POV-Ray : Newsgroups : povray.beta-test : POV-Ray 3.7.1 Release Candidate 1 ready for testing Server Time
16 Feb 2026 01:20:50 EST (-0500)
  POV-Ray 3.7.1 Release Candidate 1 ready for testing (Message 1 to 10 of 10)
Subject: POV-Ray 3.7.1 Release Candidate 1 ready for testing
Date: 23 Jun 2017 16:17:31
Message: <594d775b$1@news.povray.org>
Hi folks,
The first Release Candidate of v3.7.1 is now available on GitHub:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-rc.1
**IMPORTANT NOTE:** In contrast to the betas, the Windows version of the
release candidate does NOT make any attempt to co-exist with v3.7.0. If
you intend to keep v3.7.0 around, make sure to back up the binaries, or
install v3.7.1 in a different location. You may also want to back up the
include files first. Also, there is no way to prevent the installations
from sharing most settings.
Happy testing!
Subject: Re: POV-Ray 3.7.1 Release Candidate 1 ready for testing
Date: 25 Jun 2017 00:31:16
Message: <594f3c94$1@news.povray.org>
I am an active Object Collection contributor, and I test my modules
across different POV-Ray versions.  Some differences between v3.7.0 and
v3.7.1 are significant enough that I wish to keep v3.7.0 around.
Regarding the Unix version, I did *not* take your earlier suggestion to
run the configure script with the --prefix= parameter.  (See "Peaceful
coexistence between 3.7.0 and 3.7.1" in p.t.tutorials.)  I understand
this to mean that my beta installs have already been storing data where
v3.7.0 looks for them.  (I've already noticed the changes in the user
manual.)  Does this mean that the hack I used to keep both versions
coexisting should continue to work?
Done.  So far, the only incompatibility I've noticed is with ior.inc.
Theoretically, I have no worries there, but I have yet to address your
response to my troubles with INI files.
Date: 25 Jun 2017 05:19:47
Message: <594f8033$1@news.povray.org>
Am 25.06.2017 um 06:31 schrieb Cousin Ricky:
I think the cleanest way to accomplish this is to just back up the 3.7.0
binaries, install 3.7.1, and copy the 3.7.0 binaries back in under a
different name.
You may also need to apply your 3.7.0 `ior.inc` workaround.
To the best of my knowledge, the Unix beta did not install in a separate
directory (as opposed to the Windows beta), so whatever you did on Unix
to keep 3.7.0 and 3.7.1-beta separate should also work for the 3.7.1-rc
and later the 3.7.1 final.
Date: 25 Jun 2017 05:24:58
Message: <594f816a@news.povray.org>
BTW, what differences are we talking about there?
Date: 25 Jun 2017 10:42:09
Message: <594fcbc1@news.povray.org>
I have a module in the works that tests for inverse square light
attenuation.
There is also the elimination of the torus spindle artifact, although I
already had a workaround for that and haven't decided whether it's worth
the version sniffing just to take advantage of this feature.
But in general, many of the bug fixes and numerous enhancements to v3.7
have the /potential/ for requiring testing or version sniffing.  This is
quite different from the upgrades to v3.6.  I do not even remember what
the difference was between v3.6.0 and v3.6.1, and of course v3.6.2 was a
Windows-specific change that had no bearing on renders.
Date: 26 Jun 2017 08:34:19
Message: <5950ff4b@news.povray.org>
I am currently using the following method to maintain multiple versions
of POV-Ray on Ubuntu linux for similar testing and support reasons.
I create a tmpUser directory in my own space. Within this directory I
currently have sub-directories called MyP370, MyP371, MyP372, MyJG,
MyUber and MyPovr. If you were supporting multiple users on your system
or creating installable system-images you might create these directories
in /usr/local/share.
In your local git repository(ies) where the branch(es) are available do
the usual builds always specifying a prefix:
git checkout release/v3.7.1
cd unix
./prebuild
cd ..
