POV-Ray : Newsgroups : povray.beta-test : reported isosurfaces bug Server Time
17 Jan 2026 13:07:00 EST (-0500)
  reported isosurfaces bug (Message 1 to 2 of 2)
Subject: reported isosurfaces bug
Date: 8 Dec 2001 05:23:21
Message: <daq31usvqcqirbnlau7er75kl1oc48t30f@4ax.com>
The following report was submitted in error to povray.bugreports.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
To: bug### [at] povrayorg
Subject: iso-crash-bug
Date: Thu, 6 Dec 2001 17:03:59 +0100
I get bizarre results when rendering the following code.
Sometimes the program crashes, sometimes it just hangs, or i get the
following err-msg:
    Scene contains 1 frame level objects; 0 infinite.
    Rendering Error: Maximum function evaluation recursion level reached.
    Returned from renderer with error status
    CPU time used: kernel 0.24 seconds, user 2.76 seconds, total 3.00
seconds
I'm using Version 3.5beta.8.icl.win32  under WinXP
now the code:
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
isosurface {
  function { x*x + y*y + z*z - 1 }
  contained_by { box { <-2,-.5,-2>, <2,.5,2> } }
  accuracy 0.001
  max_gradient 6
  max_trace 4
  texture
      checker
      color rgb 1
      color blue 1
      scale 0.5
    finish{
      diffuse 0.8
      ambient 0.0
      phong 0.05
Greetings
    Thies Heidecke
Subject: Re: reported isosurfaces bug
Date: 8 Dec 2001 07:02:46
Message: <3c120165@news.povray.org>
Alan Kong <ako### [at] povrayno-spamorg> wrote:
: I get bizarre results when rendering the following code.
: Sometimes the program crashes, sometimes it just hangs, or i get the
: following err-msg:
  It seems to be the old known one. Nothing new, I think.
