POV-Ray : Newsgroups : povray.beta-test : 3.8 and text {} Server Time
13 Feb 2026 05:37:45 EST (-0500)
  3.8 and text {} (Message 1 to 10 of 18)
Subject: 3.8 and text {}
Date: 12 Nov 2019 21:05:42
Message: <5dcb64f6$1@news.povray.org>
I upgraded to the '268 version and noticed tonight,
Possible Parse Error: Text may not be displayed as expected. Please
refer to the user manual regarding changes in POV-Ray v3.8 and later.
Can someone point me to the docs for this?
The warning hits on the first 't' in 'text' in this construct I've used
for decades:
text {
	ttf ArialFont
	label
	0.23,0
	scale 0.02
	translate <-0.080*inches, 0.088*inches, -0.001*inches>
	texture {controlTextureOn}
dik
Rendered 23,533,286,400 of 40,928,716,800 pixels (57%)
Subject: Re: 3.8 and text {}
Date: 12 Nov 2019 22:00:01
Message: <web.5dcb718b60166f6f4eec112d0@news.povray.org>
The best I could find for this so far were these:
http://news.povray.org/povray.general/thread/%3C5c38071f%241%40news.povray.org%3E/
https://news.povray.org/povray.beta-test/thread/%3C5c2e6746%40news.povray.org%3E/
http://news.povray.org/povray.beta-test/thread/%3C5b17006b%241%40news.povray.org%3E/
I remember there was a lot of stuff going on trying to fix the long-standing
utf-8 bug.
Maybe use that as a hook?   Check bug reports? Flyspray, git, readme, ....
Or just stop breaking POV-Ray.   :D
Date: 13 Nov 2019 02:30:54
Message: <5dcbb12e$1@news.povray.org>
Op 13/11/2019 om 03:05 schreef Dick Balaska:
> for decades:
> text {
>      ttf ArialFont
>      label
>      0.23,0
>      scale 0.02
I am not often using text, so I am probably wrong, but comparing to the
wiki: http://wiki.povray.org/content/Reference:Text  I miss the double
quotes. Shouldn't one write: ttf ""ArialFont.ttf" "label"  ?
Date: 13 Nov 2019 02:32:48
Message: <5dcbb1a0@news.povray.org>
> for decades:
> text {
>      ttf ArialFont
>      label
>      0.23,0
>      scale 0.02
quotes. Shouldn't one write: ttf "ArialFont.ttf" "label"  ?
Date: 13 Nov 2019 07:10:04
Message: <web.5dcbf19260166f6f4eec112d0@news.povray.org>
Good catch - I read right through that, as "I've been using it for decades"
makes me assume it's not the issue, and so I jump past the surface to something
deeper.
The syntax is:
TEXT_OBECT:
  text {
    ttf "fontname.ttf/ttc" "String_of_Text"
    Thickness, <Offset>
    [OBJECT_MODIFIERS...]
Where fontname.ttf or fontname.ttc is the name of the TrueType font file. It is
a quoted string literal or string expression.
Maybe POV-Ray thinks that ArialFont is a string expression - an identifier - and
burps when it's not defined the way it thinks it should be?
Who knows what dark magic lurks in the Balaska scene files...
Date: 13 Nov 2019 09:21:44
Message: <5dcc1178$1@news.povray.org>
> utf-8 bug.
Thanks much for those!
I was off minecrafting last January or I would have chimed in about
"multiple engines with one gui". (I always wanted to wrap hgpovray with
my gui.)
Looking at the povray source code, the solution is to change all of my
files to
#version 3.8;
and leave my text {} objects exactly as they are.
On 11/13/19 7:05 AM, Bald Eagle wrote:>
decades"
something
 > deeper.
It is double quoted. My bad for not including the defines in my original
snippet.  I thought it would clutter.
#declare TtRootDir="../"; // because I'm in a subdir
#declare TtCommonDir=concat(TtRootDir, "ttCommon/");
#declare ArialFont=concat(TtCommonDir, "arial.ttf");
equals
     text {
         ttf "../ttCommon/arial.ttf"
dik
Rendered 23,657,702,400 of 40,928,716,800 pixels (57%)
Subject: Hello darkness (was Re: 3.8 and text {})
Date: 14 Nov 2019 02:27:40
Message: <5dcd01ec$1@news.povray.org>
> files to
> #version 3.8;
Well poo.
Changing my SDL from #version 3.7 to 3.8 causes the image to be much darker.
I can't do that.  I'd have to re-render 6 months worth of frames.
(and the annoying not-an-error "possible error" comes through as a
"mGenericStatus" message (normally the 'Rendered 10 of 20 pixels (50%)'
messages) so it shows up in the povwin status bar.  This confuses my
renderfarm progress bars, which resize bigly to display the message that
shouldn't even be there.)
dik
Rendered 23,734,425,600 of 40,928,716,800 pixels (57%)
Subject: Re: Hello darkness (was Re: 3.8 and text {})
Date: 14 Nov 2019 07:00:00
Message: <web.5dcd41b7bf609be64eec112d0@news.povray.org>
Isn't there a message pane switch that can be toggled to shut things like that
off?
Date: 14 Nov 2019 07:10:01
Message: <web.5dcd4322bf609be64eec112d0@news.povray.org>
> off?
http://wiki.povray.org/content/Reference:Text_Output_Options#Text_Streams
Date: 14 Nov 2019 07:26:39
Message: <5dcd47ff$1@news.povray.org>
>> files to
>> #version 3.8;
> Well poo.
> darker.
One of the changes 3.7 to 3.8 was to take the default ambient to 0.0.
It's a funky color adder disconnected from gamma handling, and at 0.1,
it tends to brink near blacks way up in intensity with AG 1.0 - washing
out the contrast in the images. Your 1.7 AG is already compensating for
this effect to a large degree.
Have you tried changing the default ambient back to 0.1 when changing
your version to 3.8?
Bill P.
