POV-Ray : Newsgroups : povray.beta-test : Gamma in beta 35a Server Time
26 Oct 2025 18:10:35 EDT (-0400)
  Gamma in beta 35a (Message 1 to 5 of 5)
Subject: Gamma in beta 35a
Date: 18 Jan 2010 17:16:34
Message: <4b54ddc2$1@news.povray.org>
Hello,
After using 3.6 since release I have just started to play with POV-Ray
3.7 beta35a in Windows XP SP3. After testing and reading the release
notes I found some behavior that maybe I just do not understand.
Does the display_gamma setting modify the output image at all? The
rendered image in POV-Ray looks fine but if I view it in another
program, such as Gimp, IrfanView or Paint.net, its either too bright or
too dark. No matter what value I put for display_gamma the image is
always the same although it changes in the POV-Ray render window. I
tried all the export formats with the same results. I kept file_gamma as
1.0 and did not use assumed_gamma.
So with POV-Ray 3.7 do I have to gamma correct all the renders
separately in another program? I understand that baking the gamma into
the image may be bad in terms of portability but if the setting is not
read by some viewers it may be nice if it could optionally be baked in.
thanks,
FlyerX
Subject: Re: Gamma in beta 35a
Date: 18 Jan 2010 19:17:09
Message: <4b54fa04@news.povray.org>
  display_gamma affects the preview window. Its purpose is to be the
proper gamma for your system (that's usually 2.2).
> I kept file_gamma as 1.0 and did not use assumed_gamma.
  file_gamma should usually be the same as display_gamma, because that way
you are telling which display_gamma you were using when you made the image.
  (I have to admit that I don't remember now why display_gamma and file_gamma
are two separate values instead of being just one and the same.)
  No, you specify the proper file_gamma.
Date: 18 Jan 2010 20:01:28
Message: <4b550468$1@news.povray.org>
Making file_gamma the required value worked.
Thanks,
FlyerX
Date: 19 Jan 2010 04:30:01
Message: <web.4b557afaa81cec5865f302820@news.povray.org>
> proper gamma for your system (that's usually 2.2)...
.....(etc.)...
A very clear, simple and concise explanation. Thanks, Warp.  IMO, this should be
made part of the 'new' documentation, practically as-is.
Ken
Date: 19 Jan 2010 10:29:09
Message: <4b55cfc4@news.povray.org>
  There's already a thread about the subject.
