POV-Ray : Newsgroups : povray.beta-test : Just some feed back on beta 37a Server Time
25 Apr 2026 20:03:37 EDT (-0400)
  Just some feed back on beta 37a (Message 1 to 3 of 3)
Subject: Just some feed back on beta 37a
Date: 1 Jun 2010 17:37:54
Message: <4c057db2@news.povray.org>
Works wonderfully and truly speeds up rendering using my 4 cores.
Suggestion: probably SSE2 is the most useful CPU instruction set for
POV-Ray hence the reason is used as a optimization, but would be useful
  IMO that you use all available instruction sets available for AMD and
Intel depending on which CPU is available. You probably know this I just
wanted to remind you of it.
Subject: Re: Just some feed back on beta 37a
Date: 1 Jun 2010 18:13:12
Message: <4c0585f8$1@news.povray.org>
Forgot to say(Copy+Paste):
Render Statistics
Image Resolution 1380 x 768
Pixels:          1127808   Samples:          735570   Smpls/Pxl: 0.65
Rays:            2382181   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Quadric                        8990228         4594141     51.10
Sphere                        47512027         9695940     20.41
Bounding Box                 131715272        65381264     49.64
Shadow Ray Tests:           2283661   Succeeded:                692493
Shadow Cache Hits:           170728
Transmitted Rays:            518803
Render Time:
   Photon Time:      No photons
   Radiosity Time:   No radiosity
   Trace Time:       0 hours  0 minutes  3 seconds (3.703 seconds)
               using 4 thread(s) with 14.373 CPU-seconds total
POV-Ray finished
CPU time used: kernel 0.25 seconds, user 14.66 seconds, total 14.91 seconds.
Elapsed time 4.06 seconds, CPU vs elapsed time ratio 3.67.
Render averaged 260915.81 PPS (71100.38 PPS CPU time) over 1059840 pixels.
Preset INI file is 'C:\Mis Documentos\POV-Ray\v3.7\ini\quickres.ini',
section is '[1024x768, AA 0.3]'.
Preset source file is 'C:\Mis
Documentos\POV-Ray\v3.6\scenes\advanced\ntreal\ntreal.pov'.
Rendering using command line '+w1380 +h768 +AM2 +R2'.
Rendering with 4 threads.
Parser Options
   Input file: C:\Mis
   Remove bounds........On
   Split unions.........Off
   Library paths:
     C:\Mis Documentos\POV-Ray\v3.7\include
     C:\WINDOWS\Fonts
Parse Warning: assumed_gamma is not supported in POV-Ray v3.7 and later
SDL. For compatibility purposes an assumed_gamma of 2.2 is taken to mean
gamma correction is off. Note that it is
possible to provide gamma settings in an INI file or on the command-line
if you really need to set them. See the documentation for more
information regarding this change.
Parser Statistics
Finite Objects:         1744
Infinite Objects:          3
Light Sources:             1
Total:                  1748
Parser Time
   Parse Time:       0 hours  0 minutes  0 seconds (0.032 seconds)
               using 1 thread(s) with 0.015 CPU-seconds total
   Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
               using 1 thread(s) with 0.000 CPU-seconds total
Warning: Scene contained deprecated 'assumed_gamma'. Output gamma has been
adjusted to match legacy 'assumed_gamma' due to language version being
set to
Date: 1 Jun 2010 18:17:44
Message: <4c058708@news.povray.org>
The previous reply was truncated, sorry, still a noob on POV-Ray, but
here it is the render log:
Parser Options
   Input file: C:\Mis
   Library paths:
     C:\WINDOWS\Fonts
Parser Statistics
Infinite Objects:          3
Light Sources:             1
Total:                  1748
Parser Time
set to
3.6x or lower. However, future versions of POV-Ray will not support backward
compatibility with 'assumed_gamma'. It is strongly recommended you
update your
scene file by removing 'assumed_gamma' and add suitable 'Display_Gamma' and
'File_Gamma' options to your INI file or command-line instead. See the
documentation for details.
Render Options
   Quality:  9
   Bounding boxes.......On   Bounding threshold: 3
   Antialiasing.........On  (Method 2, Threshold 0.300, Depth 2, Jitter
1.00)
Render Statistics
Quadric                        8990104         4594079     51.10
Sphere                        47514339         9696321     20.41
Bounding Box                 131717226        65383125     49.64
Shadow Ray Tests:           2283632   Succeeded:                692464
Shadow Cache Hits:           170761
Render Time:
   Trace Time:       0 hours  0 minutes  3 seconds (3.735 seconds)
               using 4 thread(s) with 14.405 CPU-seconds total
POV-Ray finished
CPU time used: kernel 0.11 seconds, user 14.81 seconds, total 14.92 seconds.
Elapsed time 4.08 seconds, CPU vs elapsed time ratio 3.66.
Render averaged 259892.10 PPS (71025.93 PPS CPU time) over 1059840 pixels.
