POV-Ray : Newsgroups : povray.beta-test : RC4 SSLT question Server Time
18 May 2024 13:23:20 EDT (-0400)
  RC4 SSLT question (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: RC4 SSLT question
Date: 28 Feb 2012 06:10:14
Message: <4f4cb616$1@news.povray.org>
On 28/02/2012 12:26 AM, James Holsenback wrote:
> I find the new method much more simpler ...
Simplicity is not always best. Think about how many people complain
about M$ windows and iTunes.
> I started with the scene
> file that was added ~scenes/subsurface/subsurface.pov and played around
> with it changing things and observing the affect. It's a simple scene
> and renders fairly quickly. I then graduated to a little bit more
> complicated object then started playing with that ... move the light,
> and/or change the camera view. Hint cylinders make a better test object
> (the edges) than say rounded (sphere).
A good suggestion. It looks like I will need to run a series of
experiments instead of just being able to convert my existing scenes.
Don't forget to play with the
> scaling (mm_per_unit: smaller value makes it more transparent at the
> edges, larger lessens the affect) ... keep it simple at first until you
> get the hang of it, then graduate to more complicated shapes.
Bah! Kiddy stuff. :-P
It is generally with meshes that I have been using it with.
> BTW: RC5 is on deck because of the bug report you lodged.
That is fine, Chris sent me an evaluation copy to test. :-)
> clipka's fix
> also fixed a couple of other issues I found during testing, so it won't
> be prone to crashes due to improper usage ... a bit more robust.
That is good.
> Don't
> get discouraged, it's a cool feature and well worth the seemingly
> tedious learning curve ... lastly the use of color vectors with a zero
> component is still problematic ... zero diffuse as well IIRC
That is understandable. A totally black surface will not have any
hard to imagine but what do I know? ?_?
> OH yeah ... forgot to mention the to don't forget the interior {ior
> whatever} part ... bundle that with the rest of the texture definition
> as a material
It is easy to notice if you have forgotten it. The render is too fast. :-)
What I really wanted is an understanding of what the translucency values
mean in RL.
To my way of thinking a value of <1, 1, 1> would mean that the material
is completely translucent and all the colour components are allowed to
penetrate unhindered. Why can we use a value > 1?
Yes some experimenting is needed.
Regards
Date: 28 Feb 2012 06:23:30
Message: <4f4cb932$1@news.povray.org>
simpler shapes ... walk before ya run ;-)
>> Don't
not just rgb 0 ,.... rgb <1,0,0> should be rgb <1,0.01,0.01> .... etc
Date: 28 Feb 2012 06:37:30
Message: <4f4cbc7a$1@news.povray.org>
I know, I know. But... ;-)
>>> Don't
I have just made a cylinder mesh and am about to start experimenting.
Regards
Date: 28 Feb 2012 11:44:22
Message: <4f4d0466@news.povray.org>
Am 27.02.2012 19:13, schrieb Stephen:
> With the changes to the SSLT code in RC4 there is now only one
> controlling vector, translucency, instead of two, scattering and
> absorption. What if any is the relationship between translucency,
> scattering and absorption?
> Scattering and absorption made sense to me and the reference pdf gave
> values for some materials. So how do we go about using translucency?
There were various major drawbacks with the parameterization based on
scattering and absorption.
First, while they allowed to plug in physical properties of a material
directly, sources for such data is scarce (that one pdf is the only
source I'm currently aware of), and tweaking those properties to mimic
any other desired material - even just a similar material with different
color, or a material with same color but stronger or weaker SSLT effect
- is non-trivial to say the least.
Second, those two parameters fully determined the material's color,
leaving the classic pigment parameter with no effect; this resulted in
more maintenance effort if you wanted test renders without SSLT to use
similar colors.
And last not least, with those parameters it was a major challenge - if
not impossible - to make use of classic image textures (like, say, Poser
skin textures) together with SSLT.
The new parameterization makes it straightforward to achieve a
particular effective color by simply specifying that color as a pigment;
this leaves you with only one RGB parameter to toy around if you want to
mimic a particular material, automatically keeps SSLT and non-SSLT color
of a material in sync, and enables you to change the material color - or
apply standard image textures - in a pinch.
The new parameterization also imposes no added limitations: Any material
you could model with the old parameterization can also be modeled with
the new one.
The translucency parameter specifies the so-called "mean free distance"
of a light ray in the material (in mm), i.e. the average distance a
light ray travels before it is either absorbed or scattered. This can be
more than 1.0 mm in case of very "waxy" materials, and could
theoretically be as large as infinity (for a perfectly transparent
material).
I've only recently heard of Poser figures coming with translucency maps,
which obviously need to specify values in the range 0..1; it would be
interesting to know what parameterization is used there, so we could
adapt POV-Ray to easily make use of them as well; the SSLT syntax is
therefore still in flow.
Date: 28 Feb 2012 12:40:57
Message: <4f4d11a9$1@news.povray.org>
> material).
Thanks Christoph I understand it better now that I know what the values
related to. I can get a mental image of what is happening.
that too much to ask for?
I've not heard of that. Interesting!
Regards
Date: 28 Feb 2012 14:28:23
Message: <4f4d2ad7@news.povray.org>
> distance" of a light ray in the material (in mm), i.e. the average
> distance a light ray travels before it is either absorbed or
> scattered. This can be more than 1.0 mm in case of very "waxy"
> materials, and could theoretically be as large as infinity (for a
> perfectly transparent material).
It probably depends on photon wavelength as well, although I'm not
sure that effect is strong enough to impact the visual perception of
an object with translucency.
Date: 28 Feb 2012 17:07:43
Message: <4f4d502f@news.povray.org>
Am 28.02.2012 20:28, schrieb Christian Froeschlin:
The wavelength-dependency of the mean free distance is indeed quite
significant in some materials; that's why translucency is an RGB parameter.
Date: 29 Feb 2012 03:00:02
Message: <4f4ddb02$1@news.povray.org>
For what it's worth :-)  I mentioned that in my latest post in p.t.poser.
Date: 29 Feb 2012 11:12:33
Message: <4f4e4e71$1@news.povray.org>
> Thomas
When you were talking about hair?
I thought that clipa was talking about the body meshes.
Regards
Date: 1 Mar 2012 03:29:13
Message: <4f4f3359$1@news.povray.org>
My latest is about body meshes ;-)
See message: "Use and significance of the different body maps in Poser 8+"
