POV-Ray : Newsgroups : povray.beta-test : master branch issue 29 linux compilation errors Server Time
15 May 2026 21:01:48 EDT (-0400)
  master branch issue 29 linux compilation errors (Message 31 to 40 of 41)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: master branch issue 29 linux compilation errors
Date: 2 Jul 2014 17:57:22
Message: <53b48042$1@news.povray.org>
Am 02.07.2014 21:43, schrieb Le_Forgeron:
> Le 02/07/2014 20:49, clipka nous fit lire :
>> Am 02.07.2014 19:58, schrieb Le_Forgeron:
>>> Le 02/07/2014 19:37, clipka nous fit lire :
>>>> Am 02.07.2014 19:23, schrieb Le_Forgeron:
>>>>>> Can you please give me the output with ">>" corrected to "> >"?
>>>>>> Thanks a
>>>>>> lot!
>>>>> Here it is, attached.
>>>> Thanks. Next incarnation of feature/colour_model is ready for testing.
>>> It's getting bigger (here the clang version, as gcc is above 5M)
>> Future versions will be in experimental/colour_model from now on.
> Beware, gcc errors once un-bzip2-ed is 1 699 869 bytes long in
> errorcolor.txt.
> clang errors in the other file.
I don't really understand why both gcc and clang insist that mColour is
undefined, when it's a protected member of the publicly inherited base
class.
Let's see what the latest change does.
Date: 2 Jul 2014 18:30:45
Message: <53b48815@news.povray.org>
Am 02.07.2014 23:56, schrieb clipka:
>>>>>>> Thanks a
>>>>>>> lot!
>> errorcolor.txt.
> class.
I think I got it; the problem is dependent base class name lookup.
f9d1c6ba should solve the mColour problem, let's see what else crops up.
(I've found by now that the "nasty" part of the "nasty template stuff",
which I was afraid might not work at all, isn't really that nasty, and
is actually an established pattern going by the name of "Curiously
Recurring Template Pattern", aka CRTP.)
Date: 2 Jul 2014 18:50:24
Message: <53b48cb0@news.povray.org>
Am 03.07.2014 00:30, schrieb clipka:
Forget f9d1c6ba, commit 81627c72 is now the latest and greatest.
Date: 3 Jul 2014 12:06:17
Message: <53b57f79@news.povray.org>
Le 03/07/2014 00:49, clipka nous fit lire :
It's not yet that.
As tomorrow I'm in holidays... if you have a bit of disk space on your
Windows (about 10 Giga ?), you might get faster return by installing
something like virtualbox and putting inside it a virtual machine to
install a linux iso-cd/dvd (ubuntu ?). I recommend at least 10G of
virtual disk size, but you can allocate more. (interestingly, the disk
image used by virtualbox is about the size of used data, but resizing
the whole disk later is problematic, so sizing big at start is better)
(Well, I wouldn't do it on the opposite path (linux->windows), so feel
no obligation).
CRTP is quite usual, but it might not be the simplest to understand when
you start with template (oh well, variadic templates of C++11 are even
stranger...).
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Download 'error81627c72gcc.txt.bz2.zip' (63 KB)
Date: 3 Jul 2014 12:07:09
Message: <53b57fad$1@news.povray.org>
Le 02/07/2014 23:23, clipka nous fit lire :
> Am 02.07.2014 22:01, schrieb Le_Forgeron:
>> It might be a long road.
>> I just went back to compile 3.7-stable with gcc and the image of
>> benchmark is even a bit different from the one at head with icpc.
>> There is a change in the clouds, basically the same place and
>> shape...but some holes...
> That's a known side effect of commit 5a081e92, which fixes a bug in the
> way media used to be sampled (see also FS#318).
Ok, that's one less point to search. Great & thanks.
I will dive into that exploration after my holidays.
Date: 3 Jul 2014 13:28:12
Message: <53b592ac$1@news.povray.org>
Am 03.07.2014 18:06, schrieb Le_Forgeron:
> It's not yet that.
Have a nice time!
Date: 6 Jul 2014 07:18:54
Message: <53b9309e$1@news.povray.org>
Am 02.07.2014 18:44, schrieb Le_Forgeron:
> Rendering benchmark gives the attached pictures (the icpc seems ok,
> within usual time, but gcc is bogus and too fast, far too fast)
I finally found out what's going on here.
The implementation of adaptive area lights uses an N*M cache for
"lightlet" data it has already computed. Previously, yet-uncomputed data
was flagged by setting the respective colour's red channel to -1. I had
changed this to use a NaN ("Not-a-Number") value instead, to avoid
problems when a user deliberately sets a light source's colour to
negative red.
Now of course this NaN value has to be tested for; according to IEEE
standard, a NaN value has the property that it is non-equal to anything,
even itself. So I wrote the test: "if (red != red)...".
Well, it turns out that the g++ compiler optimizes this comparison away
when in "-ffast_math" mode.
Date: 6 Jul 2014 08:00:01
Message: <web.53b939edf234d99f95bf23070@news.povray.org>
> negative red.
Use std::isnan - it works because IEEE 754 and C++ floats are not exactly the
same, and for most practical purposes NaNs will have a valid and identical
storage in memory. Be aware that NaNs and Infinites may raise exceptions
regardless though.
Date: 6 Jul 2014 15:04:08
Message: <53b99da8$1@news.povray.org>
Am 06.07.2014 13:58, schrieb Thorsten Froehlich:
>> negative red.
> regardless though.
std::isnan() is not a universal solution either, as it's not C++(03)
standard; for instance, Microsoft Visual C++ doesn't have it (it has an
_isnan() function instead). And I haven't tested whether it actually
solves the problem - according to the gcc documentation, -ffast_math
means that the compiler doesn't know anything about infinities and NaNs
at all, and the std::isnan function might just as well always return false.
So while it is now clear what's happening, this is not solved yet, so I
have my work cut out for me tonight.
Date: 6 Jul 2014 16:25:00
Message: <web.53b9af74f234d99ffbcb43f50@news.povray.org>
> >> negative red.
> > regardless though.
Its in C99 and C++11, but indeed will not work with fast math on for the
respective function. Other than disabling fast math for said function, using a
less likely magic value like HUGE_VALF or a separate store for the flag are all
the portable ways left.
