POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-x.freetype.4 Server Time
9 Dec 2025 12:31:53 EST (-0500)
  POV-Ray v3.8.0-x.freetype.4 (Message 1 to 10 of 10)
Subject: POV-Ray v3.8.0-x.freetype.4
Date: 7 Jun 2021 10:22:09
Message: <60be2b91$1@news.povray.org>
This is pretty much the same as the alpha just published, but with the
new `text` handling.
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-x.freetype.4
Differences to the Alpha:
- `text` now supports TrueType-, PostScript- amd OpenType fonts. For
now, the syntax remains unchanged, including the `ttf` keyword; the font
format is detected automagically.
- Fonts installed in the system can be accessed directly by replacing
`ttf FILENAME` with `sys FONTNAME`, optionally followed by `bold` and/or
`talic`; e.g. `text { sys "Arial" bold ... }`. (Windows version only for
now)
- `text` objects now render a bit faster.
Known caveats:
- Glyph positions may be slightly different. This is not a bug but a
feature, as the old code's glyph positioning algorithm wasn't quite right.
- Needs FreeType 2 on Unix, otherwise `text` primitive will be disabled
entirely. (Comes bundled with FreeType 2 source code for Windows builds.)
- The `internal NUMBER` mechanism for accessing fonts is currently
restricted to the `timrom.ttf` font.
Differences to `v3.8.0-x.freetype.3`:
- `text` object performance restored, and even improved. (Turns out the
previous versions wasted time rendering whitespace, of all things.)
- Based on latest Alpha.
Have fun testing!
Subject: Re: POV-Ray v3.8.0-x.freetype.4
Date: 7 Jun 2021 10:45:17
Message: <60be30fd$1@news.povray.org>
Op 7-6-2021 om 16:22 schreef clipka:
Thank you indeed.
Date: 8 Jun 2021 14:48:04
Message: <60bfbb64$1@news.povray.org>
> now)
> Known caveats:
> Have fun testing!
checking whether to use the FreeType library... yes
checking for pkg-config... (cached) pkg-config
checking for FreeType's include path... -I/usr/include/freetype2
checking for library containing FT_Init_FreeType... -lfreetype
checking ft2build.h usability... yes
checking ft2build.h presence... yes
checking for ft2build.h... yes
checking for libfreetype version >= 2.4.0... 2.10.1, ok
that last version check seems odd... i'm at 2.10.1 but it passed, and
built properly. no testing yet... time for an espresso
Date: 8 Jun 2021 20:33:09
Message: <60c00c45$1@news.povray.org>
Am 08.06.2021 um 20:48 schrieb Ash Holsenback:
Why, yes, of course.
Remember that the actual version "2.10.1" is _not_ "two one zero one",
but "two ten one".
Which is greater-or-equal to the required version "2.4.0", which is "two
four zero".
Date: 8 Jun 2021 20:43:31
Message: <60c00eb3$1@news.povray.org>
> but "two ten one".
> four zero".
lol... gotcha. old eye's saw 1 not 10 for some reason. there's a couple
of ironies there that i won't even get into
Date: 8 Jun 2021 23:17:48
Message: <60c032dc$1@news.povray.org>
Related too, to the recent developer emails...
I want to say in a public forum - what would help folks like me most is
an official release of v3.8 more or less exactly (with fixes) as it
stood when you went on a walk-about years back Christoph!
Why did Tor Olav back out the use of your terrific v3.8 tuple SDL
enhancement in his vectors.inc documentation? Because, he has to write
examples to work with v3.7 for 'most' users.
Those of us wanting to make use of the substantial improvements made in
v3.8 had no choice - after waiting around for a long time - but to treat
your last v3.8 commit as an effective release. I've now got a mountain
of stuff written against your last v3.8 commit. This is what it is.
To the degree you and other core developers 'move' the eventual v3.8
release to be some cool newer, great 'thing,' - you, Chris and whoever
else deciding - will be screwing those of us long exploiting v3.8
features, over. I'm now way off in the weeds with source code, scenes
and include files written mostly against how v3.8 master has now stood
for YEARS.
If v3.8 gets released more or less as is - especially with respect to
the parser and vm - it will be something like what v3.7 has been for the
next 5-10 years. It'll be the stable release 'most' people run. Some of
my play might still be of use to the POV-Ray community working around
such a stable v3.8 release.
Plus! I'll be motivated to work on maintenance fixes to the then newer
v3.8 stable branch as to some degree I'll need to to keep v3.8 compiling
too. :-)
I'm not now much motivated to play or chase any later and greater
'official' POV-Ray releases as I was doing for a long time. I'm sorry.
I'm old. I have ideas with which I want to play - I made the decision to
to break on v3.8 where it stalled.
Bill P.
Aside: I say all the above actually sort of wanting the freetype
improvements... It's cool, worthwhile work. I understand too, I'm not a
typical user.
Date: 9 Jun 2021 02:28:37
Message: <60c05f95$1@news.povray.org>
clipka wrote on 07/06/2021 16:22:
Thank you, Clipka!
Paolo
Date: 9 Jun 2021 06:52:00
Message: <60c09d50$1@news.povray.org>
Am 09.06.2021 um 05:17 schrieb William F Pokorny:
The status quo of the parser is halfway between here and there, so
especially with respect to the parser, releasing "as-is" won't be an option.
However, see the latest dev newsletter on this issue for the direction
things are going to head. I guess it's effectively what you are asking for.
> typical user.
Just to be clear: Those two recent releases don't bring any new
features. They just introduce some fixes to the alpha development
branch, and the experimental FreeType branch, respectively.
Frankly, they're more the result of me checking whether all our tools
still work as they should than anything else. That, and me wanting to
make a statement that POV-Ray development has officially been restarted.
Date: 18 Jun 2021 16:43:32
Message: <60cd0574$1@news.povray.org>
I'm curious, but will POV be able to render LaTeX? Or will it still be
better to convert LaTeX to SVG, and then use Inkscape to generate the
POV code from the SVG?
Mike
Date: 18 Jun 2021 17:47:51
Message: <60cd1487$1@news.povray.org>
Am 18.06.2021 um 22:43 schrieb Mike Horvath:
What?
I don't really see the connection between support for other font
formats, and support for a complete (and complex) text document format.
Also, why specifically LaTeX? Why not EPS? RTF? PDF? ODF? DOCX? HTML?
I'll go out on a limb here and predict that POV-Ray will never be able
to render any of these document formats. Not unless you write a suite of
macros to do the job.
"Dammit Jim, I'm a 3D renderer, not a typesetting engine!"
   -- POV-Ray
