POV-Ray : Newsgroups : povray.beta-test : Wavefront OBJ import Server Time
1 Jun 2024 22:26:26 EDT (-0400)
  Wavefront OBJ import (Message 21 to 30 of 31)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Wavefront OBJ import
Date: 17 Sep 2016 10:14:46
Message: <57dd4fd6$1@news.povray.org>
On 9/17/2016 9:52 AM, William F Pokorny wrote:
> Suggesting a correction and further tweak at bottom of the page:
i had it there previously had it but thought it looked better where i
had it ... oh well moved/updated it
Date: 17 Sep 2016 10:15:56
Message: <57dd501c$1@news.povray.org>
i had it there previously but thought it looked better where i had it
... oh well moved/updated it ... sheesh
Date: 18 Sep 2016 20:56:32
Message: <57df37c0$1@news.povray.org>
updated image and example code:
http://wiki.povray.org/content/Reference:Lemon
Date: 19 Sep 2016 07:20:55
Message: <57dfca17@news.povray.org>
The following point still does not make sense:
* minimal Inner_Radius is a spherical segment where the center of the
arc lies on the end points axis
Please see the discussion for the original sentence.
Date: 19 Sep 2016 09:12:20
Message: <57dfe434$1@news.povray.org>
oh-key-doe-key then ...
Date: 19 Sep 2016 11:36:46
Message: <57e0060e$1@news.povray.org>
thanks. Remember that I'm not a native speaker, so it's ok to amend any
of my text, as long as I can still understand it.
Date: 21 Sep 2016 12:52:10
Message: <57e2baba$1@news.povray.org>
Folks, just to let you know: Don't get too accustomed to the exact
syntax; I have strong reason to suspect I'll change it.
For starters, there may be cases when you want to import an .obj not as
a single mesh but as a set of meshes. (Point in case: Poser or DAZ
figures with eyelashes; the skin should have a refractive index of
around 1.45 for the Fresnelian effects to be modeled properly, while the
eyelashes must not have a refractive index at all or they'll look weird;
and while we're at it, the teeth should have a reflective index of
around 1.6. But POV-Ray does not support different refractive indices in
a single mesh.) The .obj mesh import syntax could be changed to import
only geometry that matches certain criteria (based on material, group or
object), but this would mean that in order to import all parts of an
.obj file it would have to be parsed multiple times, which isn't efficient.
So the approach I'll probably take is to make the obj import feature
create a single mesh if no filtering is done, but also provide means to
create a CSG union of meshes. But obviously it would be a tad confusing
to have a `mesh` statement create a CSG.
Also, in case we ever extend the import to support non-mesh geometry
(obj also supports points, lines and various NURBS-ish stuff) or even
other file formats that may support genuine geometric primitives,
stuffing all of it into the `mesh` syntax would seem rather odd.
Date: 22 Sep 2016 03:49:28
Message: <57e38d08$1@news.povray.org>
I am looking forward to this. One of the (future) benchmarks will
probably be when the import of a (complex) Poser figure will become
standard procedure :-)
However, I can also imagine other interesting complex things...
Good work! Thank you indeed for your unrelenting dedication!
Date: 22 Sep 2016 04:12:51
Message: <57e39283$1@news.povray.org>
Seconded.
Bravo.
Regards
Date: 22 Sep 2016 10:08:17
Message: <57e3e5d1$1@news.povray.org>
Am 22.09.2016 um 09:49 schrieb Thomas de Groot:
Actually I'm aiming for import of DAZ figures...
... which is why JSON import is next on my list (DAZ Studio 4.x's .duf
file format is actually based on JSON), in order to provide a vector for
the import of arbitrary DAZ materials. (The .mtl files that accompany
.obj files are far too restricted to be of any practical use with DAZ
figures.) The envisioned workflow would be (1) export of materials from
DAZ as (uncompressed) material presets, (2) import into POV-Ray using an
inbuilt syntax for JSON files, (3) processing of the imported data via
SDL macros to generate a set of POV-Ray material and texture
definitions, and (4) association of those materials to the meshes.
Which in turn means I'll have to implement yet a few more SDL goodies,
most notably mixed-type arrays. Some means to iterate over the elements
of a dictionary will also be needed, and possibly also a means to
identify what type of data a given variable holds.
And of course someone will have to implement a default include file to
actually do the DAZ materials data processing.
