POV-Ray : Newsgroups : povray.beta-test : Experimental tonemapping Server Time
26 Jul 2026 09:19:24 EDT (-0400)
  Experimental tonemapping (Message 1 to 10 of 12)
Subject: Experimental tonemapping
Date: 8 Apr 2016 22:33:31
Message: <570869fb@news.povray.org>
Hi folks,
An experimental version supporting tonemapping can now be found at:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8558038%2Bav124
So far only a 32-bit Windows binary is available, but the usual other
binaries will be added as their build completes.
To use tonemapping, the user needs to supply one or more functions
computing the effective output data from the raw data: One or three
functions to manipulate the colour data, and optionally a second or
fourth function to manipulate the transparency. By default, each
function takes the corresponding channel's raw data as a single
parameter, but the user can specify a different set of data to be passed
to all functions.
The syntax is
    global_settings {
      tonemapping {
        parameters { CHANNEL ... }
        FUNCTION ...
where each `CHANNEL` may be any of:
- `channel` (for the channel's raw data)
- `red`, `green`, `blue`, `filter` (for the named channel's raw data)
- `gray`, `grey` (for the raw grayscale value)
- 'x', 'y' (for the screen coordinate ranging from left/top = 0 to
right/bottom = 1).
Each `FUNCTION` may take either the following forms:
    function { EXPRESSION }
    function(IDENTIFIERS) { EXPRESSION }`
with the latter form allowing to specify the identifiers by which the
chosen data channels will be referred to in EXPRESSION (defaulting to
`x`, `y` and `z`)."
The following example adds the red channel to all colour channels
(including itself):
    global_settings {
      tonemapping {
        parameters { channel,red }
        function(c,r) { c+r }
The following example swaps the red, green, blue and alpha channels
around (note that the tonemapping operates on the transmit channel,
which is equivalent to 1-alpha):
    global_settings {
      tonemapping {
        parameters { red,green,blue,transmit }
        function(r,g,b,tr) { g }
        function(r,g,b,tr) { b }
        function(r,g,b,tr) { 1-tr }
        function(r,g,b,tr) { 1-r }
The feature can even be used to do something useful, such as simulating
film exposure:
    #declare Exposure = 1.6;
    #declare ExposureGain = 1.0;
    global_settings {
      tonemapping {
        function { ExposureGain * (1 - exp(-Exposure * x)) }
So here's the deal: Get the thing, test the shit out of it and enjoy! :)
Subject: Re: Experimental tonemapping
Date: 10 Apr 2016 11:02:47
Message: <570a6b17$1@news.povray.org>
Am 09.04.2016 um 04:33 schrieb clipka:
Hmm... no takers yet? Or is that just the spring weekend dragging people
outside?
Date: 10 Apr 2016 17:17:40
Message: <570ac2f4$1@news.povray.org>
>> enjoy! :)
> people outside?
   Just tried it for noise:
   tonemapping {
     parameters { red,green,blue }
     function(r,g,b) { r*f_granite(g*image_width,b*image_height,0) }
     function(r,g,b) { g*f_granite(r*image_width,b*image_height,0) }
     function(r,g,b) { b*f_granite(r*image_width,g*image_height,0) }
   I don't know if I've used it correctly there, but looks nice without
aa. With aa it loses most of the noise (and a later conversion to jpg
makes it almost unnoticeable). I guess that's one of the things that
will do better with the future post-aliasing "postprocesing" feature.
jaime
Date: 11 Apr 2016 06:29:15
Message: <570b7c7b@news.povray.org>
   Ok, ditch that one, these work better:
   // RGB noise
   tonemapping {
     #declare noise_amount=0.05;
     parameters { red,green,blue,x,y }
     function(r,g,b,x,y)
{r-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.4+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{g-f_granite(.2+x*image_width,y*image_width,0)*noise_amount+f_granite(.5+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{b-f_granite(.3+x*image_width,y*image_width,0)*noise_amount+f_granite(.6+x*image_width,y*image_width,0)*noise_amount}
   // B&W noise
   tonemapping {
     function(r,g,b,x,y)
{r-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.2+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{g-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.2+x*image_width,y*image_width,0)*noise_amount}
     function(r,g,b,x,y)
{b-f_granite(.1+x*image_width,y*image_width,0)*noise_amount+f_granite(.2+x*image_width,y*image_width,0)*noise_amount}
   Also, I found a solution for the pre-aa problem : don't use aa, but
focal blur. :)
jaime
Date: 11 Apr 2016 07:48:06
Message: <570b8ef6$1@news.povray.org>
   // vignetting
   #declare vignetting_amount=0.3;
   #declare f_vignette=
   function{
     pigment{
       spherical
       color_map{
         [vignetting_amount rgb 0]
         [1 rgb 1]
   tonemapping {
     function(r,g,b,x,y) {r*f_vignette(x-.5,y-.5,0).gray}
     function(r,g,b,x,y) {g*f_vignette(x-.5,y-.5,0).gray}
     function(r,g,b,x,y) {b*f_vignette(x-.5,y-.5,0).gray}
Date: 11 Apr 2016 07:49:37
Message: <570b8f51$1@news.povray.org>
   Oops... that's a leftover from previous test, you can delete it.
jaime
Date: 11 Apr 2016 14:06:13
Message: <570be795$1@news.povray.org>
   Ok, first suggestion: how about a way to accumulate several effects,
perhaps using multiple tonemapping{} statements?
jaime
Date: 11 Apr 2016 15:00:10
Message: <570bf43a$1@news.povray.org>
Am 11.04.2016 um 20:06 schrieb Jaime Vives Piqueres:
Jotted down on the to-do list for future versions.
The present implementation is driven by the following goals:
(1) Achieve "gamma complete" status in 3.7.1 proper; to this end, it
seems necessary to provide _some_ mechanism by which users can effect
"artistic gamma" without having to misuse any of the existing technical
gamma handling mechanisms.
(2) At all costs avoid implementing a dedicated "artistic gamma" feature
that would become obsolete just one version later.
(3) Keep the first implementation simple to avoid excessively stalling
the release of 3.7.1 proper (*).
(* Sorry, no -- it's still too soon to hold your breath. Most notably
there's still plenty of work to do on the inbuilt help of the Windows
version.)
Date: 12 Apr 2016 00:45:10
Message: <570c7d56$1@news.povray.org>
A simple question from a simple mind: what #version statement needs to
be used? It's gagging on the "tonemapping" statement.
> outside?
Date: 12 Apr 2016 15:04:34
Message: <570d46c2$1@news.povray.org>
Am 12.04.2016 um 06:44 schrieb Tim Riley:
As far as the tonemapping statement is concerned, the experimental
version doesn't care what "#version" statement you use.
If you post the scene that gives you the error message, I should be able
to tell you whether it is a problem with the scene or a problem with the
version of POV-Ray you're using.
