![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On ubuntu amd64, with "povray --benchmark"
Parse Warning: gamma_correction not specified or inferred so is turned
off for
compatibility with this pre POV-Ray 3.7 scene. See the documentation
for more
details.
May be the benchmark scene can be updated to avoid that warning ?
Trace time on amd3500+ (old!): 9 minutes 29 seconds (569.449 seconds)
with 4 threads. (548.117 CPU-seconds total)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> off for
> for more
> details.
just so we don't end up stepping on each others toes ... i'll go ahead
and look into this one
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: povray --benchmark on linux from source
Date: 6 Dec 2010 17:28:37
Message: <4cfd6395@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's worth keeping in mind that the benchmark code has a fair bit of stuff
disabled (back from the early days of the beta). It might be worthwhile
starting out with a fresh copy of the benchmark file from 3.6 and only
changing the minimum necessary to make it work well with 3.7.
-- Chris
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> off for
> for more
> details.
Done ... for those who have access I'd appreciate a sanity check ...
change #5249
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> off for
>> for more
>> details.
> change #5249
btw:
Render Time:
Photon Time: 0 hours 0 minutes 0 seconds (0.308 seconds)
using 5 thread(s) with 0.367 CPU-seconds total
Radiosity Time: No radiosity
Trace Time: 0 hours 2 minutes 58 seconds (178.175 seconds)
using 2 thread(s) with 354.943 CPU-seconds total
opensuse11.2 amd athlon x2 250 4gb
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Btw, when I try the benchmark like that (on OpenSuse 11.3), it fails to
render with the message:
File '/tmp/pov7021.pov' line 141: Possible Parse Error: Cannot find file
'functions.inc', even after trying to append file type extension.
If I #include "functions.inc" in a regular file and render it with
POV-Ray 3.7, it finds it ok, so it's not a problem in configuration.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hmmm ... i never saw that ... before OR after #5249
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have no idea. It has been a really long time since I last tried.
Note that I didn't *install* povray. I just compiled it and moved the
executable to my home directory bin directory. It works ok like that
(when I configure ~.povray/3.7/povray.ini properly). I don't know if
that's the source of the problem. (The benchmark should definitely work
regardless.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
