POV-Ray : Newsgroups : povray.beta-test : CSG Issues with disc shape. v38 beta 2. Server Time
24 Jun 2026 03:45:10 EDT (-0400)
  CSG Issues with disc shape. v38 beta 2. (Message 1 to 10 of 18)
Subject: CSG Issues with disc shape. v38 beta 2.
Date: 24 Sep 2025 05:02:31
Message: <68d3b3a7@news.povray.org>
Due to recent discussions in the pov4 forum, I decided to document what
I believe are issues with disc{} shape's CSG results. Ref:
https://news.povray.org/povray.pov4.discussion.general/thread/%3C68c8a619%241%40news.povray.org%3E/
See the attached image and scene files.
The top row a disc{} is being intersected with a sphere{}. In the second
row a roughly equivalent polygon{} is intersected in the same fashion.
I believe the disc{} results are correct only in the second and last
columns. The polygon row of intersections I believe is OK(*).
Bill P.
(*) Image results use v3.8 beta 2. The normal in yuqk for the polygon{}
is flipped so +z is the outside texture.
Download 'discoddnesscsg_v38.png' (52 KB) Download 'discoddnesscsg.pov.txt' (4 KB)
Preview of image 'discoddnesscsg_v38.png'
Subject: Re: CSG Issues with disc shape. v38 beta 2.
Date: 24 Sep 2025 09:45:00
Message: <web.68d3f4cae434b08f1398638025979125@news.povray.org>
So, I need to question the whole top row.
I refer to the disc {} in its form with a hole using the mathematically accurate
term "annulus".
It's interesting that the annulus gets rendered with what appears to be a
bounding box with the sphere texture included.  I'm assuming that's part of the
erroneous behaviour - only the annulus ought to be rendered.
1. If column 2 and 5 both show the sphere, then why doesn't column 1 show the
lower part of the sphere?
(bounding boxes and perhaps some method of showing the inside () results of the
disc might help. VRandInObject or whatever it's called, or media)
2. Confused about why inverse shows so much of the sphere.
Does the disc act like a half-infinite cylinder?
Does inverse now cause it to be  NOT(half-infinite cylinder)?
Because even that doesn't seem like the correct result to me.
3. I guess it's wrong, but consistent with render 1.
4. perhaps this might be correct, if we're considering the disc/annulus to
technically have an inside () ?  Though I would expect for there to not be
anything, since the annulus surface is outside/tangent to the sphere
5.  No idea why you think that's correct, since there's now no overlap, unless
we're somehow considering the annulus to be some form of plane / half-space
object.  But then that leaves me confused about the rest of the renders in that
row.
I am in full agreement about the bottom row.
Suggest:
0. show bounding boxes and insidedness tests for the annulus.
1. apply an inside_texture to the sphere
2. use a sphere with a negative radius
3. use sphere {inverse}
4. use both inverse
5. make the major and minor radii of the annulus equal.
6. refer to my Boolean operations render, and see if that inspires any
additional experiments - my subconscious tells me that using that as a guide to
construct formalisms for what we're doing with objects and CSG (and using very
accurate, formal terminology apart from what we use in SDL) might help us
unravel what our less rigorous discussions may be hiding from us.
https://news.povray.org/povray.documentation.inbuilt/thread/%3Cweb.68573b7934ec28cb1f9dae3025979125%40news.povray.org%3
E/
"Since POV-Ray does not implement regularized Boolean operations (i.e., union,
intersection and difference are done as conventional set operations)"
(bottom of page)
https://pages.mtu.edu/~shene/COURSES/cs3621/LAB/povray/csg.html
P.S. As I was letting Second Coffee percolate into my blood stream this morning,
I was mixing thoughts about scene experiments, and I recently tried to render a
cone (a real, mathematical "double-cone") as an isosurface and had an issue,
until I reformulated how I was doing it to avoid division-by-zero.
Could you (someone) also render a cone {} with one radius positive, and the
other radius the unary inverse?  Use inside_texture and repeat CSG experiments.
