POV-Ray : Newsgroups : povray.beta-test : 3.7 RC3, One suggestion/request Server Time
25 Apr 2026 19:55:00 EDT (-0400)
  3.7 RC3, One suggestion/request (Message 11 to 16 of 16)
Subject: Re: 3.7 RC3, One suggestion/request
Date: 26 Feb 2011 19:15:24
Message: <4d69979c@news.povray.org>
Le_Forgeron wrote:
> the same issue will be happening whatever the colour
> or pattern: sometime it will be invisible)
the same holds for the grey-checkered background pattern indicating
not yet rendered blocks. It's not likely that a real scene will match
it exactly and if it pathetically does then it's not very critical.
So a rather non-invasive method of marking blocks might be to use the
exact same pattern that is already there but with different colors, e.g.
black-red instead of gray-white.
Date: 26 Feb 2011 19:25:59
Message: <4d699a17$1@news.povray.org>
On 2/26/2011 1:07 PM, Darren New wrote:
> Warp wrote:
>> In the preview window, draw a semi-transparent border around the blocks
>> being currently rendered.
> Or toggle between normal and inverse video a couple times a second?
And here I was just thinking it should be a plain box with an x marked
through it... drawn sort of like the bounding boxes :)
Date: 26 Feb 2011 19:27:13
Message: <4d699a61$1@news.povray.org>
On 2/26/2011 4:26 PM, Darren New wrote:
> Maybe toggling for each pixel updated, so you can see how fast each
> block is rendering? :-)
The block currently being rendered doesn't show anything until the
render is complete for that block.
Date: 26 Feb 2011 21:53:26
Message: <4d69bca6$1@news.povray.org>
Since the box is apparently empty until the whole box is calculated, it
would seem to be a perfectly fine solution. (I had forgotten how it looked,
but I guess I was remembering seeing entire blocks being updated instead of
individual pixels of a particular block.)
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 27 Feb 2011 02:48:10
Message: <4d6a01b9@news.povray.org>
Trevor G Quayle <Tin### [at] hotmailcom> wrote:
> Yes, I don't care about how it will look as long as it's off by default.
  If it's a subtle border around the block being rendered, why is it so
important to be off by default?
Date: 27 Feb 2011 09:35:00
Message: <web.4d6a6005af21053fb05ef170@news.povray.org>
If it's subtle I suppose.  I wasn't liking the idea of flashing or marching
borders.
-tgq
