![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Having checked the revision.txt file I see that quadrics.cpp has comments
concerning these QCone_Y shapes, which are being used in the
scenes\advanced\wineglass.pov file. Unfortunately, I haven't looked at those
comments so I am just going to give an example scene file by taking only the
relevant parts.
In short, the merge is where the trouble shows itself. I thought it might be
have been the clipping or the previous CSG, but this final merge is where it
all breaks down. Hopefully that will help you find the problem.
/* BEGIN TEST SCENE */
/* problem with wineglass.pov file rendered in 3.7.0.beta.5a.icl8.win32 */
#include "shapes.inc"
#declare Plain=texture {pigment {rgb 1}}
#declare Rim =
torus {0.975, 0.025
clipped_by { plane { -y, 0.0 } }
scale <15.0, 10.0, 15.0>
translate 24.0*y
texture {Plain}
#declare Top = intersection {
plane { y, 1.0 }
object { QCone_Y }
object { QCone_Y scale <0.97, 1.0, 0.97> inverse }
clipped_by { plane { y, 0.0 inverse } }
translate 14.0*y
texture {Plain}
#declare Stem =
cylinder { y*3.25, y*14, 1
texture {Plain}
#declare Base = object {
//sphere {0,1}
//cone{0,0,-y,1}
QCone_Y // this shape is causing CSG merge trouble
clipped_by {
plane { y, 0.0 }
plane { y, -1.0 inverse }
translate 1.0*y
scale <12.0, 3.25, 12.0>
texture {Plain}
// CSG union is okay, so try it instead of the
// merge, which causes everything above +1*y to disappear
merge {
object {Rim}
object {Top}
object {Stem}
object {Base}
scale <1.0, 1.50, 1.0>
light_source {
<10,10,-100>,1
location <0,60,-60>
look_at <0,20,0>
/* END TEST SCENE */
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> //sphere {0,1}
> //cone{0,0,-y,1}
> clipped_by {
> plane { y, 0.0 }
> translate 1.0*y
> texture {Plain}
Things get stranger...
If you replace the clipped_by section with:
clipped_by {
plane { y, -1.0 }
....you end up with an empty ring partway along the shape in addition to the
previously-mentioned disappearing act above +1*y. (Compare with the same
scene rendered in 3.61a...)
As far as the comments, I can't seem to find quadrics.cpp anywhere...
Bent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Okay, I've reduced the scene greatly:
//Start of scene
camera {location -5*z}
background{color rgb 1}
light_source {<-10, 10, -10> color rgb 1}
merge{
quadric {<1, -1, 1>, <0, 0, 0>, <0, 0, 0>, 0 clipped_by{plane{y,-1}}}
sphere{0,1 scale <1,3,1>}
pigment {color rgb .5}}
//End of scene
See if this helps any.
Bent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Curiouser and curiouser...
The difference function has a problem too:
//Start of scene
camera {location <0,4,-5> look_at 0}
difference{
sphere{0,2}
//End of scene
(I changed things around a little...)
Also, try adding an inverse to the quadric - you get the same thing as if
you were to replace the difference with the merge again...
Bent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For that matter, replacing the quadric with a poly doesn't change a thing:
poly {2,<1,0,0,0,-1,0,0,1,0,0> clipped_by{plane{y,-1}}}
Bent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
