POV-Ray : Newsgroups : povray.beta-test : Test of RC5 Windows installer Server Time
25 Apr 2026 18:11:06 EDT (-0400)
  Test of RC5 Windows installer (Message 21 to 23 of 23)
Subject: Re: Test of RC5 Windows installer
Date: 16 Mar 2012 21:20:01
Message: <web.4f63e5c0a0f59aa4a92d0ddf0@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> On 17/03/2012 08:41, JC wrote:
> > I am running Win XP64, and I cannot install the RC5 version.  I have RC3
> > installed, and have had no issues.  I get the following error message:
> > The exception unknown software exception (0xc0000005) occurred in the
> > application at location 0x00000000.
> Thanks for the report - we're aware of this issue but are having
> difficulty in tracking down the cause. If you want to assist in
> tracking it down by running some additional tests please drop me an
> email directly.
> -- Chris
Chris, I don't see your email.  I will be glad to help out in any way I can.
John
Date: 23 Mar 2012 16:45:01
Message: <web.4f6ce070a0f59aa4271ddd6b0@news.povray.org>
> email directly.
> -- Chris
Chris, I am still having this issue, and haven't received a reply from the email
you asked for.  Just an FYI, and not pushing.  Thanks.
John
Date: 25 Mar 2012 07:02:17
Message: <4f6efb39@news.povray.org>
On 09/03/2012 9:47 AM, Chris Cason wrote:
> Folks,
> I would appreciate it if some of you could sanity-check the RC5
> windows installer, which may be found here:
>    http://www.povray.org/beta/povwin-3.7.RC5-setup.exe
> Please advise if you have any installation issues.
The last installation (RC5) did not automatically append standard
locations in povray.ini
Regards
Date: 25 Mar 2012 14:47:37
Message: <4f6f6849$1@news.povray.org>
>> Folks,
Some standard locations no longer need to be defined in povray.ini. The
scene and include folders are now in a stable location and don't need to
be explicitely defined.
Date: 25 Mar 2012 15:32:58
Message: <4f6f72ea@news.povray.org>
Thanks, I did not know that.
Regards
Date: 25 Mar 2012 18:01:46
Message: <4f6f95ca$1@news.povray.org>
That was the case previously, however this has changed with RC4 as a
number of users wanted the ability to change the default locations.
The default paths should not generally be needed in povray.ini as
POVWIN automatically adds them to the include path based on
information in the registry.
However I can see there might be a case for having them in the INI
file anyhow, e.g. if another program wants to parse the INI file (e.g.
a console build of POV that doesn't have the windows registry logic).
-- Chris
Date: 25 Mar 2012 18:04:00
Message: <4f6f9650@news.povray.org>
This technically isn't needed by POVWIN. I am undecided if it's a good
idea to include them in the INI file as well. It would be useful for
non-standard builds to parse the INI file, but would also make it less
portable (currently POVWIN will infer the correct information based on
the registry and/or launch path).
-- Chris
Date: 25 Mar 2012 18:28:22
Message: <4f6f9c06$1@news.povray.org>
That is true, for instance Bishop3D will read the ini file to add paths
to its own importer.
But I miss-read the text and thought it said that Windows would
automatically append standard locations on installation.
Regards
Date: 7 Apr 2012 14:05:00
Message: <web.4f808118a0f59aa4225f6f120@news.povray.org>
> > email directly.
> > -- Chris
> John
Hi... i have the same problem. The installation fail when push the button
"next".
My computer run under XP64.
greetings!
Date: 15 Jun 2012 14:20:00
Message: <web.4fdb7c97a0f59aa46d36c97d0@news.povray.org>
> > > email directly.
> > > -- Chris
> > John
> "next".
> greetings!
I am having same issue, and same OS. How can i help to solve this issue? If not,
is there a way to extract files from installer and install manually?
