POV-Ray : Newsgroups : povray.beta-test : Experimental tonemapping Server Time
29 Apr 2024 13:10:40 EDT (-0400)
  Experimental tonemapping (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Experimental tonemapping
Date: 10 Apr 2016 17:17:40
Message: <570ac2f4$1@news.povray.org>
El 10/04/16 a las 17:02, clipka escribió:
>> So here's the deal: Get the thing, test the shit out of it and
>> enjoy! :)
> Hmm... no takers yet? Or is that just the spring weekend dragging
> people outside?
   Just tried it for noise:
   tonemapping {
     parameters { red,green,blue }
     function(r,g,b) { r*f_granite(g*image_width,b*image_height,0) }
     function(r,g,b) { g*f_granite(r*image_width,b*image_height,0) }
     function(r,g,b) { b*f_granite(r*image_width,g*image_height,0) }
   I don't know if I've used it correctly there, but looks nice without
aa. With aa it loses most of the noise (and a later conversion to jpg
makes it almost unnoticeable). I guess that's one of the things that
will do better with the future post-aliasing "postprocesing" feature.
jaime
Date: 11 Apr 2016 06:29:15
Message: <570b7c7b@news.povray.org>
   Ok, ditch that one, these work better:
   // RGB noise
   tonemapping {
     #declare noise_amount=0.05;
     parameters { red,green,blue,x,y }
     function(r,g,b,x,y)
{r-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.4+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{g-f_granite(.2+x*image_width,y*image_width,0)*noise_amount+f_granite(.5+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{b-f_granite(.3+x*image_width,y*image_width,0)*noise_amount+f_granite(.6+x*image_width,y*image_width,0)*noise_amount}
   // B&W noise
   tonemapping {
     function(r,g,b,x,y)
{r-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.2+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{g-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.2+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{b-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.2+x*image_width,y*image_width,0)*noise_amount}
   Also, I found a solution for the pre-aa problem : don't use aa, but
focal blur. :)
jaime
Date: 11 Apr 2016 07:48:06
Message: <570b8ef6$1@news.povray.org>
>> So here's the deal: Get the thing, test the shit out of it and enjoy! :)
   // vignetting
   #declare vignetting_amount=0.3;
   #declare f_vignette=
   function{
     pigment{
       spherical
       color_map{
         [vignetting_amount rgb 0]
         [1 rgb 1]
   tonemapping {
     function(r,g,b,x,y) {r*f_vignette(x-.5,y-.5,0).gray}
     function(r,g,b,x,y) {g*f_vignette(x-.5,y-.5,0).gray}
     function(r,g,b,x,y) {b*f_vignette(x-.5,y-.5,0).gray}
Date: 11 Apr 2016 07:49:37
Message: <570b8f51$1@news.povray.org>
   Oops... that's a leftover from previous test, you can delete it.
jaime
Date: 11 Apr 2016 14:06:13
Message: <570be795$1@news.povray.org>
   Ok, first suggestion: how about a way to accumulate several effects,
perhaps using multiple tonemapping{} statements?
jaime
Date: 11 Apr 2016 15:00:10
Message: <570bf43a$1@news.povray.org>
Am 11.04.2016 um 20:06 schrieb Jaime Vives Piqueres:
Jotted down on the to-do list for future versions.
The present implementation is driven by the following goals:
(1) Achieve "gamma complete" status in 3.7.1 proper; to this end, it
seems necessary to provide _some_ mechanism by which users can effect
"artistic gamma" without having to misuse any of the existing technical
gamma handling mechanisms.
(2) At all costs avoid implementing a dedicated "artistic gamma" feature
that would become obsolete just one version later.
(3) Keep the first implementation simple to avoid excessively stalling
the release of 3.7.1 proper (*).
(* Sorry, no -- it's still too soon to hold your breath. Most notably
there's still plenty of work to do on the inbuilt help of the Windows
version.)
Date: 12 Apr 2016 00:45:10
Message: <570c7d56$1@news.povray.org>
A simple question from a simple mind: what #version statement needs to
be used? It's gagging on the "tonemapping" statement.
On 4/10/2016 9:02 AM, clipka wrote:
> Am 09.04.2016 um 04:33 schrieb clipka:
>> An experimental version supporting tonemapping can now be found at:
>> https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8558038%2Bav124
> Hmm... no takers yet? Or is that just the spring weekend dragging people
> outside?
Date: 12 Apr 2016 15:04:34
Message: <570d46c2$1@news.povray.org>
Am 12.04.2016 um 06:44 schrieb Tim Riley:
As far as the tonemapping statement is concerned, the experimental
version doesn't care what "#version" statement you use.
If you post the scene that gives you the error message, I should be able
to tell you whether it is a problem with the scene or a problem with the
version of POV-Ray you're using.
Date: 13 Apr 2016 19:16:15
Message: <570ed33f$1@news.povray.org>
Thanks for the offer, but I went back to your original email then looked
at my code a twentieth time and realized that I had placed the
tonemapping code /after/ the global_settings block instead of inside it.
I just got a 4K monitor and the font size is a little smaller than I'm
used to. I'm going to have to either increase the font size, or pay
closer attention.
Date: 14 Apr 2016 05:51:10
Message: <570f680e$1@news.povray.org>
Am 14.04.2016 um 01:16 schrieb Tim Riley:
> closer attention.
That's why I have my 4K divided across two displays ;)
In software development there's no substitute for /physical/ screen real
estate.
