POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.9322209 Server Time
16 Jun 2024 18:22:53 EDT (-0400)
  POV-Ray v3.8.0-alpha.9322209 (Message 25 to 34 of 34)
Subject: Re: POV-Ray v3.8.0-alpha.9322209
Date: 1 Oct 2017 04:13:36
Message: <59d0a3b0@news.povray.org>
Am 01.10.2017 um 02:07 schrieb Jim Holsenback:
> On 9/21/2017 3:10 PM, clipka wrote:
>> Be advised that this binary-only release wants to reside in an existing
>> v3.7.x installation.
> nix is working oh-key-dokey fine however doze has an issue ... binary in
> v3.7.1 install directory but help buttons for POV-Win and Scene aren't
> working
Yes, that's a known issue: v3.8 can't load the v3.7 help file.
To work around this, download the help file directly from the
`release/v3.8.0` branch, and copy it into the v3.7 install's `help`
directory.
Date: 2 Oct 2017 05:20:05
Message: <59d204c5$1@news.povray.org>
>> working
> directory.
copied as is and when that didn't work went through several renaming
incantations with no joy
Date: 2 Oct 2017 08:31:49
Message: <59d231b5@news.povray.org>
Am 02.10.2017 um 11:20 schrieb Jim Holsenback:
>>> working
>> directory.
Presuming your v3.7 installation and the v3.8.0-alpha binary reside in
`C:\Program Files\POV-Ray\v3.7`, then the v3.8 help file
(`distribution\platform-specific\windows\Help\povray.chm` in the repo)
should work fine when dropped in as `C:\Program
Files\POV-Ray\v3.7\help\povray.chm`.
Note that v3.8.0-alpha always looks for its help file in your v3.7
(release proper, i.e. v3.7.0, or RC, i.e. v3.7.1-rc.1) installation
directory tree, regardless of where you place the v3.8.0-alpha binary.
Most notably, if you accidently placed the v3.8.0-alpha binary in a
v3.7-beta installation (e.g. v3.7.1-beta.9), it will still try to load
the help file from wherever your v3.7 proper installation resides.
Also note that the help file must be named `povray.chm` (as in the
`release/v3.8.0` branch), /not/ `povray37.chm` (as still in the master
branch, IIRC).
Date: 4 Oct 2017 08:20:41
Message: <59d4d219$1@news.povray.org>
> branch, IIRC).
well i uninstalled 3.7.1 beta and put the pvengine64 into my remaining
3.7.0 bin directory and povray.chm into help directory. now the help
buttons work but all i get is the left pane and none of the links are
clickable ... not that big of an issue for /me/ because i prefer the
html version
Date: 4 Oct 2017 11:00:11
Message: <59d4f77b$1@news.povray.org>
Am 04.10.2017 um 14:20 schrieb Jim Holsenback:
> html version
Now that's odd... can anyone confirm?
Date: 4 Oct 2017 14:55:01
Message: <web.59d52dbad1757457a1bbc3890@news.povray.org>
> > html version
Same thing here. Before I was going to say anything I was trying a few things to
see if I could get it to work, such as trying to default to Internet Explorer
rather than Windows 10 Edge.
I used the direct link to the Help file you provided, although I had gotten that
file from github before that and it was the same way but there were two
different byte sizes for the files.
Install directory is actually 3.7.0, not just 3.7 so I can only wonder if that
has anything to do with this.
Date: 4 Oct 2017 18:55:01
Message: <web.59d5663ed17574579c5d6c810@news.povray.org>
> > > html version
Have now tried something else. Right-click on povray.chm and go into Properties.
Under General tab is checkbox "unblock". That was a suggested fix I found on the
'net about these chm help files.
Get message when attempting that: "Too many posts were made to semaphore".
When button for Ignore is pressed, or Ignore All, nothing changes regarding
empty contents of the help file when opened next time.
Maybe this will make sense, all I know about it is what I find on the 'net and I
guess this is supposed to be about multiple calls to places within the file
going wrong somehow.
Date: 4 Oct 2017 19:10:01
Message: <web.59d56929d17574579c5d6c810@news.povray.org>
Okay, Speaking of Ignore... please disregard my previous reply below.
See if you can right-click on the povray.chm file and in Properties, on the
General tab, check the box for Unblock.
Don't Ignore or Ignore All, and instead use Try Again (if same is seen on your
Windows system), then maybe the Administrator message will pop up and you can
let that get you through this like I did.
My Help contents now appear intact. Of course, I haven't looked at it all yet
but the context help seems to be okay now (selecting a keyword and pressing F1
key) and the menu buttons for POV-Win and Scene Help show up for me after doing
the above.
> > > > html version
Date: 4 Oct 2017 20:51:27
Message: <59d5820f$1@news.povray.org>
Am 05.10.2017 um 01:05 schrieb omniverse:
> the above.
Sounds to me like the help file viewer doesn't like it when the .chm
file is flagged as "downloaded from the internet and hence potentially
unsafe".
Since this won't be a problem once we create an installer, I tend to
consider this a non-issue.
Date: 5 Oct 2017 06:27:56
Message: <59d6092c$1@news.povray.org>
thanks ... works now
