POV-Ray : Newsgroups : povray.beta-test : another strange photon behavior Server Time
19 Dec 2025 06:29:06 EST (-0500)
  another strange photon behavior (Message 1 to 4 of 4)
Subject: another strange photon behavior
Date: 5 Nov 2001 15:04:25
Message: <MPG.16510f3e44067d3f9896ae@news.povray.org>
There still seems to be a bug (or maybe two) in the (refractive) photons
code.
It accurs only in very special cases, and is dependent on the texture and
shape of the object on wich the photons show up, on the position of the
light_source, the color of the light source, and the color and
filter/transmit of the refractive object (and maybe some other things i
didn't notice).
The symptoms are:
a) bright colored caustics, but the color is not related to the color of
light_source or photon target (of course, dispersion was not used).
b) holes/circular black spots appear in the caustics.
Here is a scene with shows the prob.
I tried to eliminate everything that seems to have no effect on the bug.
I'll also post a rendering of this scene in the beta-test.binaries group.
#version 3.5;
#include "functions.inc"
#declare overallscale=10;
#declare cm=0.01*overallscale;
#declare m=1*overallscale;
global_settings
	assumed_gamma 2
	max_trace_level 50
	photons
		count 10000 jitter .3
camera
	location <0,30,-50>*cm
	look_at <-3.5,6,0>*cm
	angle 30
light_source
	vnormalize(<2,2,-1>)*m*1 // multiply with .6, and the color will
go away
	color rgb <1,1,.95>*2
	spotlight point_at <0,10,0>*cm radius 0 falloff 15 tightness 20
#declare Floor=
texture
	pigment
		color rgb 1
	finish
		ambient 0
		reflection .2 // remove this -> black "holes" in caustics
will go away
#declare Sky=
texture
	pigment
		color rgb 1
	finish{ambient 1}
sphere
	0,1*m
	translate y*(1*m)
	texture
		gradient y scale 2*m
		texture_map
			[0.0 Floor]
			[0.1 Floor]
			[0.3 Sky]
			[1.0 Sky]
	translate -y*0.01*cm
	inverse
	//clipped_by{plane{y,.02*m }}
lathe
	//linear_spline
	cubic_spline
	6+2+2+1,
	< -0.5,  0.1>*cm,
	<  0.0,  0.1>*cm,
	<  4.0,  0.0>*cm,
	<  4.75, 0.5>*cm,
	<  4.0,  3.0>*cm,
	<  5.0,  10.0>*cm,
	<  5.0,  11.5>*cm,
	<  4.5,  10.0>*cm,
	<  3.2,  1.5>*cm,
	<  0.0,  1.5>*cm
	< -0.5,  1.5>*cm
	// avoid coicidence probs
	translate y*.1*cm
	pigment
		color rgb <.99,1,.99>
		filter .9
	interior
		ior 1.5
	photons{target refraction on reflection on collect off}
Subject: Re: another strange photon behavior
Date: 5 Nov 2001 15:12:28
Message: <MPG.1651111ef0b617489896b0@news.povray.org>
Oops, forgot:
Windows98SE, POV 3.5 beta 7, both compiles
Date: 5 Nov 2001 16:26:25
Message: <3BE70403.7F1EA60E@engineer.com>
Same here. Win98SE Athlon.
_____________
Kari Kivisalo
Date: 9 Nov 2001 14:20:51
Message: <3BEC2B3D.8F3CBBD8@twoalpha.net>
Below is an updated script that seems to work with your original settings.  I
added photons to the reflective sphere and also added caustics to the glass.
This made a nice picture as far as I can see.
Dean
#version 3.5;
global_settings
        assumed_gamma 2
        max_trace_level 50
        photons
                count 10000 //jitter .3
camera
        angle 30
light_source
        vnormalize(<2,2,-1>)*m*1 // multiply with .6, and the color will go
away
        color rgb <1,1,.95>*1
#declare Floor=
texture
        pigment
                color rgb 1
        finish
                ambient 0
will go away
#declare Sky=
texture
        pigment
                color rgb 1
        finish{ambient 1}
sphere
        0,1*m
        translate y*(1*m)
        texture
                texture_map
                        [0.0 Floor]
                        [0.1 Floor]
                        [0.3 Sky]
                        [1.0 Sky]
        inverse
photons{target refraction on reflection on collect off}}  //added by Dean to
see if how it changes things
lathe
        //linear_spline
        cubic_spline
        6+2+2+1,
        < -0.5,  0.1>*cm,
        <  0.0,  0.1>*cm,
        <  4.0,  0.0>*cm,
        <  4.75, 0.5>*cm,
        <  4.0,  3.0>*cm,
        <  5.0,  10.0>*cm,
        <  5.0,  11.5>*cm,
        <  4.5,  10.0>*cm,
        <  3.2,  1.5>*cm,
        <  0.0,  1.5>*cm
        < -0.5,  1.5>*cm
        translate y*.1*cm
        pigment
                filter .9
        interior
                ior 1.5
                  caustics .5//added by Dean to see if how it changes things
Lutz-Peter Hooge wrote:
> Hi,
> code.
> didn't notice).
> The symptoms are:
> #version 3.5;
> global_settings
>         assumed_gamma 2
>         max_trace_level 50
>         photons
> camera
>         angle 30
> light_source
> go away
> #declare Floor=
> texture
>         pigment
>                 color rgb 1
>         finish
>                 ambient 0
> will go away
> #declare Sky=
> texture
>         pigment
>                 color rgb 1
>         finish{ambient 1}
> sphere
>         0,1*m
>         translate y*(1*m)
>         texture
>                 texture_map
>                         [0.0 Floor]
>                         [0.1 Floor]
>                         [0.3 Sky]
>                         [1.0 Sky]
>         inverse
> lathe
>         //linear_spline
>         cubic_spline
>         6+2+2+1,
>         < -0.5,  0.1>*cm,
>         <  0.0,  0.1>*cm,
>         <  4.0,  0.0>*cm,
>         <  4.75, 0.5>*cm,
>         <  4.0,  3.0>*cm,
>         <  5.0,  10.0>*cm,
>         <  5.0,  11.5>*cm,
>         <  4.5,  10.0>*cm,
>         <  3.2,  1.5>*cm,
>         <  0.0,  1.5>*cm
>         < -0.5,  1.5>*cm
>         translate y*.1*cm
>         pigment
>                 filter .9
>         interior
>                 ior 1.5
