POV-Ray : Newsgroups : povray.beta-test : Camera syntax glitch Server Time
14 Dec 2025 16:58:02 EST (-0500)
  Camera syntax glitch (Message 1 to 3 of 3)
Subject: Camera syntax glitch
Date: 27 Jan 2002 15:02:53
Message: <Xns91A399144356FCQ@204.213.191.226>
The angle keyword appears to be ignored unless it is the last keyword given
in the camera block.  #version 3.1 will correct this problem.
Example:
sphere {0,2000 pigment {rgb 1} finish {ambient 1}}
//#version 3.1;
//Render as is, then transpose the angle and look_at keywords and render
//again.  Compare the results.
camera
    location <0,0,15000>
    right x*(image_width/image_height)
    angle 40
    look_at <0,0,0>
Subject: Re: Camera syntax glitch
Date: 27 Jan 2002 15:25:37
Message: <kbo85uojor08o8etfom8r1u56htceliikk@4ax.com>
On 27 Jan 2002 15:02:53 -0500, che### [at] sympaticoca (Coridon Henshaw)
There have been changes to camera syntax in beta 10 which have not yet
been completely described in the documentation.
Peter Popov ICQ : 15002700
Date: 27 Jan 2002 16:07:46
Message: <Xns91A3A413B742ECQ@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:kbo85uojor08o8etfom8r1u56htceliikk@4ax.com:
>>given in the camera block.  #version 3.1 will correct this problem.
IIRC, isn't the objective of the camera changes to ensure that the camera
keywords (with the exception of camera type) are internally applied  in the
correct order, regardless of how they appear in the scene file?
On the other hand, if angle anywhere but last is now invalid syntax, an
error message would seem to be in order, particularly as the new syntax is
the opposite of what 3.1 required.  (3.1 camera breaks if angle comes after
look_at).
