POV-Ray : Newsgroups : povray.beta-test : Dictionary 'reassign' Server Time
14 Jul 2026 01:57:49 EDT (-0400)
  Dictionary 'reassign' (Message 1 to 8 of 8)
Subject: Dictionary 'reassign'
Date: 4 Dec 2018 10:59:01
Message: <XnsA9AEACC41A9B2seed7@news.povray.org>
Don't know the proper word for what I do, but the code below fails. Should
it? Can it be made not to fail?
#declare T = dictionary {
  ["Index"] : array[2]{"Base1", "Base2"},
  ["Base1"] : <1,2,3>,
  ["Base2"] : <0,1,2>
#declare Chain = T["Index"][0];
#declare Vec = T.Chain;
Parse Error: Cannot pass uninitialized identifier to non-optional LValue.
ingo
Subject: Re: Dictionary 'reassign'
Date: 4 Dec 2018 14:20:01
Message: <web.5c06d2c1a98f76e2e43b71790@news.povray.org>
hi,
>   ["Base2"] : <0,1,2>
I don't suppose "the other way round" is any good to you?  eg:
#version 3.8;
global_settings {assumed_gamma 1}
  .base0 : 0,
  .base1 : 1,
  .base2 : 2,
  .vecs : array {<1,2,3>,<0,1,2>,<4,5,6>}
#debug concat("2)  <",vstr(3,T.vecs[T.base2],",",0,0),">.\n")
regards, jr.
Date: 4 Dec 2018 15:16:01
Message: <XnsA9AED85707CE3seed7@news.povray.org>
>   .base0 : 0,
>   .base1 : 1,
>   .base2 : 2,
I'll have to reorient my brain for that, but I'll have a try. It may
work for a few things but probably not for the the more complex
structures I have.
#declare Fabrik = dictionary{
    // Processing order
    ["Proc"]  : array[4]{"Left", "Right", "LRB" ,"Base"},
    //Chain named 'Base'
    ["Base"]  : dictionary{
        ["Type"]      : "BaseSubbase",
        ["Joint"]     : array[4]{<0,0,0>, < 0,1,0>, < 0,2,0>, < 0,3,0>},
        ["Constraint"]: array[4]{false, object{}, false, false},
        ["Centroid"]  : array[1]{"LRB"}
    ["Left"]  : dictionary{
        ["Type"]      : "SubbaseEnd"
        ["Joint"]     : array[4]{<0,3,0>, <-1,4,0>, <-2,5,0>, <-3,6,0>},
    ["Right"] : dictionary{
        ["Joint"]     : array[4]{<0,3,0>, < 1,4,0>, < 2,5,0>, < 3,6,0>},
    ["LRB"]   : dictionary{
        ["Type"]      : "Centroid"
        ["Index"]     : array[3]{"Left", "Right", "Base"},
        ["Centroid"]  : dictionary{
            ["Left"]      : 0,
            ["Right"]     : 0,
            ["Base"]      : 3
Thanks,
ingo
Date: 4 Dec 2018 16:55:00
Message: <web.5c06f675a98f76e2e43b71790@news.povray.org>
hi,
> structures I have.
I kept this onscreen for a while -- pretty awe-inspiring.  :-)
I also had a (very) cursory look at the pdf documenting the FABRIK algorithm.
given all that I'm thinking -- were I in your shoes -- I'd like to get a level
of abstraction between self and the details.  so, perhaps a "tree.inc", a set of
macros which implement the exact needed subset of
en.wikipedia.org/wiki/Tree_(data_structure)#Common_operations.  if nothing else,
it would reduce the amount of implementation detail I'd need to deal with.
anyway, if you want someone to test some code etc, feel free to write.
regards, jr.
Date: 4 Dec 2018 17:45:00
Message: <web.5c07026fa98f76e2e43b71790@news.povray.org>
hi,
>   ["Base2"] : <0,1,2>
heh, turns out there is a way (thanks to the Kenneth + clipka exchange :-))
#version 3.8;
#include "strings.inc"
  ["Base2"] : <0,1,2>
#declare Chain = T["Index"][1];
#declare Vec = Parse_String(concat("T.",Chain));
#debug concat("Vec: <",vstr(3,Vec,",",0,0),">\n")
regards, jr.
Date: 4 Dec 2018 23:14:57
Message: <5c0750c1$1@news.povray.org>
Am 04.12.2018 um 16:59 schrieb ingo:
>    ["Base2"] : <0,1,2>
`T.Chain` is shorthand for `T["Chain"]`. You don't have a key "Chain" in
your dictionary.
What you want is
    #declare Vec = T[Chain];
Notice the use of square brackets without quotes. This tells POV-Ray
that the key to use is the content of the variable `Chain`.
Date: 5 Dec 2018 01:40:51
Message: <XnsA9AF4E22035EBseed7@news.povray.org>
>> Should it? Can it be made not to fail?
>>    ["Base2"] : <0,1,2>
>> LValue.
> in your dictionary.
> What you want is
Ah, the result of T["Index"][0] is a string, so why quote it again.
Being a bit blind sometimes.
Thanks,
ingo
Date: 5 Dec 2018 01:47:04
Message: <XnsA9AF4F30EB662seed7@news.povray.org>
Thanks for the link, I'll look into it.
The Farbrik algorithem is not that complex, but setting the whole thing up
in a general way makes it a bit complicated. With the use of nested dicts
and a bit of OOPishness it's doable I think.
ingo
