POV-Ray : Newsgroups : povray.beta-test : Radiosity artifacts at low error_bound in 3.7RC3 Server Time
30 Apr 2026 19:00:53 EDT (-0400)
  Radiosity artifacts at low error_bound in 3.7RC3 (Message 1 to 4 of 4)
Subject: Radiosity artifacts at low error_bound in 3.7RC3
Date: 17 May 2011 18:20:00
Message: <web.4dd2f2fc468c5d60dca745f10@news.povray.org>
Consider this scene of a hollow sphere viewed from the inside:
    difference {
        sphere { 0, 100 }
        sphere { 0, 99 }
        pigment { rgb 1 }
        finish { ambient .4 }
    global_settings {
        radiosity {
            error_bound .1
            always_sample off // default in 3.7
Rendering produces dark splotches at the centers of the pretrace
blocks. Blocks rendered earlier have darker splotches. They also differ
in shape between renders even with +HR (but not with +WT1). Turning
"always_sample" on removes them, as does increasing "count" past 1000.
I wonder if this might be a bug, as 3.6 doesn't produce these artifacts
regardless of "always_sample" and "count".
Subject: Re: Radiosity artifacts at low error_bound in 3.7RC3
Date: 18 May 2011 18:07:29
Message: <4dd44321$1@news.povray.org>
Am 18.05.2011 00:13, schrieb aaz:
Yuck!
The radiosity settings are a poor choice (low error_bound and a low
number of pretrace passes don't mix well), but it seems there /is/
something else fishy. I'll have a look at it. Would you mind filing a
bug report at http://bugs.povray.org in the meantime?
Date: 18 May 2011 22:38:13
Message: <4dd48295$1@news.povray.org>
>      difference {
>          sphere { 0, 100 }
>          sphere { 0, 99 }
>          pigment { rgb 1 }
>      global_settings {
>          radiosity {
>              error_bound .1
Changing pretrace_end to 0.01 make those spots disapear.
count 100 and pretrace_start 0.04 pretrace_end 0.02 also show an uniform
surface.
Date: 19 May 2011 07:45:00
Message: <web.4dd5025db1fe0a28dca745f10@news.povray.org>
> Would you mind filing a bug report
http://bugs.povray.org/task/203
You can still make out their shapes at very high contrast. Actually,
it looks like "always_sample" doesn't remove them completely either.
The render produced by 3.6 is also not entirely uniform, but it doesn't
have this distinct pattern.
Originally I was rendering the shadow of a "no_image" object standing
on a plane and tuned "error_bound" all the way to .01 to get an
accurate edge where the object touched the plane. At this setting these
artifacts appear as random black dots and it's very hard to get rid of
them within a reasonable render time.
