POV-Ray : Newsgroups : povray.beta-test : v3.8b2. height_field input values at 0.0 not clean. Server Time
3 Mar 2026 01:16:17 EST (-0500)
  v3.8b2. height_field input values at 0.0 not clean. (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: v3.8b2. height_field input values at 0.0 not clean.
Date: 16 Feb 2023 07:30:22
Message: <63ee21de$1@news.povray.org>
On 2/15/23 08:15, William F Pokorny wrote:
> The HF zero (y as image/fnct evaluated) and z HF result should cleanly
> show up no matter scaling! At best it is today noisy.
:-) My first thoughts are so often mostly wrong...
The problem in this scene starts with a coincident surface! If the
height_field mesh is entirely at 0.0 in y, it is coincident with the
plane in the scene. Fix this issue and results are solid no matter the
scaling in y.
Note. Inbuilt Patterns especially often clamp to the [0-1] range due
numerical noise.
Bill P.
More detail
The coincident surface signature is different than I'm used to. Here it
is tangled with auto bounding in an odd way based on scaling in y. If I
turn bounding off with -mb, the cases which had previously disappeared
completely on larger or no scaling in y, are cleanly there - which is
also an odd coincident surface signature.
No bounding and the smaller scaling is more there and with a more
typical (to my eye's experience anyhow) coincident surface appearance.
I don't understand why scaling is affecting results as it is, but, I'm
not going to further chase this.
Date: 16 Feb 2023 18:50:00
Message: <web.63eebfb81428d28b9b4924336e066e29@news.povray.org>
On 2/15/23 05:34, William F Pokorny wrote:
[from a recent post in " Using a function in a height_field declaration" thread]
> Yes. Functions as used in height_fields never see called x,y values
> outside the [0-1] range.
> Forgot to plug a new povr function called f_boom() I believe should be
> in any v4.0 release.
> #include "functions.inc"
> #declare FnChkVals = function (x) {
>      select(((x<0.0) | (x>1.0)),
>          0,
>          0,
>          f_boom(x,2,3,4,5,6)
> height_field {
>   function 500, 500 { FnChkVals(y) }
> A little ugly in that it throws after printing six values, but it offers
> a quick way for 'users' to test values in functions. Above we're testing
> that y as seen in the HF called function is never outside the [0,1]
> range.
I've been taking a look at this and playing around with it in a modified way--
leaving out  f_boom(...) and changing some values so that the construct itself
will work for me...
I didn't #include "functions.inc", just...
#declare FnChkVals = function (y) {
         0,
         0.3,
         0.6 // instead of f_boom
height_field {
As a result, I get a nice 'planar' height_field at y=0.3... so at least that's
my own 'sanity check', and that I can make it work in a basic way ;-)
But there is something about your construct that puzzles me, as I do not use
'select' very much. The documentation says, "Select compares the first argument
with zero, depending on the outcome it will return B, C or D."
The way I see
is that it's basically a 'true/false' comparison(?) here. In other words, no
matter what the values of x might be, the result of the argument in parentheses
can only be a 'comparison against 0', by definition.
*If* that is the case, then the select() result can have only two states or
outcomes-- true or false (or 1 and zero). Which would then pick either argument
B or C, but never D(??) So, I am wondering if your f-boom macro will ever
actually be chosen by this select() set-up.
I assume that it *does* work for you, so I must have a misconception about
select() itself and how it operates here.
Date: 16 Feb 2023 19:00:00
Message: <web.63eec2c21428d28b9b4924336e066e29@news.povray.org>
Hmm. I think I muddied my question and my logic, sorry. I kind of mixed up what
happens in a 4-argument 'select' use.
But it would seem that only two of the three B-C-D select() results could be
chosen by your function, but not all three.
Date: 16 Feb 2023 20:00:00
Message: <web.63eed0b51428d28b1f9dae3025979125@news.povray.org>
> >          0,
> >          0,
> >          f_boom(x,2,3,4,5,6)
Kenneth, I use select all the time.
This is how it works:
select (N, -1, 0, 1)
When your comparison function gets evaluated, it returns a Boolean state (in
POV-Ray it's a 0 or a 1).
So what he's doing, is checking if x is less than 0 or greater than 1.
If it is, then the Boolean result is true, which in POV-Ray is 1.
If it's not, then the result is false, or zero.
The negative option in the select statement never gets used - it's just there to
force the select function to have a zero option that's separate from the 1
option, since a 3-term select statement is divided into 2 results:  negative or
>= 0.
I hope that helps.
Date: 17 Feb 2023 04:51:17
Message: <63ef4e15$1@news.povray.org>
Bill W (BE) explained well.
