POV-Ray : Newsgroups : povray.beta-test : CSG Issues with disc shape. v38 beta 2. Server Time
25 Oct 2025 04:27:21 EDT (-0400)
  CSG Issues with disc shape. v38 beta 2. (Message 11 to 18 of 18)
Subject: Re: CSG Issues with disc shape. v38 beta 2.
Date: 25 Sep 2025 11:40:00
Message: <web.68d5614ae434b08f1398638025979125@news.povray.org>
> > Aside 2: clipka fixed something with the cone behavior (my memory
> > otherwise fails) in v3.8. I expect v3.7 cone behavior is different in
> > some aspect.
https://www.povray.org/beta/
Changes between 3.7.beta.35 and 3.7.beta.35a
Fixed an axis problem with cones.
And that's all I've found so far.
Haven't downloaded the 3.8 source to dig through that yet.   All I have is 3.7
stable.
- BW
Date: 25 Sep 2025 14:50:00
Message: <web.68d58ecce434b08f684162df25979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> I took a few swings at fixes late last night, but no luck. I'm going to
> code up some parser checks to limit the radii to positive values only
> until I can come back to this issue with more focus.
I'm looking at the following
if (fabs(apex_radius - base_radius) < EPSILON)           // line 757
if (apex_radius < base_radius)                           // line 768
tmpf = base_radius * len / (apex_radius - base_radius);  // line 782
if (((apex_radius - base_radius)*len/tlen) < EPSILON)    // line 788
and wondering if those should should use fabs of each radius for the
calcs/comparisons
Just because I'm getting the impression that once one of the values crosses
zero, the differences sort of double-back on themselves, which might trigger
that whole
 /* What we are dealing with here is really a cylinder */
        Set_Flag(this, CYLINDER_FLAG);
        Compute_Cylinder_Data();
        return;
part, which might wind up clipping one side of the cone.
So it might be partially an algorithmic bug?
What bounding are you disabling in yuqk?
Is it stuff in
https://github.com/POV-Ray/povray/tree/master/source/core/bounding ?
Have you tried manually bounding the cones with a cylinder using the max
(abs(r1), abs(r2)) in SDL?  Curious if that would
a. work
and
b. be faster
- BW
Date: 25 Sep 2025 18:55:00
Message: <web.68d5c7a4e434b08f1f9dae3025979125@news.povray.org>
POV-Ray screwed me.
"Unnecessary bounding object removed."
Might be time to fix that or update the bounded_by documentation page.
Date: 30 Sep 2025 19:27:14
Message: <68dc6752$1@news.povray.org>
On 9/24/25 15:07, William F Pokorny wrote:
> In yuqk I'm leaning heavily toward changing the disc{} to a patch object
> with an inside test that always returns false. To fix it, I suspect I'd
> have add internal dual cylinder bounding, but cost wise this will be not
> much different than a CSG difference with two cylinders...
Alright. In yuqk I've turned the disc{} shape into a shape like
polygon{} having an inside test which always returns false.
What I learned is that the polygon{} shape - and now the disc{} shape
too - are not PATCH_OBJECT type shapes internally, but rather
BASIC_OBJECT types also using that NonsolidObject class.
I'd earlier missed that the NonsolidObject class overrides the Invert()
method in the base object class in a way that turns the object modifier
'inverse' method into a No-OP (disables 'inverse').
So... We have in the code two slightly different ways to set up patch
like objects. Why? Why? Why! you ask.
The only effective difference I see at the moment is that when the
patch-like shape is set up as a PATCH_OBJECT type we get warnings we
don't get when the patch-like shape is set up as a BASIC_OBJECT type.
Specifically:
   "Parse Warning: Patch objects not allowed in intersection."
and
   "Cannot invert a patch object."
In yuqk, I've changed that first warning so that it is only active for
yuqk's debug compile because I don't see much value in it - we can do
those sorts of intersections. Further, I changed the debug compile
warning message so that it now reads:
"Parse Warning:
Patch object used in difference{} or intersection{} block. If a mesh{}
or mesh2{} shape consider defining an 'inside_vector' to enable inside
testing."
The second parse warning has - for release R20 - been moved to
NonsolidObject::Invert() to generate warnings for all patch-like shapes
no matter their being set up as BASIC_OBJECT or PATCH_OBJECT.
As for how all this patch-like stuff should ultimately be set up, I need
think about it for a while (see aside below).
Bill P.
Aside
Why not allow 'inverse' with more (all?) these patch-like
(NonsolidObject) shapes? In some limited code play things look to work.
It flips the normals, which is useful where both texture{} and
interior_texture are set up.
The inside region would be limited by the shape's bounding box where
'inverse' is used.
We could then too use bounded_by{} to do much of what clipped_by{} can
do, but more efficiently.
The obvious downside, I think, is the behavior is less intuitive /
obvious to users (me included). Thoughts?
In any case, all has me leaning even more toward changing the default in
V4.0 to preserving user specified bounding as the default. These days,
mostly, there is only auto-bounding in scenes. Where a user specifies
bounded_by{} he probably wants to use that bounding.
Date: 30 Sep 2025 19:36:57
Message: <68dc6999$1@news.povray.org>
> POV-Ray screwed me.
You can manually bound, if you use '-ur' / 'remove_bounds=off'.
The '-b' option turns off all general object bounding(*) in the yuqk
fork. It turns off most, but not all, of that same general bounding in
v3.7 and v3.8 versions of POV-Ray.
Bill P.
(*) - Bounding methods 1 (slab) and 2 (bsp).
