POV-Ray : Newsgroups : povray.beta-test : trivial question on topic Server Time
12 Nov 2025 02:55:58 EST (-0500)
  trivial question on topic (Message 1 to 10 of 11)
Subject: trivial question on topic
Date: 9 Nov 2001 07:39:14
Message: <h6jnutscqu7hgr77vpt22rd26mj94di0d4@4ax.com>
Are all entries form povray.bugreports verified with 3.5?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: trivial question on topic
Date: 9 Nov 2001 09:41:38
Message: <3BEBEB4C.CA854309@pacbell.net>
Most items from that group were fixed early on in Mega-Pov and those
that weren't were fixed in 3.5. There are a small number of bugs
reported from that group that were never fixed however. Such as this
bug reported by me and verified by Ron Parker -
Poly Object Bug
  camera { location <0,0,-10> look_at 0 angle 25 }
  light_source { <0,1,-100> color rgb 1 }
  #declare Heart =
  poly { 6,<
  8.0,0,0,0,12,0,0,12,0,-12,0,0,0,0,0,0,0,0,0,0,6,0,0,12,0,-12,0,0,0,0,6,
 -0.1,-12,0,6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,3,0,-3,0,0,
  0.0,0,3,-1,-6,0,3,0,0,0,0,0,0,1,0,-3,0,3,0,-1>
  // sturm }
  object { Heart rotate <-90,90,0> pigment { red 1 } }
Personally I think Ron has conveniently forgotten about this one
because it is either impossible to fix or too difficult to fix :)
Ken Tyler
Date: 9 Nov 2001 09:50:05
Message: <16rnutgipvj3ejtrhcidtjlauig34hoi1a@4ax.com>
So, should I spend the time and go trough povray.bugreports and check all
entries ?
ABX
Date: 9 Nov 2001 09:56:46
Message: <3bebeeae@news.povray.org>
: So, should I spend the time and go trough povray.bugreports and check all
: entries ?
  Would it make any harm?
Date: 9 Nov 2001 10:02:54
Message: <2rrnutkdb0ppbdk7su1vp6qouvmj5dq2oj@4ax.com>
I don't know rules of team - perhaps there is somebody who did it (perhaps
recently) and necessary not fixed entries are on the current bugfix list.
ABX
Date: 9 Nov 2001 10:06:09
Message: <3BEBF10A.DC1B545F@pacbell.net>
> entries ?
During alpha testing I went through and double checked most of the
bug reports in that group. I started from the oldest and worked
towards the newest. I did not finish going through all of them. If
you want to, try going through the newest 1/3 of the bug reports
and verify if they have been fixed of not. The rest have been
checked and have been fixed or reported or both.
Ken Tyler
Date: 9 Nov 2001 10:12:47
Message: <ugsnutcc1ptv56bugvr35tcfbmg6hqmflh@4ax.com>
On Fri, 09 Nov 2001 07:06:50 -0800, Ken <tyl### [at] pacbellnet> wrote:
>If you want to, try going through the newest 1/3 of the bug reports
I do it!
ABX
Date: 9 Nov 2001 12:31:32
Message: <8j4out427k0uls9nkq0kphdh1e7n0510jf@4ax.com>
>  #declare Heart =
If the poly creates the same equation (I've not checked) like heart available in
isosurface library then it could be something strange with equation or solver.
Iso version of heart has also strange line in the middle.
ABX
Date: 9 Nov 2001 13:00:23
Message: <3bec19b6@news.povray.org>
: Iso version of heart has also strange line in the middle.
  Sounds like an undefined location (most probably the 1/0 case).
Date: 10 Nov 2001 02:00:48
Message: <slrn9upk4r.n3e.ron.parker@fwi.com>
Actually it's in the jobs database but marked as suspended.  I wasn't
able to figure out what it was, but it looked like a precision problem
to me.  It might get fixed someday, but not today.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
