POV-Ray : Newsgroups : povray.beta-test : division-by-zero-crash? Server Time
13 Oct 2025 21:10:29 EDT (-0400)
  division-by-zero-crash? (Message 1 to 10 of 10)
Subject: division-by-zero-crash?
Date: 28 Sep 2001 14:16:53
Message: <MPG.161edd5f8ac5762898968e@news.povray.org>
If using a function in a pigment like this
#declare f=function {1/x}
plane{z,0 inverse pigment{function{f(x,y,z)}}}
povray crashes after creating the preview window.
A problem with with the handling of div. by zero errors I guess.
3.5 beta 4, Win98SE
Lutz-Peter
Subject: Re: division-by-zero-crash?
Date: 28 Sep 2001 14:36:49
Message: <3bb4c341@news.povray.org>
In article <MPG.161edd5f8ac5762898968e@news.povray.org> , Lutz-Peter Hooge
Hmm, I get a proper "Floating-point exception detected in function 'f'. Your
function either attempted a division by zero, used a function outside its
domain or called an internal function with invalid parameters." message
using the "A typical camera" template together with your example.  Without a
set camera the scene runs through without any problems.
    Thorsten
Date: 28 Sep 2001 15:10:40
Message: <MPG.161ee9f9c07838c998968f@news.povray.org>
In article <3bb4c341@news.povray.org>, tho### [at] trfde says...
Ok, this is the complete "scene"
#version 3.5;
camera
	location <0,1,-4>
	look_at <0,0,0>
Date: 28 Sep 2001 15:15:04
Message: <3bb4cc38@news.povray.org>
In article <MPG.161ee9f9c07838c998968f@news.povray.org> , Lutz-Peter Hooge
> #version 3.5;
> camera
>  location <0,1,-4>
>  look_at <0,0,0>
Still getting an error message and no crash.
    Thorsten
Date: 28 Sep 2001 15:17:53
Message: <MPG.161eebabeda1c72f989690@news.povray.org>
In article <3bb4cc38@news.povray.org>, tho### [at] trfde says...
Strange... over here it happens every time. I also restartet windows and
tried again.
Date: 28 Sep 2001 15:20:13
Message: <slrn9r9jbf.639.ron.parker@fwi.com>
>> #version 3.5;
>> camera
>>  location <0,1,-4>
>>  look_at <0,0,0>
I get a crash here, on Linux:
Creating bounding slabs.
Scene contains 1 frame level objects; 1 infinite.
File: div0.pov  Line: 7
Fatal Error: Floating-point exception detected in function 'f'. Your function ei
ther attempted a division by zero, used a function outside its domain or called
Possible Rendering Error: libpng: No IDATs written into file
Possible Rendering Error: Cannot write PNG file.
Segmentation fault
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 28 Sep 2001 15:23:53
Message: <slrn9r9jic.639.ron.parker@fwi.com>
>>> #version 3.5;
>>> camera
>>>  location <0,1,-4>
>>>  look_at <0,0,0>
More details.  I don't have time to track this one down right now, but
hopefully this stack trace will help.  I have a +fn in my default INI
file; it would help to know what parameters Lutz is rendering with.
#0  0x80bc1fd in PNG_Image::~PNG_Image (this=0x8174ac0, __in_chrg=3)
    at png_pov.cpp:816
#1  0x80cab10 in close_all () at povray.cpp:1885
#2  0x80c93b3 in povray_terminate () at povray.cpp:498
#3  0x80c9401 in povray_exit (i=1) at povray.cpp:543
#4  0x80f53b8 in ErrorAt (filename=0x8177598 "div0.pov", line=7,
    format=0x8117f20 "Floating-point exception detected in function '%s'. Your f
unction either attempted a division by zero, used a function outside its domain
or called an internal function with invalid parameters.") at userio.cpp:419
#5  0x806af4e in POVFPU_Exception (fn=0) at fnpovfpu.cpp:1062
#6  0x806ebc2 in POVFPU_RunDefault (fn=1) at fnpovfpu.cpp:1276
#7  0x80b25c8 in function_pattern (EPoint=0xbffff030, TPat=0x8177928)
    at pattern.cpp:1623
#8  0x80af5a7 in Evaluate_TPat (TPat=0x8177928, EPoint=0xbffff030,
    Intersection=0xbffff928) at pattern.cpp:202
#9  0x80ba413 in Compute_Pigment (Colour=0xbffff630, Pigment=0x8177928,
    EPoint=0xbffff7d0, Intersection=0xbffff928) at pigment.cpp:538
#10 0x8084d74 in compute_lighted_texture (ResCol=0xbffff804,
    Texture=0x8177878, IPoint=0xbffff7d0, Raw_Normal=0xbffff7e8,
    Ray=0x814b320, Weight=1, Intersection=0xbffff928) at lighting.cpp:3857
#11 0x8084872 in do_texture_map (Result_Colour=0xbffff804, Texture=0x8177878,
    IPoint=0xbffff7d0, Raw_Normal=0xbffff7e8, Ray=0x814b320, Weight=1,
    Ray_Intersection=0xbffff928, Shadow_Flag=0) at lighting.cpp:3617
#12 0x807f557 in Determine_Apparent_Colour (Ray_Intersection=0xbffff928,
    Colour=0x81bbc30, Ray=0x814b320, Weight=1) at lighting.cpp:600
#13 0x80d5b92 in Trace (Ray=0x814b320, Colour=0x81bbc30, Weight=1)
    at render.cpp:1903
#14 0x80d6f12 in trace_pixel (x=160, y=0, Colour=0x81bbc30) at render.cpp:2835
#15 0x80d4fc2 in Start_Non_Adaptive_Tracing () at render.cpp:1391
#16 0x80c9a65 in FrameRender () at povray.cpp:993
#17 0x80c9503 in FrameLoop () at povray.cpp:723
#18 0x80c9378 in povray_render (argc=3, argv=0x81698e8) at povray.cpp:455
#19 0x80c90bd in main (argc=3, argv=0xbffffc74) at povray.cpp:246
#20 0x4016db0f in __libc_start_main ()
Date: 28 Sep 2001 15:25:42
Message: <MPG.161eed77fc317236989691@news.povray.org>
When rendering it maximises the preview windows (dond't know why), then
it gives an "invalid page fault" (hope this is the correct translation,
german Windows version).
I cust discovered the POV GUI itself is still functional until I close
the error message.
So I could minimize the preview window and look at what Pov itself says:
--snip
File: C:\Eigene Dateien\test.pov  Line: 6
Returned from renderer with error status
--snap-
Lutz-Peter
Date: 28 Sep 2001 15:29:03
Message: <MPG.161eee4ab937df8c989692@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
says...
I had +fn in the command line too. Sorry I forgot to mention this.
AH!, when I remove it (reners to .bmp then), it doesn't crash
Date: 28 Sep 2001 15:29:51
Message: <3BB4D081.8E222799@gmx.de>
> the error message.
Ok, i think i have it, crash only with png output here (WinNT, beta 4).