Beyond that bounding, some shapes like blob{} and mesh{} / mesh2{} have
internal bounding which can sometimes (always?) be turned off with the
SDL 'hierarchy off' object modifier; Some shapes - like the sor{} - have
internal bounding that is always there; Some shapes always use a
contained_by{} shape which both determines bounds and can become part of
the overall result - a little like a, tucked in the shape,
intersection{}.
Date: 30 Sep 2025 20:45:00
Message: <web.68dc78abe434b08f1f9dae3025979125@news.povray.org>
Why, Bill?  :D
> "Parse Warning:
> testing."
That's like one of the best POV-Ray warning messages I've ever read.  :)
Why more efficiently?
Well, that depends on the documentation and examples provided, right?
I'm sure that given everything that gets learned, all of that should be
documented/preserved in a directory specific to that object type.
Scene files, comments, and supplementary documentation files are cheap - but the
preservation of the insights and lessons are invaluable.
Detailed diagrams and even animations are cheaply stored in the distro as .pov
and .ini files.
We would assume so, yes.
Now that you're that deep into the code for disc, which is a simple object,
could you at some point help a few of us POV-bros out and give a general layout
of how POV-Ray .h and .cpp files go about "making" the object?
Perhaps in a dedicated thread?
The faster I'm able to learn to navigate my way through one object, the easier
the rest of them will be.  Even I can't start writing various bug fixes and
features from scratch, I can at least start writing up good, accurate, and truly
helpful documentation and diagrams.
Hugely tangentially related, have you thought about using that as a test object
(simple normal code) for developing things like surface normal pigment
functions, directional gradient pigment functions, and surface curvature pigment
functions?
Applying that to a sphere would allow anisotropic scaling to then start to
really test those out.  I'm sure even mistakes would yield interesting results.
- BW
Date: 1 Oct 2025 17:02:26
Message: <68dd96e2$1@news.povray.org>
Your question got me thinking - thanks. It's probably less often more
efficient than I first thought.
The clipped_by{} process is something which runs after ray-surface
intersections for the object being clipped are determined. Basically, it
runs one or more shape inside tests for each surface intersection. Those
found inside are kept, those not are ignored. The inside tests are not
free to calculate - and they bypass the higher level generic bounding so
the inside test often get run more than strictly necessary.
What had in mind was something like the sphere solid-not-solid example
using a difference as a stand in for clipped_by{} where the disc was out
of scope bounding wise. We'd use only the 'inverse' inside test - within
the bounding box. Unlike that solid-not-solid example, the inside test
cost close to nothing - higher compiler optimization levels should
eliminate even the method / function call.
On letting your question bang around in my skull for a while I had the
thought - well Bill P, you could just use the inverted disc as the
clippped_by{} shape. In that case the inside test itself would be faster
because it is always false. We'd still be losing out on the high level
bounding by using clipped_by{}.
Related. What I'm starting to think a lot about, is trying out some
no-surfaces-ever / inside-test-only 'non-shapes' as another class of
objects we could use in CSG operations.
In POV-Ray proper we have the object{} pattern. (In yuqk the object{}
pattern has been renamed bool_object{} and about a half dozen additional
forms like dens_object, list_object{} patterns have been added.)
I 'think' there is nothing stopping us from using what are effectively
scalar value fields (value patterns) as inside tests that can be bounded
and used more or less 'directly' in CSG to select / ignore portions of
surfaces. Those CSG surface results could then have spatial object
modifiers applied, for example, in addition to specific texturing.
I saw your suggestion about creating some how to object documentation...
I think clipka did something like this in a post for what is more or
less obvious as necessary functions / methods by looking at something
like disc.cpp. In support of any object is dedicated parsing code for
the supporting SDL.
It's complicated beyond that rough outline. What you've been doing with
trying to pull back the layers with the sor{} implementation is just
what one has to do - pretty much shape by shape because they are all
implemented somewhat differently.
Maybe, if I do get to trying on or more 'non-shapes' / 'insider'(s), I
can keep a rough log of what I did to implement one. No promises.
Bill P.
Date: 10 Oct 2025 15:57:31
Message: <68e9652b@news.povray.org>
On 9/30/25 19:36, William F Pokorny wrote:
>> POV-Ray screwed me.
Ugh! In looking more at bounded_by{} and clipped_by{} myself of late, I
re-discovered / remembered - after thrashing a couple days - that
official versions of POV-Ray have this weird 3D volume test which limits
user specified bounding to that which is 'smaller' than the initial
automatic bounding volume. The code just does this "I know better than
the user bit," silently.
The yuqk fork removed the volume increase limiting code back in 2017. It
was always a bad idea for reasons - not the least of which is that it
often prevents users from working around automatic bounding which isn't
working correctly.
So... I was too flippant with my initial response with respect to
official releases of POV-Ray supporting manual bounding and +-ur /
remove_bounds=. Manual bounding is at least somewhat broken / limited in
recent official POV-Ray releases.
I'm working in yuqk mostly, and thousands of changes down the road, my
old head doesn't remember everything different relative to official
POV-Ray releases. I've been trying to get yuqk's documentation up to
date - largely for my own sanity in helping me remember changes like
these - but I'd not gotten to writing updated documentation for
bounded_by{} and clipped_by{}. :-( FWIW.
There are other yuqk manual bounding differences too. Another of note,
is that the official POV-Ray code will update bounding based upon the
clipped_by{} shape(s) alone (or by overriding bounded_by{}). The yuqk
fork only updates manual bounding based upon any bounded_by{} block(s)!
IIRC, using clipped_by{} to also manually bound was a v3.6 -> v3.7
change. In any case manual, bounding sometimes needs to be slightly
larger than any clipped_by{} specifications - we shouldn't be using
clipped_by{} to set or update bounding.
Bill P.
