POV 3.5 RC1 Win installation
HFComputeNormal()
Not used but still (commented) in include file
HFCreate_()
1. Unused Type parameter in HFCreate_ macro.
2. Putting comment inside loop can slow down execution I think
3. First loop use two locals but can be realised with only one.
Here is my version of first loop with speed optimization
but without annoying #debug
#if (Smooth)
// CALCULATION OF NORMAL VECTOR
// We don't vnormalize the vectors from the current center point
// to its neightbor points because we want a weighted average
// where bigger areas contribute more. This also means that the
// center point can be left out completely of the calculations:
#local NArr = array[xRes][zRes]
#local J = 1;
#while (J<=xRes)
#local K = 1;
#while (K<=zRes)
#local VC =
vcross(vnormalize(PArr[J][K+1]-PArr[J][K-1]),vnormalize(PArr[J+1][K]-PArr[J-1][K]));
#declare NArr[J-1][K-1] = ( VC.gray=0 ? 333*x : vnormalize(VC) );
#declare K = K+1;
#declare J = J+1;
HF_Square(), HF_Sphere(), HF_Cylinder(), HF_Torus()
I think that content of loop can be optimized. to remove jumping for conditions.
For example content for HS_Square could be:
CURRENTLY:
#local UV = <(J-1)/(xRes-1),0,(K-1)/(zRes-1)>;
#local P = (UV*Ext*<1,0,1> + MnExt);
#if (UVmap)
#local H = Function(UV.x, UV.z, 0);
#else
#local H = Function(P.x, P.y, P.z);
#declare PArr[J][K] = P + H*Ext*y;
MY REPLACEMENT:
Function(UVmap?UV.x:P.x,UVmap?UV.z:P.y,UVmap?0:P.z)*Ext*y;
scenes\incdemo\shapes.pov
Example shows dark areas on edges of meshes.
It is probably result of low resolution (and direction of normals).
ABX
> HFComputeNormal()
I'll delete it.
> HFCreate_()
It was supposed to be "FileName" instead of "Type", but I see now that no
parameter is needed.
> execution I think
A test shows that you're right, so I'll move the comments outside of the
loops. However, normally it's preferred that you test speed optimizations
yourself before you suggest them.
Whoops, the debug is a leftover from my tests. Don't know how it got
there...
Actually, the test to see if the vector has zero length is also a leftover
from the debugging. Currently the macro should never reach that part anyway,
so it can be removed completely. I will do so.
If you have actually seen the debug being used in some of your tests, then
it is due to an error, and then I would be very interested in that.
I can't see any significant improvement with your version, and it's more
difficult to read.
That's just how smooth triangles are. There's nothing I can do about it that
won't significantly increase the parse time of the demo scene.
Thanks for your input,
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Mar 19)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
On Tue, 16 Apr 2002 21:27:42 +0200, "Rune" <run### [at] mobilixnet dk>
I know, but it was difficoult in this case becouse I worked with printed
version of HF* macros :-)
ABX
> there...
Your changes seems better now except AFAIK you not necessary normalize vector
before calculating cross product (you only inrease floating point error at
this moment) in HFCreate_() macro. Consider below example:
#include "strings"
#local A=<126,45,33>;
#local B=<63,12,7>/1000;
#declare C=vnormalize(vcross(vnormalize(A),vnormalize(B)));
#declare D=vnormalize(vcross(A,B));
#warning VStr(C)
#warning VStr(D)
ABX
> necessary normalize vector before calculating cross
> product
Sheesh, I knew that! How could I forget?
Thanks for the tip! :)
Anyway, I have rewritten the HF macros completely for the next beta.
They now work with mesh2 instead of mesh. Maybe you would like to have a
look at them?
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Apr 14)
On Mon, 22 Apr 2002 20:55:31 +0200, "Rune" <run### [at] mobilixnet dk>
> > product
> look at them?
Yes. I looked at this and ... You made exactly the same mistake as above. :)
And additional note to mesh2 creation process. You can remove condition inside
loops in HFCreate_(). Just don't close and don't open #write directive before
and after condition. Look for changed case of first loop of HFCreate_():
#if(WriteFile)
#fopen _HFMACRO_OUTPUT_FILE FileName write
#write(_HFMACRO_OUTPUT_FILE,"mesh2 {\nvertex_vectors {",xRes*zRes,",\n",
#else
mesh2 {vertex_vectors{xRes*zRes,
#local J = 1;
#while (J<=xRes)
#local K = 1;
#while (K<=zRes)
PArr[J][K]
#declare K = K+1;
#declare J = J+1;
#if(WriteFile)
,"}\n")
#else
ABX
Sigh, I really must learn to remember this!
> You can remove condition inside loops in HFCreate_().
Very clever! With this fixed four places, the speed increase is actually
noticeable. :)
Rune