However, I'm going to re-state things because what showed up where I
have ???? characters above looks different on the web than what I see in
Thunderbird(a).
There are two forms of select(). The is a four term/argument version and
a three term version. The four term allows 'actions' for negative, zero
and positive input values. The three term one allows actions for
negative and (zero or positive) values.
I used the 4 term because I think it reads a little cleaner when setting
up a boolean test in the first term which can only return a zero or one
- the negative action is never used as Bill W said.
Aside: You can use the 3 term select depending upon a boolean result in
the first term test by doing something like:
select(1-(2*((x<0.0) | (x>1.0))), 0, 1)
I think this form less clear and, FWIW, it's slower than the four term
version.
Bill P.
(a) The leading '>' character got picked up as being an indication of
text from a previous post and is displaying as a vertical bar '|' in
Thunderbird.
Date: 17 Feb 2023 05:11:09
Message: <63ef52bd$1@news.povray.org>
Perhaps worth saying a little more than the above. Whether creating a
height_field or internal image_map from a function in POV-Ray, any
'function return' values outside the [0-1] get 'wrapped' to a ramp wave
as is the default with the majority of inbuilt patterns.
So, function return values of:
-0.1 --> 0.9
-0.5 --> 0.5
-0.9 --> 0.1.
1.1 --> 0.1
1.5 --> 0.5
1.9 --> 0.9
In other words, there is a jump or discontinuity when returning values
go negative or larger than 1. Further, there is no ability to to invoke
wave(a) modifiers as is true with the pattern mechanism.
Function based image_maps and height_fields all end up in a [0-1]
vertical/value range - even if your function itself returns values
outside that range.
Bill P.
(a) - The povr fork offers some wave modification capability via new
inbuilt functions like f_sine_wave().
Date: 17 Feb 2023 14:10:00
Message: <web.63efce3b1428d28b9b4924336e066e29@news.povray.org>
> Thunderbird(a).
No problem at my end; I see the correct syntax in the web portal.
Sorry for my longer-than-usual-delay in responding; I had to think hard about
this 'negative option being ignored' thing, and the difference between a 3-part
vs. 4-part select(). I was still thinking about it when I feel asleep last
night! William P's function construct makes better sense to me now; I finally
had the 'flashing insight'.
docs for the 4-part select:
When used with four parameters, if A < 0 it will return B. If A = 0 it will
return C. Else it will return D (A > 0).
I had to work out my own rather pedantic 'truth table' of sorts, as I see it --
hopefully corrected this time--
Given  ((x<0.0) | (x>1.0))  as the first argument 'A':
The boolean results in parentheses are only ever 0 or 1 (true or false).
if x is indeed less than 0.0 OR greater than 1.0, that produces boolean TRUE (or
1) in the parentheses. Compared against select's 'zero by definition' for A,  1
is 'greater than zero'.  So according to the rules, the outcome of select() will
be argument D-- the f_boom macro. Effectively, it doesn't matter if x exceeds
either limit; the result will be TRUE in either case.
If x is exactly 0.0  *or inside the given range*, the boolean operation in
parentheses produces FALSE (or 0). But, for select's argument A
comparison, 'zero equals zero' -- and argument C is chosen, which is 0.0 in
William P's code and 0.3 in mine.
So far, argument B is never chosen; C and D take care of every possible outcome
of    ((x<0.0) | (x>1.0))
HOWEVER, I see now that a simpler 3-part select() would not work when using
argument A as written-- because of the 3-part rules: Argument B is only chosen
when argument A is *less than* 0, which never occurs with  ((x<0.0) | (x>1.0))
Date: 17 Feb 2023 14:45:00
Message: <web.63efd8c11428d28b9b4924336e066e29@news.povray.org>
The boolean results in parentheses are only ever 0 or 1 (false or true).
Oops.  ;-)
Date: 17 Feb 2023 20:50:00
Message: <web.63f02e8f1428d28bc076587389db30a9@news.povray.org>
I agree..
How about just this:
select(
    -((x < 0.0) | (1.0 < x)),
    0,
    1
- or this:
select(
    -((0.0 <= x) & (x <= 1.0)),
    1,
    0
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 18 Feb 2023 05:40:25
Message: <63f0ab19$1@news.povray.org>
> select(
>      0,
>      1
> - or this:
> select(
>      1,
>      0
Very likely OK in practice, and cleaner in form than my three term select.
What spooks me some is that -0 and +0 are real things in the IEEE
floating point standard and as supported by C++. If a C++ coder has
thought to test for -0 < 0, they can.
Bill P.
