POV-Ray : Newsgroups : povray.beta-test : Requesting user feedback: POV-Ray v3.7 scenes/includes Server Time
25 Apr 2026 18:11:12 EDT (-0400)
  Requesting user feedback: POV-Ray v3.7 scenes/includes (Message 31 to 40 of 47)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Requesting user feedback: POV-Ray v3.7 scenes/includes
Date: 1 Mar 2013 16:41:55
Message: <513120a3$1@news.povray.org>
> Am 01.03.2013 04:14, schrieb Alain:
>> In my math classes when looking at geometry, we only used the
>> left-handed coordinate and rotation system. Also, Y was always UP and Z
>> forward, NEVER relative to the paper's surface.
>> It was the same in my physics courses.
> What? For us it was /always/ right-handed, for both maths and physics. I
> can't believe it's different across the world in such disciplines.
> ... unless of course you use a different scheme to assign axes to the
> fingers. We used thumb=X, index=Y, and middle=Z.
Using the right hand, it require you to twist your arm to have the thumb
point toward +X, then the index point to +Z
In my courses, with the left hand, it was: thumb = +Y, index= +Z,
middle= +X with the index pointing forward and the thumb up.
Very easy to hold, and you can still have a pen in your right hand...
Maybe just a coincidence, but it's the same thing that is used to get
the direction of the force exerced on a conductor in a magnetic field.
The index is in the direction of the current (positive), the thumb in
the direction of the magnetic field (north pole), and the middle finger
in the direction of the force.
For the rotations, you point the thumb toward the + side of an axis, and
the fingers curl in the direction of the positive rotation.
That's why, for me, ther was no learning curve to use the POV-Ray
coordinate system. It's exactly the same I always used in school.
>> The right-handed system is mostly used by architecs, and, as most early
>> modeling applications where made for architecs, it stuck. It's also why
>> we have the infamous Z for the up direction. Architecs use the X and Y
>> axis along the ground and on paper where +X is right and +Y is the top
>> of the paper.
> If you put a proper math-style 2D coordinate system (X axis right, Y
> axis "top") onto paper, and then add +Z as height above ground, that's a
> left-handed system to me.
That's exactly how architecs work. And that's right handed.
Date: 1 Mar 2013 22:32:52
Message: <513172e4$1@news.povray.org>
Am 01.03.2013 22:42, schrieb Alain:
That's a left-handed system indeed, but I doubt it's the standard used
in professional mathematics and physics. (Then again, in professional
mathematics the handedness of the world is just abstracted away anyway.
That leaves physics though.)
If you swap any of the two components, you can do the same stunt with
the right hand.
But here are two stunts you can't do left-handed:
Make a "thumbs-up" sign with your right hand. Point your thumb in the
direction of current in a wire. The fingers will curl in the direction
of the magnetic field around the wire.
Make a "thumbs-up" sign with your right hand. Hold your hand so that the
fingers curl in the direction of current flowing in a coil. The thumb
will point in the direction of the magnetic field inside the coil.
That's true in both left- and right-handed coordinate systems, simply
due to the way positive rotation is defined. (In other words, in a
left-handed coordinate system positive rotation is defined just the
other way round as in a right-handed one.)
It might be a UK-schools special, which would explain why POV-Ray uses
it. (Then again, you are not from the UK, are you?)
Doing the gymnastics again, yes - it is indeed.
Date: 1 Mar 2013 23:58:13
Message: <513186e5$1@news.povray.org>
> the right hand.
No. Canada.
Date: 2 Mar 2013 03:22:25
Message: <5131b6c1@news.povray.org>
Just as an info: The modeller Silo uses the following right-handed
system coordinate:
X to the right (thumb)
Y up (index)
Z towards viewer/out of screen (middle)
Moray, on the other hand (no pun intended), was right-handed as follows:
Y towards screen (index)
Z up (middle)
Date: 6 Mar 2013 03:20:03
Message: <web.5136fb11823c8519c2d977c20@news.povray.org>
> system coordinate:
> Y up (index)
> Z up (middle)
What a mess! :-P
Well, there seems to be at least ONE 'standard' that everyone/every system
agrees on: +x is to the right. Hooray! It's good to know that there's one little
'island of stability' in a chaotic world. ;-)
Date: 6 Mar 2013 03:53:04
Message: <513703f0$1@news.povray.org>
On 6-3-2013 9:15, Kenneth wrote:
> What a mess! :-P
In fact, once you get used to manipulating the different systems at the
same time, you know exactly what to expect and how to merge everything
harmoniously into POV-Ray.
So, for Moray, I always had two lines of code ready whenever I imported
a Moray object into a POV scene:
scale <1,1,-1>
rotate <90,0,0>
Except of course, when I used complete Moray scenes. I suppose that the
/new/ future Moray version is going to be left-handed by the way ;-)
Using Silo, I model as if the object were left-handed, export it as
left-handed through Poseray, and then just rotate it by 180*y whence in
POV-Ray.
Little tricks, but becoming automatic.
Date: 6 Mar 2013 16:06:42
Message: <5137afe2$1@news.povray.org>
Am 06.03.2013 09:15, schrieb Kenneth:
>> system coordinate:
>> Y up (index)
>> Z up (middle)
> What a mess! :-P
I don't want not spoil your joy :-)
but "+x is right" is not always right!
Sometimes it's also left!
Take a look at http://www.f-lohmueller.de/pov_anim/ani_3920d.htm
Date: 7 Mar 2013 02:10:09
Message: <web.51383c1e823c8519c2d977c20@news.povray.org>
Oh no!  TOTAL chaos now! (heh heh)
BTW, that's a really nice animation. I had not seen that particular page; thanks
for posting the link. (I need to revisit your website--LOTS of fascinating and
useful stuff there. Over the years, I've learned *many* POV-Ray tips and tricks
from all of it.)
Date: 7 Mar 2013 21:05:02
Message: <web.5139470b823c851978641e0c0@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> So, we're asking for user feedback and recommendations for things to
> remove and things to add. Please followup to this thread ... thanks!
A few years ago, CLipka posted some well-annotated SDL code for dispersion to
the TINA-CHeP forums:
   http://tinachepforum.forumup.co.uk/about8-tinachepforum.html
If he is willing, I'd love to see that as a standard include file.
Date: 8 Mar 2013 02:02:50
Message: <51398d1a$1@news.povray.org>
Am 08.03.2013 03:03, schrieb Cousin Ricky:
You might want to have a look at your POV-Ray 3.7 standard include
directory - keep your eyes peeled for "ior.inc" ;-)
