POV-Ray : Newsgroups : povray.beta-test : povray --benchmark on linux from source Server Time
15 May 2026 19:56:33 EDT (-0400)
  povray --benchmark on linux from source (Message 1 to 8 of 8)
Subject: povray --benchmark on linux from source
Date: 6 Dec 2010 15:57:42
Message: <4cfd4e46$1@news.povray.org>
On ubuntu amd64, with "povray --benchmark"
Parse Warning: gamma_correction not specified or inferred so is turned
off for
  compatibility with this pre POV-Ray 3.7 scene. See the documentation
for more
  details.
May be the benchmark scene can be updated to avoid that warning ?
Trace time on amd3500+ (old!): 9 minutes 29 seconds (569.449 seconds)
with 4 threads. (548.117 CPU-seconds total)
Subject: Re: povray --benchmark on linux from source
Date: 6 Dec 2010 17:22:01
Message: <4cfd6209$1@news.povray.org>
> off for
> for more
>  details.
just so we don't end up stepping on each others toes ... i'll go ahead
and look into this one
Date: 6 Dec 2010 17:28:37
Message: <4cfd6395@news.povray.org>
It's worth keeping in mind that the benchmark code has a fair bit of stuff
disabled (back from the early days of the beta). It might be worthwhile
starting out with a fresh copy of the benchmark file from 3.6 and only
changing the minimum necessary to make it work well with 3.7.
-- Chris
Date: 8 Dec 2010 13:32:48
Message: <4cffcf50$1@news.povray.org>
> off for
> for more
>  details.
Done ... for those who have access I'd appreciate a sanity check ...
change #5249
Date: 8 Dec 2010 13:45:16
Message: <4cffd23c$1@news.povray.org>
>> off for
>> for more
>>  details.
> change #5249
btw:
Render Time:
  Photon Time:      0 hours  0 minutes  0 seconds (0.308 seconds)
              using 5 thread(s) with 0.367 CPU-seconds total
  Radiosity Time:   No radiosity
  Trace Time:       0 hours  2 minutes 58 seconds (178.175 seconds)
              using 2 thread(s) with 354.943 CPU-seconds total
opensuse11.2 amd athlon x2 250 4gb
Date: 8 Dec 2010 16:47:34
Message: <4cfffcf5@news.povray.org>
  Btw, when I try the benchmark like that (on OpenSuse 11.3), it fails to
render with the message:
File '/tmp/pov7021.pov' line 141: Possible Parse Error: Cannot find file
 'functions.inc', even after trying to append file type extension.
  If I #include "functions.inc" in a regular file and render it with
POV-Ray 3.7, it finds it ok, so it's not a problem in configuration.
Date: 8 Dec 2010 18:16:37
Message: <4d0011d5$1@news.povray.org>
hmmm ... i never saw that ... before OR after #5249
Date: 9 Dec 2010 10:07:04
Message: <4d00f098@news.povray.org>
  I have no idea. It has been a really long time since I last tried.
  Note that I didn't *install* povray. I just compiled it and moved the
executable to my home directory bin directory. It works ok like that
(when I configure ~.povray/3.7/povray.ini properly). I don't know if
that's the source of the problem. (The benchmark should definitely work
regardless.)
