POV-Ray : Newsgroups : povray.beta-test : Public Beta Release v3.7.1-beta.2 Server Time
1 Jun 2024 22:39:35 EDT (-0400)
  Public Beta Release v3.7.1-beta.2 (Message 21 to 30 of 46)
Subject: Re: Public Beta Release v3.7.1-beta.2
Date: 14 Jan 2017 13:42:37
Message: <587a711d$1@news.povray.org>
Am 14.01.2017 um 15:20 schrieb Jim Holsenback:
> On 1/11/2017 12:59 AM, clipka wrote:
>> POV-Ray 3.7.1 has now officially entered public beta testing phase.
>> Source code and Windows binaries are available on GitHub:
>> https://github.com/POV-Ray/povray/releases/tag/v3.7.1-beta.2
>> (beta.1 was an internal release only.)
>> The beta version is designed to install in its own dedicated directory,
>> and live happily alongside an existing 3.7 installation.
>> Happy testing!
> well since i'm not a doze user perhaps it's just me but ... this release
> seems to be having trouble honoring the Display = On option in the
> master povray.ini file as well as having it in a povray.ini file in the
> directory that the povray sdl file resides. In order to get a render
> display i have to add +d in toolbar command line. btw: it (beta) is
> reading all the other options (library path) options that i have in the
Just to avoid confusion: I understand that you're not /normally/ a
Windows user, but are reporting your results of testing POV-Ray for
Windows - is that correct?
Are you testing on a genuine Windows machine, a virtual machine, or an
emulator (e.g. Wine)?
Also, which binary are you using - 32 bit, 32 bit SSE2, or 64 bit?
Date: 14 Jan 2017 13:50:03
Message: <587a72db$1@news.povray.org>
>>> Happy testing!
adding that i installed beta down an alternate path (in my documents)
the 3.7 distribution lives in program files
you would be correct
the first one flavored windows 7 pro
the later
Date: 14 Jan 2017 14:25:51
Message: <587a7b3f@news.povray.org>
Am 14.01.2017 um 16:28 schrieb Jim Holsenback:
> also stumbled upon a windows docs issue as well ...
> in 3.2.4.1 output file type towards the bottom in the paragraph that
> starts as: The Radiance Synthetic Imaging System ... there are two
> external links: Radiance  and  OpenEXR. the Radiance link opens up the
> web page inside the windows help viewer, the OpenEXR link opens up the
> web age in default web /browser/ OpenEXR also appears as >>OpenEXR
I can confirm that; more precisely, it's "»OpenEXR", where "»" is the
Unicode/ISO-Latin-1 character U+00BB, "RIGHT-POINTING DOUBLE ANGLE
QUOTATION MARK".
> also have a look from 2.5.6 --> to the bottom of that page there is a
> mix of external links that exhibit the same behavior ... links that are
> preceded by >> open up the web page in default web browser and the links
> /without/ >> open web page inside the windows help viewer.
> looked on the wiki and /all/ links markup are consistent and the nix
> docs look fine (no >> anywhere) so i'm guessing it's regex issue in the
> post processing that creates the doze docs
I can confirm that this is indeed created during post-processing for the
Windows HTML Help. From what I glean from the conversion script this is
intended to mark external links, but from the results I conclude that it
indeed fails to catch all instances.
From what I see, there are two cases in which the algorithm fails:
- Non-HTTP external links (e.g. "https://whatever").
- External links followed by more links (external or internal) on the
same HTML source line.
Looks like I can amend the script to catch those as well. If you
discover any instances that don't fall in either category, feel free to
holler out loud.
Date: 15 Jan 2017 00:55:25
Message: <587b0ecd$1@news.povray.org>
Am 14.01.2017 um 17:28 schrieb StephenS:
> On WinXP sp3 32-bit
> pvengine and pvengine-sse2(default), POV-Ray runs fine, the editor has
> problems opening a file tab.
Stephen, can you please try this experimental version of the editor
DLLs, and let us know whether it solves the XP issues:
www.povray.org/temp/povwin-3.7-beta-editor.exe
Date: 15 Jan 2017 06:31:48
Message: <587b5da4@news.povray.org>
>> On WinXP sp3 32-bit
Same problems.
Stephen S
Date: 15 Jan 2017 08:07:06
Message: <587b73fa@news.povray.org>
>>> On WinXP sp3 32-bit
> Same problems.
Can you try dropping in, one by one, the editor DLL's from the 3.7.0
distribution (just copy & paste from the 3.7 bin directory) and find
out if/when the problem goes away? If so, changing which DLL fixed it?
Note: the 3.7.0 DLL's will pick up your 3.7.0 editor configuration,
this is to be expected.
-- Chris
Date: 15 Jan 2017 08:33:43
Message: <587b7a37$1@news.povray.org>
> -- Chris
Replacing with only povcmax32-sse2.dll, made no change.
Reset files.
Replacing with only cmedit32-sse2.dll v3.7.0.0, fixed problems(open file
tabs).
Stephen S
Date: 16 Jan 2017 20:08:30
Message: <587d6e8e$1@news.povray.org>
Am 15.01.2017 um 14:33 schrieb StephenS:
>> -- Chris
> Reset files.
> tabs).
Can you please try replacing the cmedit32-sse2.dll with this one:
http://wiki.povray.org/clipka-files/cmedit32-sse2.dll
Date: 16 Jan 2017 20:47:55
Message: <587d77cb$1@news.povray.org>
>> Reset files.
>> tabs).
Looking good :-)
Files open in new tab.
Stephen S
Date: 17 Jan 2017 03:58:41
Message: <587ddcc1$1@news.povray.org>
Am 17.01.2017 um 02:47 schrieb StephenS:
>>> Reset files.
>>> tabs).
> Looking good :-)
Please do test exhaustively, and let us know if you come across any
peculiarities; after all the povcmax DLL you're using might still turn
out to be problematic as well.