./configure COMPILED_BY="wfp" --prefix=$HOME/tmpUser/MyP371
make -j4
make check
make install
For each branch you want to maintain change the --prefix argument to
point to the corresponding install space.  In my case the branches are
currently "3.7-stable", "release/v3.7.1", "master"(3.7.2) and other
experimental branches including my own "povr" branch for my work version
of povray.
It's helpful to do a 'make clean' or 'make distclean' after each 'make
install'.  With the code refactoring over time the clean and distclean
"targets" have changed due the source code directories getting moved
around and renamed.  You can skip the cleanup step but you might find
yourself with, for example, extra "*.o" object files laying around.
Note you'll get extra directories relative to any particular branch in
any case.  These extra directories will be empty if you have done the
distclean step while in the branch where they were valid.
With the differing distributions built and installed, I create small
wrapper scripts in my $HOME/bin directory to run each. For example, I
have a p370 bash script which looks like:
------------------ Start -----------------
#!/bin/bash
# Wrapper to run local POV-Ray 3.7.0 stable install
#-- Use install version's povray.ini over, for example,
#   $HOME/.povray/3.7/povray.ini which might have been
#   customized or be incompatible. If have Library paths
#   important and normally in the home directory, will
#   need to use -L or add additional Library_Path= in temp .ini file.
export POVINI=$HOME/tmpUser/MyP370/etc/povray/3.7/povray.ini
echo "" >$HOME/.povray/3.7/povray.ini
#   Note:
#   A similar conflict is possible with
#   $HOME/.povray/<version>/povray.conf. Use $PATH install only.
echo "" >$HOME/.povray/3.7/povray.conf
#--- Run what the user passes for options.
$HOME/tmpUser/MyP370/bin/povray $@
exit $?
------------------ End -----------------
Now instead of the usual:
povray +w800 +h600 the.pov
command use instead one of:
p370  +w800 +h600 the.pov
p371  +w800 +h600 the.pov
p372  +w800 +h600 the.pov
pPovr +w800 +h600 the.pov
pJG   +w800 +h600 the.pov
pUber +w800 +h600 the.pov
One of the awkward parts today is every "make install"(1) puts its own
versions of povray.ini and povray.conf into the users $HOME in a .povray
sub-directory common for all 3.7 versions.  My view is this isn't
something "make install" should be doing - rather povray should on start
look to create these files if need be on a users first invocation.
Further, better to maintain separate versions for 3.7.0 vs 3.7.1 for
example.  Anyway, not the way in works today and part of what the
wrapper scripts do is avoid the stuff in $HOME.
The six distributions currently require just under 300MB of disk space.
(1) - uberpov is set up so as to maintain its own .uberpov directory,
but I use the same form of wrapper script as all other versions to keep
things simple.
Bill P.
Date: 27 Jun 2017 11:50:00
Message: <web.59527deddc04a32345c5fe030@news.povray.org>
> Hi folks,
> Happy testing!
there doesn't seem to be any povwin*.exe under 'downloads'...
Date: 27 Jun 2017 12:22:49
Message: <59528659$1@news.povray.org>
Am 27.06.2017 um 17:46 schrieb green:
> clipka <ano### [at] anonymousorg> wrote:
>> Hi folks,
>> Happy testing!
Sorry for the inconvenience; the release candidate has been retracted
for now, while dev team is examining the possiblity of redesignating the
upcoming version as v3.8.0 rather than v3.7.1.
Date: 27 Jun 2017 13:45:06
Message: <web.595298a1dc04a32345c5fe030@news.povray.org>
> >> Hi folks,
> >> Happy testing!
ok, good.  thanks for the info.
Date: 30 Jun 2017 01:30:01
Message: <web.5955e11bdc04a323883fb31c0@news.povray.org>
But I haven't even started testing beta 9 yet!!  ;-P
"The World is moving too fast..."  Shakespeare (or Mark Twain??)
