![](/i/fill.gif) |
> We are missing the OS & memory (size & type) if we want to compare.
Sorry, Windows 7 x64 with 6 GB, 3 x 2GB Mushkin DDR3 1333 Mhz,
although BIOS settings seem to indicate its running at 1066 Mhz.
I'm a bit hazy on modern technology details; the last system I
assembled myself was a P66 with 8MB back in 1994 ... I initially
considered ordering Corsair DDR3 1600 Mhz but the vendor told me
the 1600 Mhz wouldn't benefit my configuration unless I overclocked
(it's one of these sites where you configure your system online).
Also my initial enthusiasm was dampened by some blue screens and I
actually found some problem using memtest86, seems two of the three
DDR's had problems and it's running on 2GB for the time being but
seems to be stable now (I hope ...).
> And how you get that number (because all I got is time: render, photon,
> bounding & parser)
In the Windows version there is menu entry "Run benchmark" which
will render the benchmark scene and yield the pps value (and only the
pps value) in a message box. In fact many people testing CPU speeds
seem to use POV-Ray 3.7 just for its benchmark feature and list it
next to other benchmarks such as Cinebench, e.g.
http://www.tabsnet.com/index.php?option=com_benchmark&task=list&bid=5&sysid=0
I didn't try to render benchmark.pov manually because the
menu item takes care of using correct render options.
![](/i/fill.gif) |
![](/i/fill.gif) |
Le 28/08/2010 18:13, Le_Forgeron nous fit lire :
I might run it with various threads to
make a curve if I get some energy for it.
Enjoy (but do not rely on it)
For sack of documentation, until 7 WT, it's one real core per thread.
(and until 12 WT, there is at least one "pseudo core" idle)
(done on 980X / Asrock X58 Extreme3, Linux Ubuntu amd64, memory in
triple channel mode, PC3-10666 CL 9, might be running at a different
speed: memtest report a bandwidth of 16400 MB/s)
WT Trace time
1 251,26
2 123,438
3 82,225
4 61,38
5 49,314
6 41,176
7 39,025
8 37,058
9 35,574
10 33,814
11 32,145
12 31,204
13 31,086
14 30,963
15 30,93
16 30,965
17 31,063
18 30,782
19 31,148
20 31,021
21 31,003
22 31,179
23 31,064
24 31,162
25 31,312
26 31,123
27 31,348
28 31,295
29 31,24
30 31,741
31 31,396
32 31,615
33 31,585
34 31,627
35 31,262
36 31,122
![](/i/fill.gif) |
