POV-Ray : Newsgroups : povray.beta-test : Test of RC5 Windows installer Server Time
18 May 2024 18:51:53 EDT (-0400)
  Test of RC5 Windows installer (Message 14 to 23 of 23)
Subject: Re: Test of RC5 Windows installer
Date: 15 Mar 2012 09:34:06
Message: <4f61efce@news.povray.org>
Forgot to add I am using Windows 7 64 bit.
"David"  wrote in message news:4f61ef41$1@news.povray.org...
I am not getting any file association with .pov files with both RC4 and RC5.
RC3 and earlier did this okay.
If I open a .pov file I get the windows pop-up asking me to pick a program
or search for one and have to do it manually.
I thought it was perhaps my windows installation causing this but maybe its
not?
"Chris Cason"  wrote in message news:4f59d1d0$1@news.povray.org...
Folks,
I would appreciate it if some of you could sanity-check the RC5
windows installer, which may be found here:
  http://www.povray.org/beta/povwin-3.7.RC5-setup.exe
Please advise if you have any installation issues.
-- Chris
Date: 15 Mar 2012 10:44:07
Message: <4f620037@news.povray.org>
> RC5. RC3 and earlier did this okay.
> program or search for one and have to do it manually.
> its not?
I am getting something similar. If I select a pov file and open it, it
opens with notepad. (I think that I set this manually a while ago.) If I
use "open with" I get the option of opening it with RC3 or ver 3.5.
I still have 3.5 in case I want to use Moray.
I cannot say what it did before as I hardly ever open pov files that way.
Regards
Date: 15 Mar 2012 10:45:00
Message: <web.4f61ff2ba0f59aa499ed429f0@news.povray.org>
> Mika L wrote:
> > I have a problem with registering .pov-files to the right POV-Ray application.
> > Namely, when I double-click on a .pov-file, it opens in the 32-bit POV-Ray
> > application (pvengine.exe).
> I now tried this too and found that in my case, the POV files
> were still associated with my 3.6 installation. Associating it
> with pvengine64.exe did not work, associating it with pvengine.exe
> worked but connect to the render command instead of open (???).
> The command under
> HKEY_CLASSES_ROOT\povfile\shell\Open\command
> appeared to be correct. After deleting
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.pov\UserChoice
> everything worked fine (Windows 7 x64). So possibly Windows got confused
> with an earlier manual association, but the behavior was still strange.
In my computer the command under
points to the deleted folder of RC4 and I cannot modify that. The Modify-command
in regedit is greyed out.
-Mika
Date: 15 Mar 2012 11:00:01
Message: <web.4f620376a0f59aa499ed429f0@news.povray.org>
> The command under
I fixed the path in the command under
but I cannot delete the entry
I can edit this entry, but what should I write in it?
My computer also executes the Render command in pvengine.exe by double-clicking
on a .pov-file.
-Mika
Date: 15 Mar 2012 11:15:44
Message: <4f6207a0$1@news.povray.org>
>> its not?
Same for me on Windows 7 x64. I had not tested this before because I
never open pov files this way, but no program is recognized and has to
be selected manually. I don't know how it was with older versions.
Date: 16 Mar 2012 17:45:01
Message: <web.4f63b384a0f59aa4a92d0ddf0@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> Folks,
> -- Chris
I am running Win XP64, and I cannot install the RC5 version.  I have RC3
installed, and have had no issues.  I get the following error message:
The exception unknown software exception (0xc0000005) occurred in the
application at location 0x00000000.
Date: 16 Mar 2012 17:47:43
Message: <4f63b4ff@news.povray.org>
Thanks for the report - we're aware of this issue but are having
difficulty in tracking down the cause. If you want to assist in
tracking it down by running some additional tests please drop me an
email directly.
-- Chris
Date: 16 Mar 2012 21:20:01
Message: <web.4f63e5c0a0f59aa4a92d0ddf0@news.povray.org>
> email directly.
> -- Chris
Chris, I don't see your email.  I will be glad to help out in any way I can.
John
Date: 23 Mar 2012 16:45:01
Message: <web.4f6ce070a0f59aa4271ddd6b0@news.povray.org>
> email directly.
> -- Chris
Chris, I am still having this issue, and haven't received a reply from the email
you asked for.  Just an FYI, and not pushing.  Thanks.
John
Date: 25 Mar 2012 07:02:17
Message: <4f6efb39@news.povray.org>
On 09/03/2012 9:47 AM, Chris Cason wrote:
> Folks,
The last installation (RC5) did not automatically append standard
locations in povray.ini
Regards
