POV-Ray : Newsgroups : povray.beta-test : Restructured Parser wants Testing Server Time
6 Jun 2026 21:27:35 EDT (-0400)
  Restructured Parser wants Testing (Message 30 to 39 of 59)
Subject: Re: Restructured Parser wants Testing
Date: 23 May 2018 15:55:19
Message: <5b05c727$1@news.povray.org>
On 23/05/2018 19:05, clipka wrote:
> Am 23.05.2018 um 19:31 schrieb Stephen:
>>>> Sorry it does not use macros. It did but I de-constructed the grass
>>>> macro it was using as it was declaring an array of meshes from within a
>>>> while loop. [Watch the memory usage rise and the HDD thrash.]
>>> Hmm... then that begs the question, which change between v3.7.0 and
>>> v3.8.0-alpha would have improved parsing speed?
>> You mean it is not deliberate? o_O
> I don't recall having done anything to the parser between v3.7.0 and
> v3.8.0-alpha with the intent to speed up parsing in general, with the
> sole exception of macro caching. I hate the code, so it has never gotten
> much love & care from me ;)
> There /may/ have been side effects from a bit of code cleanup here and
> there. But usually I've just given the parser more jobs to do.
So Bill says. ;)
>>> Besides, what loop size are we talking about? Would that happen to be
>>>> 64k characters in the loop body?
>> I am not too sure I understand.
>> The loop size depends on the size of the target heightfield and the
>> required density of the grass.
> I mean the raw number of characters in the scene (or include) file, from
> the `#while` or `#for` to the corresponding `#end`.
> For example, the body of the following loop is 31 characters long:
>      #for(I,0,100) #debug "Another iteration.\n" #end
That is how I read it.
Including tabs. Word counts 399 characters
>> I thought you might ask for a copy and started to look at how many image
>> maps it was using.
>> It seems that when I was modifying the file manually I forgot to remove
>> a couple of flower meshes. I had used in B3D. I cleaned it up and it is
>> only 13500 lines now. And one heightfield image.
>> If you still want a copy. I will post it.
> Please go ahead. I'm curious which feature of the file makes
> v3.8.0-alpha like it better than v3.7.0.
Done.
Posted in povray.binaries.scene-files as "Flowers for clipka"
Regards
Date: 23 May 2018 16:00:22
Message: <5b05c856$1@news.povray.org>
New version:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-x.tokenizer.9673626
Cached macros back in action.
Also includes an optimization that may reclaim some lost performance in
loops.
Date: 23 May 2018 16:08:04
Message: <5b05ca24$1@news.povray.org>
On 23/05/2018 18:51, clipka wrote:
> Am 23.05.2018 um 18:53 schrieb Stephen:
>>>> Which reminds me. I use that facility to overwrite the version number
>>>> B3D exports by declaring it after the first one. Will that workaround
>>>> still work?
>>> Uh... please elaborate. How would the resulting scene file look like?
>> #version 3.6;
>> //------- Scene Raw Script Begin -------
>> #version 3.7 ;
>> //------- Scene Raw Script End ---------
>> [The rest of the scene...]
> If `#version 3.6;` is the very first statement in the scene, then that's
> fine.(*)
> If there's anything before that (other than whitespace and/or comments),
> it is still fine unless you replace `#version 3.7;` with `#version 3.8;`.
> (* In the sense that you won't get a parse error. It may have side
> effects, e.g. the new v3.8 default values currently don't apply unless
> you specify `#version 3.8` at the very first line. I intend to change
> that though.)
Thanks for clearing that up for me.
I seem to remember a warning that the version number must be the first
statement and thought it might mean the final version number.
Regards
Date: 23 May 2018 16:16:06
Message: <5b05cc06$1@news.povray.org>
On 23/05/2018 18:55, clipka wrote:
> Am 23.05.2018 um 19:35 schrieb Stephen:
>> On 23/05/2018 16:26, clipka wrote:
>>> Not sure I understand what you mean. Would you change B3D, or would you
>>> change POV-Ray?
>> Sorry I missed this.
>> B3D comes compiled with no source code. So for that to work it would
>> need be a change in PovRay.
> Then such a switch would add more trouble than it would solve.
I must be over thinking. :)
> I'll try to re-implement v3.8.0-alpha behaviour, which is to provide
> special treatment for filename literals if `#version 3.7` or earlier is
> specified, while treating them like regular string literals if `#version
> 3.8` or later is specified.
Great! That means that I can use 3.7 for testing and manually change the
file when I want to use 3.8.
> In either case, a warning shall be printed if single backslashes are
> encountered in filename literals.
> ("filename literal" being any string literal in a place where the parser
> specifically expects a file name, such as in `#include`.)
Another thought. (Don't judge me. ;) )
What about the library paths defined in povray.ini?
Regards
Date: 23 May 2018 16:33:34
Message: <5b05d01e$1@news.povray.org>
Am 23.05.2018 um 22:16 schrieb Stephen:
Totally different story: Those don't go through the scanner/tokenizer,
so they are entirely unaffected by any change made to those parser
stages with regards to escape sequences.
Date: 23 May 2018 16:55:01
Message: <web.5b05d41c6ca3c278a47873e10@news.povray.org>
> New version:
Using my 'city buildings' scene again...
v3.7.0-- 35.54 seconds
v3.8 tokenizer-- 34.2 seconds (average of five runs)
(both versions running 'hot', as described earlier)
Date: 23 May 2018 17:07:18
Message: <5b05d806$1@news.povray.org>
Am 23.05.2018 um 21:55 schrieb Stephen:
> Done.
I think I nailed it: On my system I get just shy of 300 seconds parsing
time on v3.7.0, a bit over 200 seconds on v3.8.0-alpha, and a bit shy of
200 seconds on v3.8.0-x.tokenizer.9673626 now.
Didn't bother to test with v3.8.0-x.tokenizer.9999, as I would have had
to "rewind" to old source code, but I'm satisfied with having a
reasonably plausible theory as to why it may have been slower.
Date: 23 May 2018 17:58:17
Message: <5b05e3f9$1@news.povray.org>
>> Done.
Excellent!
I'll download the new version you posted, tomorrow and rerun the scene.
BTW The scene I uploaded had twice the density of grass blades (10000)
than the one I used originally to test them (5000).
Regards
Date: 24 May 2018 02:15:15
Message: <5b065873$1@news.povray.org>
I imagine that would be the case. I was thinking more of consistency in
the windoze environment.
Regards
Date: 24 May 2018 02:36:41
Message: <5b065d79$1@news.povray.org>
On 23-5-2018 14:20, clipka wrote:
> Am 23.05.2018 um 08:54 schrieb Thomas de Groot:
>> Where the longer parse time comes from is in the while loop distributing
>> the cubes. This loop resides in a separate inc file. and looks like this:
[snip]             ^^^^^^^^^^^^
> Unless you copied that to your file with the loop, that's a macro in a
> different file...
[snip]
> So yes, that pretty much explains the poor performance with the
> overhauled parser -- or, more to the point, the better performance with
> v3.8.0-alpha: The latter features cached macros, while the overhauled
> parser currently has those disabled.
> I would expect v3.7.0 to show roughly similar performance as the
> overhauled parser.
Of course. I forgot about this. With version 3.7.0 the performance is as
you say. Better performance starting with 3.7.1 according to my test.
