POV-Ray : Newsgroups : povray.beta-test : Default file type Server Time
16 May 2026 01:39:39 EDT (-0400)
  Default file type (Message 21 to 30 of 43)
Subject: Re: Default file type
Date: 26 Apr 2010 12:56:15
Message: <4bd5c5af$1@news.povray.org>
Am 26.04.2010 15:01, schrieb Warp:
> Slime<fak### [at] emailaddress>  wrote:
>> I don't think the default file type should be one that uses lossy
>> compression.
>    I didn't know that POV-Ray even supported lossy formats as output...
Contrary to rumors, POV-Ray can output JPEG.
Date: 26 Apr 2010 13:34:00
Message: <4bd5ce88@news.povray.org>
> >> compression.
  Is that new in POV-Ray 3.7? How do you fine-tune the compression options?
Date: 26 Apr 2010 13:38:02
Message: <4bd5cf7a$1@news.povray.org>
>>>> compression.
http://wiki.povray.org/content/Documentation:Reference_Section_1.1#Output_File_Type
Date: 26 Apr 2010 13:44:50
Message: <4bd5d112$1@news.povray.org>
>>>> compression.
It has been there in 3.6 as well, but was simply inaccessible from the
command line (but would have been accessible i.e. for special rendering of
insert menus from inside POV-Ray, though this was not done). In 3.7 general
access was added.
	Thorsten
Date: 26 Apr 2010 13:45:22
Message: <4bd5d132@news.povray.org>
On 26.04.10 00:16, clipka wrote:
> Am 25.04.2010 23:20, schrieb Alain:
>>> How about changing the default output file type for both Windows and
>>> Unix version to PNG?
>> Why not for all versions?
> With me having not much of an idea about Macs anyway, I pass that
> question on to any Mac experts listening right now...
PNG is the system's preferred file format in Mac OS X.
	Thorsten
Date: 26 Apr 2010 14:24:45
Message: <4bd5da6c@news.povray.org>
  Thanks.
Date: 26 Apr 2010 15:03:27
Message: <4bd5e37f@news.povray.org>
Another vote for PNG. That's the format I always go to for POV.
~Mike
Date: 26 Apr 2010 15:08:19
Message: <4bd5e4a3$1@news.povray.org>
Am 26.04.2010 19:34, schrieb Warp:
No, it has just been undocumented - for good reason: POV-Ray 3.6 was
able to generate JPEG output as well, but the quality was terrible and
couldn't be changed.
With 3.7, compression is set with the "Compression=N" INI-file option,
where N is an integer value from 2 ("horrible") to 100 ("top quality").
A value of either 0 or 1 will select the default (95; 3.6 apparently
used a value somewhere around 10).
There are still issues though: While IC displays the JPEG output images
as expected, Windows Explorer preview and Photoshop 6.0 get the RGB
values wrong way round (i.e. blue displays as red and vice versa). So
given that IC normally does a pretty good job at JPEGs, POV-Ray must be
doing something pretty unconventional there.
Date: 26 Apr 2010 15:26:06
Message: <4bd5e8ce$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4bd40f13$1@news.povray.org...
> How about changing the default output file type for both Windows and Unix
> version to PNG?
Yes please!
Date: 26 Apr 2010 16:35:00
Message: <web.4bd5f781412281fae92d9930@news.povray.org>
I always thought that .jpeg compression quality was set within a simpler
1-through-10 scale --just those and no in-between values. (That's how my old
version of Photoshop does it, anyway...which is about the extent of my
knowledge.)
How was 95 arrived at for the 3.7 default (vs. 100)? They're so close. More
importantly, can all image-viewing apps decode .jpegs created with such a
'fine-scale' 1-to-100 compression choice? I base this question on problems I've
encountered (in Photoshop again, v5.0): strangely, even within its own 1-to-10
scale, there are several values that produce an image which isn't viewable in
some other apps I have. Maybe that's strictly a problem with the older
Photoshop--but it makes me wonder about the 1-to-100 variation in 3.7. Could the
'wrong choice' of a particular interim value produce an image-decoding problem?
Ken
