POV-Ray : Newsgroups : povray.beta-test : Longstanding arealight problem? Server Time
13 Jul 2025 22:53:29 EDT (-0400)
  Longstanding arealight problem? (Message 1 to 2 of 2)
Subject: Longstanding arealight problem?
Date: 16 Jan 2002 18:07:08
Message: <Xns9198B851394EACQ@204.213.191.226>
Earlier today, while I was going through the list of unconfirmed bugs, I
came across what appears to be a longstanding bug in the arealight
implementation.  Render the following scene in either v3.5 or v3.1 and note
that the shadow on the right hand side of the sphere appears to be roughly
cut off rather than smooth.
plane {y,0 pigment {rgb 0.5}}
sphere {y,1 pigment {rgb 0.75}}
camera {location <0,4,-8> look_at <0,0,0> rotate y*45}
light_source {y*10 rgb 1 area_light <5,0,5> <-5,0,-5> 16,16 adaptive 1
jitter rotate z*45}
Subject: Re: Longstanding arealight problem?
Date: 16 Jan 2002 18:14:05
Message: <3c46093d@news.povray.org>
It's not a bug. You have just misunderstood how area lights are defined.
  You define two axis vectors as the dimensions of the area light, not its
corner coordinates (as it seems to be the case in your example). What your
example does is (I think) a 1-dimensional area light instead of 2-dimensional.
This is causing the smoothing to be in one direction only.
  What you probably meant was this:
light_source {y*10 rgb 1 area_light <5,0,0> <0,0,5> 16,16 adaptive 1
jitter rotate z*45}
