aff96f2fcb86afba0@news.povray.org>
I just went through the POV-Ray help and found this in the section about
"no_image".
"When no_image is used, the object will not be seen by the camera, either
directly or through transparent/refractive objects. However, it will still
cast shadows, and show up in reflections (unless no_reflection and/or
no_shadow is used also)."
There you go. The object is not supposed to be seen through
Date: 25 Sep 2007 06:55:34
Message: <46f8e926@news.povray.org>
  Then it's probably a bug in 3.7.
Date: 25 Sep 2007 19:17:43
Message: <46f99717@news.povray.org>
> "no_image".
Please post a minimal sample scene for us to work with.
thanks,
-- Chris
Date: 26 Sep 2007 09:17:46
Message: <46fa5bfa$1@news.povray.org>
Chris Cason nous apporta ses lumieres en ce 2007/09/25 19:17:
>> "no_image".
> thanks,
> -- Chris
As minimal as you can:
plane{z, 15 pigment{checker}finish{ambient 1} no_image}
sphere{<0,0,3>,1 pigment{rgbt 1}}
It should be all black but you see the checker pigment through the sphere.
Documentation; The worst part of programming.
Date: 26 Sep 2007 11:41:42
Message: <46fa7db6@news.povray.org>
Le 26.09.2007 15:17, Alain nous fit lire :
does it mean we need no_transmission and no_refraction also ?
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 26 Sep 2007 14:56:50
Message: <46faab72$1@news.povray.org>
Le Forgeron nous apporta ses lumieres en ce 2007/09/26 11:41:
No. Just make no_image work coherently between versions, and according to the
documentations.
An object with no_image is normaly invisible, but still cast shadows and show in
reflections.
An object with no_reflection is visible, cast shadow, but don't show in reflections.
An object with no_shadow is visible normaly and in reflections but don't cast
any shadow.
WARNING: The consumption of alcohol is a major factor in dancing like a retard.
Date: 29 Sep 2007 16:55:05
Message: <46febba9@news.povray.org>
> to the documentations.
Why not? We could have no_image work coherently between versions and new
no_transmission and no_refraction keywords too ;-)
Date: 29 Sep 2007 21:39:05
Message: <46fefe39@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2007/09/29 16:57:
You could add those, yes, but you don't need to.
no_transmition would work relative to transparent objects that don't have an
ior. You don't see the object through a transparent object, but will see it
through one with an ior.
no_refraction would work for those that do have an ior. You see that through a
transparent object but not if that object have any ior different than 1.
Idolism: Let's bronze this shit.
Date: 11 May 2008 08:35:35
Message: <4826e817$1@news.povray.org>
This is fixed in beta 26 (better late than never ;)
-- Chris
