POV-Ray : Newsgroups : povray.beta-test : Beta 38 - NOTE: "AMBIENT" NO LONGER WORKS IN RADIOSITY SCENES Server Time
25 Apr 2026 21:39:39 EDT (-0400)
  Beta 38 - NOTE: "AMBIENT" NO LONGER WORKS IN RADIOSITY SCENES (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Beta 38 - NOTE: "AMBIENT" NO LONGER WORKS IN RADIOSITY SCENES
Date: 2 Jul 2010 11:54:06
Message: <4c2e0b9e$1@news.povray.org>
On 7/2/2010 3:48 AM, clipka wrote:
> As of beta 38, the "ambient" keyword no longer works in radiosity scenes.
> *IT'S NOT A BUG, IT'S A FEATURE*.
> Honestly.
> For legacy scenes using a "#version 3.6" statement, nothing has changed;
> ambient should work just as it did before.
> Otherwise, radiosity scenes will now be rendered as if "ambient_light"
> had been set to 0, i.e. materials with an "ambient" parameter will /not/
> seem to emit light anymore.
> To model light-emitting surfaces, a new finish parameter "emission" has
> been added, which will do just the same as "ambient" previously did,
> except that it is unaffected by the global ambient_light setting.
> It is also recommended to use the "emission" keyword in non-radiosity
> scenes for anything you want to look like glowing, and use "ambient"
> only to model local ambient illumination, so that transition to using
> radiosity is straightforward.
Makes sense, I guess, since IRL a light bulb is not "extra ambient"
compared to something else.
http://isometricland.com
Date: 2 Jul 2010 16:35:00
Message: <web.4c2e4cfe70b8880befbe2db80@news.povray.org>
> > Honestly.
Great! would it be really pushing too much to ask such a feature request as to
make this mappable with bitmap files: emission_map, just like bump_map or
image_map?
Date: 2 Jul 2010 21:34:48
Message: <4c2e93b8@news.povray.org>
Am 02.07.2010 22:33, schrieb Mr:
> image_map?
Yes - at present, I guess it would ;-)
texture_map should get you there for now.
Date: 3 Jul 2010 00:44:58
Message: <4c2ec04a$1@news.povray.org>
request as to
 > image_map?
I think it would be more practical if 'finish' in general was mappable
with patterns, like pigments are. I mean, since we're dreaming. =)
  - Slime
Date: 3 Jul 2010 02:40:00
Message: <web.4c2eda8670b8880befbe2db80@news.povray.org>
> > image_map?
I won't ask it, then... Thanks for hearing it without me asking and still
sparing my life. :)
Date: 3 Jul 2010 12:10:41
Message: <4c2f6101$1@news.povray.org>
> image_map?
Do you mean like a glow map?
Date: 3 Jul 2010 17:30:01
Message: <web.4c2faabf70b8880b9b4d22840@news.povray.org>
> > image_map?
I meant to make like TV/ computer screens :)
Date: 4 Jul 2010 05:27:32
Message: <4c305404$1@news.povray.org>
Am 03.07.2010 23:25, schrieb Mr:
>>> image_map?
You might try modeling it via the LCD approach: An emission object as
backlight, and a filtering one right in front.
Date: 4 Jul 2010 14:13:27
Message: <4c30cf47$1@news.povray.org>
Le 02/07/2010 09:48, clipka nous fit lire :
> Honestly.
Please revisit the stacker*.pov files, as:
stackernight.pov is now rendered in full black,
other stacker* get a significant change in colours/lights.
Date: 4 Jul 2010 16:44:10
Message: <4c30f29a$1@news.povray.org>
>> Honestly.
stackernight uses only ambient lighting. You should replace ambient by
emission.