Thanks,
- BW
Date: 24 Sep 2025 15:07:56
Message: <68d4418c$1@news.povray.org>
> term "annulus".
I think the answer to most (all?) of your questions about the disc is
the inside test is supposed to be equivalent to a plane{}'s inside test
using the disc{}'s normal.
In yuqk I'm leaning heavily toward changing the disc{} to a patch object
with an inside test that always returns false. To fix it, I suspect I'd
have add internal dual cylinder bounding, but cost wise this will be not
much different than a CSG difference with two cylinders...
FYI. You are correct the issue in v3.8 beta2 is bounding related.
Attached an image rendered with yuqk using the '-b' flag to turn
bounding off. The yuqk fork turns bounding 'completely' off with '-b'
where v3.7 and v3.8 made code changes which pushed the last level of
bounding for shapes outside the +-b flag's control(*). The yuqk fork has
restored the v3.6 and prior behavior - and the restoration is certainly
helpful here for debugging.
(*) - The change offered a performance optimization in some situations.
Ah, I see the cone is doing something weird where the two radii are
negative. We should probably just not allow negative radii arguments in
the parser - for any shape.
Bill P.
Aside 1: Long on my todo list is breaking apart the cylinder and cone
code. Today it's all munged together making both slower and more complex
than they need be.
Aside 2: clipka fixed something with the cone behavior (my memory
otherwise fails) in v3.8. I expect v3.7 cone behavior is different in
some aspect.
Download 'discoddnessnoboundingcsg_yuqk.png' (58 KB) Download 'coneoddnesscsg_v38.png' (63 KB)
Preview of image 'discoddnessnoboundingcsg_yuqk.png'
Preview of image 'coneoddnesscsg_v38.png'
Date: 24 Sep 2025 15:50:00
Message: <web.68d44aace434b08fe2c47eda25979125@news.povray.org>
Nice renders.  These are a great starting point for a debugging toolkit, as well
as what could be some interesting extra documentation.
What I meant, if you misunderstood, was to have one side be radius r, and the
other side be radius -r, so that it would make a "double-cone".
> Bill P.
> than they need be.
clipka at one time said that the cylinder is just a cone with 2 equal end radii
> some aspect.
It would be great if someone could hunt down the readme for 3.8 to see if that's
mentioned.  Are there any comments in source?
- bw
Date: 24 Sep 2025 16:10:00
Message: <web.68d44f2be434b08fe2c47eda25979125@news.povray.org>
I would say that that makes sense.
As I have discussed with jr, and perhaps brought up in other posts, I would like
to have default values for things like the disc radii and surface normal if they
are not provided.   That might be a parser thing in addition to a .cpp thing.
Useful would be a swept annulus - a tube {}
Simply because it seems to be a common shape and it can be cumbersome if one has
a lot of them to make - especially for a newbie.
One of the things that I have read about in CS courses, and elsewhere, is that
they have that "regularized Boolean" variant, which I think we could immensely
benefit from - given that it would get rid of the residual coincident surface
problem when doing differences.
Alternately, would be some hierarchical CSG logic, whereby the last object
specified in any given CSG operation takes precedence.  I guess it would be sort
of like a z-buffer for CSG.  It's also how I code differences in my editor - the
differencing objects get indented after the parent object.  So, in a coincident
surface contest, the parent object should always lose.
Getting better at reading and interpreting the source, though I don't see the
big picture in terms of information flow.
-bw
Date: 24 Sep 2025 18:12:50
Message: <68d46ce2@news.povray.org>
Ah, yes, the double cone looks to work fine.
On the cone fix all I could find was a fix Chris implemented for v3.7
which wasn't in v3.6. For v3.8 there is some uv mapping stuff added and
then removed by clipka where others were involved. So... It might just
be my failing head getting things mixed up. :-)
Bill P.
Date: 24 Sep 2025 18:35:00
Message: <web.68d4711ee434b08f1f9dae3025979125@news.povray.org>
Well...  sorta.
