POV-Ray : Newsgroups : povray.beta-test : Reallocing Finite with extension (with crash) Server Time
14 Dec 2025 16:59:03 EST (-0500)
  Reallocing Finite with extension (with crash) (Message 1 to 5 of 5)
Subject: Reallocing Finite with extension (with crash)
Date: 28 Jan 2002 06:04:52
Message: <8laa5us450irp75g6l2i4e84dm1c4v4i01@4ax.com>
POV 3.5 b 10 icl on WinNT Sp 6 PII 233 with 128 MB
There were some reports about "Reallocing Finite" message and crash previously
(i.e. http://news.povray.org/3c375d62%241%40news.povray.org ).
But I'm not sure if my crash is connected with it so I report.
Look at below scene
// SCRIPT 1
#local C=1000;
#while(C)
  #declare D=-C^.5*100*z;
  #local C=C-1;
It is parsed sucesfully and returns black render so let's add ad object
// SCRIPT 2
#local C=1000;
#while(C)
  sphere{0 1 rotate D pigment{rgb 1}}
  #local C=C-1;
It crash every time with last message about "relocating finite" message.
But it is not end of problem. Let's reorder calculation for D.
// SCRIPT 3
#local C=1000;
#while(C)
  #declare D=-100*C^.5*z;
  #local C=C-1;
It not crash. It is parsed ok, opens render window and then it stops rendering
with Rendering Error "Too many nested objects". Well, nested objects ? Does it
mean one inside another. Let's see - yes, they are identical - it's centered
object rotated around origin. So let's move it a little along x.
// SCRIPT 4
#local C=1000;
#while(C)
  sphere{x 1 rotate D pigment{rgb 1}}
  #local C=C-1;
It not crash but it still says "Too many nested objects". So let's see
documentation. Only thing related to "nested objects" string is "5.2.6.2
Automatic Bounding Control" so let's repeat all scripts with Bounding=off.
Unfortunatlly behaviour not changed.
Any confirmation ?
ABX
Subject: Re: Reallocing Finite with extension (with crash)
Date: 28 Jan 2002 06:26:05
Message: <3c55354d@news.povray.org>
news:8laa5us450irp75g6l2i4e84dm1c4v4i01@4ax.com...
previously
> Look at below scene
> // SCRIPT 1
> #local C=1000;
> #while(C)
>   #local C=C-1;
> #end
object
> // SCRIPT 2
> #local C=1000;
> #while(C)
>   #local C=C-1;
> #end
message.
> // SCRIPT 3
> #local C=1000;
> #while(C)
>   #local C=C-1;
> #end
rendering
? Does it
centered
> // SCRIPT 4
> #local C=1000;
> #while(C)
>   #local C=C-1;
> #end
see
"5.2.6.2
Bounding=off.
> Any confirmation ?
> ABX
SCRIPT 3+4: It keeps saying "Rendering line 1 of 480" in the status
bar.
Everything confirmed (WINPOV Beta 10, Win 98SE, 128MB, P3 600MHz).
Felix Wiemann
Date: 28 Jan 2002 06:58:30
Message: <3C553D01.77D55F93@atosorigin.com>
The "Too many nested objects" message appears when computing the intersection
and one is found to be inside a lot of objects.
Alas, "a lot" is a compilation define (or dependant of it) and cannot be
updated via SDL. Well, IIRC a message from this group.
May be using a sphere further away from the origin, with a kind of uniform
repartition (because 100xsqrt(c), with c from 0 to 1000 cover
0 to 316 (and not even 360) , with a lot of them near the end(1000) and few
near the original position. For instance, hundred spheres are between
300 and 316, and worst thing, all of the thousand spheres intersect at <0,0,0>!
Or just reducing the radius of the sphere.
P.S.: what about sphere_sweep instead ?
Non Sine Numine
http://grimbert.cjb.net/
Date: 28 Jan 2002 07:21:10
Message: <cffa5u85bs2tktme3pp8a3fpuochu3cjp6@4ax.com>
So this part is documentation report becouse User can be confused with such
error with no specification, explanation or workaround.
I have investigated it little more and this limit is probably equal 100.
#local C=100;
#while(C)
  plane{z 0 translate z pigment{rgb 1}}
  #local C=C-1;
> repartition...
In this case it was only example. In real scene I use also translation before
rotation and I also use complicated shape different for each C so there was no
way to workaround. The main problem in this post was why crash connected with
rotation disappeare when I reordered calculation.
ABX
Date: 6 Feb 2002 15:48:03
Message: <slrna635k6.648.ron.parker@fwi.com>
Then you'll be pleased to find out that the crash has been fixed.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
