POV-Ray : Newsgroups : povray.beta-test : e_and_SOR_–_Beta_38 Server Time
29 Mar 2026 02:01:08 EDT (-0400)
  e_and_SOR_–_Beta_38 (Message 1 to 7 of 7)
Subject: e_and_SOR_–_Beta_38
Date: 28 Aug 2010 14:17:17
Message: <4c7952ad@news.povray.org>
It is not a big scene but all of the elements are required for it to
fail. It also seems to be dependent on the camera angle.
Best Regards,
Subject: h_Lathe_and_SOR_–_Beta_38
Date: 28 Aug 2010 14:23:36
Message: <4c795428@news.povray.org>
It is in my sent box (47K)
Best Regards,
Date: 28 Aug 2010 14:27:47
Message: <4c795523@news.povray.org>
I'm beginning to hate Thunderbird.
Best Regards,
Date: 28 Aug 2010 15:05:51
Message: <4c795e0f@news.povray.org>
Am 28.08.2010 20:27, schrieb Stephen:
Looks fine here, with T'bird also. In this case it's apparently the web
interface that stumbles over a long (non-ASCII) dash you put in the subject.
Date: 28 Aug 2010 15:31:27
Message: <4c79640f@news.povray.org>
Am 28.08.2010 20:17, schrieb Stephen:
The root cause is a combination of
(1) a problem with either the sor or lathe object, returning "undefined"
as the surface normal at a certain point (which leads to "undefined"
values in subsequent computations of a refracted ray), and
(2) a lack of defensive programming in the image handling code (which
"converts" the undefined values into an access violation).
Date: 28 Aug 2010 17:04:00
Message: <4c7979c0$1@news.povray.org>
>> I can see it using the web view and it is called
> subject.
It wasn't me. A big boy did it and ran away ;-)
The big boy's name is M$ Word.
Best Regards,
Date: 28 Aug 2010 17:08:41
Message: <4c797ad9$1@news.povray.org>
If you remove either the SOR or the lath or the skysphere the scene
renders OK.
Actually looking at both the SOR and the lathe in OpenGL (Bishop3D)
shows an ugly turn at the base. I will remodel them even if it leaves
gaps between the glass and the liquid.
Thanks Christoph.
Best Regards,
