POV-Ray : Newsgroups : povray.beta-test : Technical verification build v3.8.0-beta.x.cmedit.669 - editor DLL changes Server Time
10 Jul 2026 14:38:50 EDT (-0400)
  Technical verification build v3.8.0-beta.x.cmedit.669 - editor DLL changes (Message 1 to 10 of 11)
Subject: Technical verification build v3.8.0-beta.x.cmedit.669 - editor DLL changes
Date: 29 Jun 2021 06:07:02
Message: <60daf0c6$1@news.povray.org>
Hi folks,
another not-quite-beta in our series of "let's not test POV-Ray itself,
but all the stuff that surrounds its compilation, deployment and
installation":
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.x.cmedit.669
This time, we would like you to test-drive an update to the editor DLL
mechanism:
(0) Make sure you have an existing POV-Ray v3.7 installation.
(1) Make sure to _uninstall_ any of the previous technical verification
builds. Most notably, make sure there are no editor DLLs left in the
`.../POV-Ray/v3.8-beta/bin` directory that might have somehow found
their way there.
(2) Install the version published at the URL above, _declining_ the
installer's offer to download the editor DLLs.
(3) Run the newly installed POV-Ray version, verifying that it offers
you to download the editor DLLs (_decline_ again), and that you can't
use the editor.
(4) Copy `povcmax32.dll` and `povcmax64.dll` (but _no_ other DLLs, not
even `povcmax32-sse2.dll`) from the `.../POV-Ray/v3.7/bin` directory of
your existing v3.7 installation into the corresponding directory of the
new installation.
(5) Run the newly installed POV-Ray version, verifying that it does
_not_ offer you to download the editor DLLs anymore, and that its editor
is now fully functional.
We would like your feedback...
- whether you do indeed see the expected behavior (and if not, what
divergent behavior you are seeing)
- what version of Windows you are using
- which of the three POV-Ray binaries is actually being run on your
system (32-bit, 32-bit SSE2 or 64-bit; see version information in the
Message Window)
Background:
Due to licensing issues, we previously distributed both the
`cmedit*.dll` and `povcmax*.dll` in an installer package separate form
the POV-Ray installer. However, this required us to provide new editor
installers for each new "generation" of POV-Ray that installed in a new
spearate directory (`v3.7-beta` vs. `v3.7` vs. `v3.8-beta`, and so on),
even though each time we only need to update `cmedit*.dll`, and even
though only `povcmax*.dll` is subject to those licensing issues.
There were reasons to do it this way, but we think we have managed to
find a way around those reasons. We now like to enlist your help to
confirm that this approach works for all versions of Windows that the
binaries are intended to support.
If it does indeed work as intended, we will distribute the `cmedit`
module in the main POV-Ray installer, and package only `povcmax*.dll` in
the separate editor installer, which can subsequently be left unchanged
for future versions. Furthermore, our plan is to have the POV-Ray
installer try to automatically "steal" those DLLs from an existing older
POV-Ray installation.
Happy testing!
Subject: Re: Technical verification build v3.8.0-beta.x.cmedit.669 - editor DLLchanges
Date: 30 Jun 2021 02:29:52
Message: <60dc0f60$1@news.povray.org>
Op 29/06/2021 om 12:07 schreef clipka:
> Hi folks,
> installation":
The update povwin-v3.8.0-beta.x.cmedit.669-setup.exe does not download
(correctly). I only get an empty file: 0 bytes. Using Win10.
Subject: Re: Technical verification build v3.8.0-beta.x.cmedit.669 - editorDLLchanges
Date: 30 Jun 2021 02:48:43
Message: <60dc13cb@news.povray.org>
Op 30/06/2021 om 08:29 schreef Thomas de Groot:
>> Hi folks,
>> itself, but all the stuff that surrounds its compilation, deployment
>> and installation":
OK. Skip that. Firefox blocked the download.
Date: 30 Jun 2021 02:59:35
Message: <60dc1657@news.povray.org>
> Hi folks,
> installation":
> mechanism:
OK
> their way there.
OK
OK
> use the editor.
OK
> new installation.
OK
(Some extra grumbling about admins rights)
OK
Initially a bit of confusion coming from protesting Firefox and admin,
but finally worked as expected.
Windows 10
> Message Window)
64-bit (as expected)
> Happy testing!
> Christoph
You are welcome.
Subject: Re: Technical verification build v3.8.0-beta.x.cmedit.669 -editorDLLchanges
Date: 30 Jun 2021 03:00:55
Message: <60dc16a7$1@news.povray.org>
Am 30.06.2021 um 08:48 schrieb Thomas de Groot:
Did FF give any particular reason for that? And how did you get past it?
Date: 30 Jun 2021 03:06:08
Message: <60dc17e0$1@news.povray.org>
Am 30.06.2021 um 08:59 schrieb Thomas de Groot:
>> of your existing v3.7 installation into the corresponding directory of
>> the new installation.
> OK
Something along the lines of, "to copy any stuff into this directory,
you need admin rights; do you think you deserve those rights (Yes/No)?",
I presume?
As you probably guessed already, that's perfectly normal at that step.
Thanks for testing.
Subject: Re: Technical verification build v3.8.0-beta.x.cmedit.669-editorDLLchanges
Date: 30 Jun 2021 04:06:03
Message: <60dc25eb$1@news.povray.org>
Op 30-6-2021 om 09:00 schreef clipka:
>>> download (correctly). I only get an empty file: 0 bytes. Using Win10.
To tell the truth, I am a bit mystified. It happened on my other laptop
(not the present one I am using) and apparently there is there an
extension/add-on there which 'controls' the downloads. Very first time I
got an action from it by the way. I need to go back there and see what
it is exactly; it does not reside on the present laptop and I cannot
find it (rapid browse) in the Firefox add-ons or extensions.
Anyway, when I found out it blocked the download, I could tell it to
download anyway, and it did.
I shall come back later on this when I find out the truth. ;-)
Date: 30 Jun 2021 04:08:35
Message: <60dc2683@news.povray.org>
Op 30-6-2021 om 09:06 schreef clipka:
>>> not even `povcmax32-sse2.dll`) from the `.../POV-Ray/v3.7/bin`
>>> directory of your existing v3.7 installation into the corresponding
>>> directory of the new installation.
>> OK
> I presume?
Yes, that was the message.
> Thanks for testing.
Happy to be of service :-)
Subject: Re: Technical verification buildv3.8.0-beta.x.cmedit.669-editorDLLchanges
Date: 30 Jun 2021 05:11:40
Message: <60dc354c$1@news.povray.org>
Op 30-6-2021 om 10:06 schreef Thomas de Groot:
In Firefox, when downloading a file, you get an icon in the toolbar saying:
"Display the progress of ongoing downloads (Ctrl+J)"
In the present case, download was interrupted with the message:
"This file is not commonly downloaded"
and you can go to a menu with explanation about safety and viruses, and
the possibility to go on downloading or delete the file.
First time I experienced this.
Subject: Re: Technical verificationbuildv3.8.0-beta.x.cmedit.669-editorDLLchanges
Date: 30 Jun 2021 07:09:24
Message: <60dc50e4$1@news.povray.org>
Am 30.06.2021 um 11:11 schrieb Thomas de Groot:
Ah! Yes, that makes sense. It _is_ indeed a file that is not commonly
downloaded. An unsigned executable, none the less. So a download filter
has every reason to have some level of mistrust.