I was actually wondering if the normal flipped, which apparently it used to:
https://news.povray.org/povray.general/thread/%3Cweb.58228e15512a2627116828db0%40news.povray.org%3E/?mtop=412640
"Note : a cone can take a negative radius. In this case, you'll get a
double cone. You can try this :
cone{2*x, 2, -2*x, -2 pigment{rgb 1} inside_texture{pigment{rgb<0,0,1>}}}
Yes, the left part IS blue."
And that's why I think that allowing the negative radius should be kept, and
perhaps even enhanced. *
I tried searching for documentation instances for "negative radius" but didn't
find much - but I seem to remember notes to the effect that the normal would be
flipped.  torus?  sphere?
* What I'm currently thinking about is whether there should be some mechanism
for "inside-out" shapes to be functionally equivalent to _inverse_.
So maybe in regular mode, the negative radius just flips the normal, but perhaps
with an additional keyword, any inside-out part would actually be inverted.
Which also had me wondering what other shapes we can cleverly play with using
negative values.
- bw
Date: 24 Sep 2025 18:52:07
Message: <68d47617$1@news.povray.org>
>> and the
Blast, it doesn't work for all +- values.  Let me see if I can figure
out why not.
Started to look at allowing both values to be negative and in testing
that potential change I found not all +- -+ radii values work for
getting a double cone.
Saw your other post on normal changes. I've not seen that in v3.8+, but
who knows. Maybe it worked at some point as you suggested.
Bill P.
Date: 24 Sep 2025 19:30:00
Message: <web.68d47e2be434b08f1f9dae3025979125@news.povray.org>
> out why not.
Whoa.  I did not expect that.
Looks like there's some kind of clipping going on with the bounding.
- bw
#version 3.8;
global_settings {
 assumed_gamma 1.0
#declare E = 0.000001;
#declare Zoom = 14; //60;
 orthographic
 location <0, 0, -10>
 right    x*image_width/Zoom
 up       y*image_height/Zoom
 look_at  <0, 0, 0>
light_source {<0, 0, -200> rgb 1}
sky_sphere {pigment {rgb 0}}
#declare XM = 25;
#declare YM = 25;
#for (Y, -1, 1, 0.1)
 #for (X, -1, 1, 0.1)
  cone {-x, Y, x, X
  texture {pigment {rgb <abs(X), abs(Y), abs(X+Y)>} finish {emission 0.2}}
  translate <X*XM, Y*YM, 0>
text { ttf "arial.ttf", "+r1, -r2", 0.02, 0.0 translate <-1.2*XM,  1*YM, 0>}
text { ttf "arial.ttf", "-r1, -r2", 0.02, 0.0 translate <-1.2*XM, -1*YM, 0>}
text { ttf "arial.ttf", "r1=0, -r2", 0.02, 0.0 translate <-1.2*XM, 0, 0>}
text { ttf "arial.ttf", "+r1, +r2", 0.02, 0.0 translate < 1.1*XM,  1*YM, 0>}
text { ttf "arial.ttf", "-r1, +r2", 0.02, 0.0 translate < 1.1*XM, -1*YM, 0>}
text { ttf "arial.ttf", "-r1, r2=0", 0.02, 0.0 translate <-3, -1.05*YM, 0>}
Download 'cone_test.png' (202 KB)
Preview of image 'cone_test.png'
Date: 25 Sep 2025 07:34:39
Message: <68d528cf$1@news.povray.org>
Yep, tried my '-b' yuqk flag and it fixes all the +- -+ cases in your
test scene where bounding goes wrong(*). Thank you for posting it! :-)
I took a few swings at fixes late last night, but no luck. I'm going to
code up some parser checks to limit the radii to positive values only
until I can come back to this issue with more focus.
I have quite a bit yet to do to finish the sor{} changes in yuqk{} and
that's only the most recent ball I've let hit the ground. :-)
Bill P.
(*) The render was slow without bounding!
