POV-Ray : Newsgroups : povray.beta-test : Gamma in POV-Ray 3.6 vs. 3.7 Server Time
29 Mar 2026 23:37:53 EDT (-0400)
  Gamma in POV-Ray 3.6 vs. 3.7 (Message 26 to 35 of 75)
Subject: Re: Gamma in POV-Ray 3.6 vs. 3.7
Date: 12 Sep 2009 10:46:24
Message: <4aabb440@news.povray.org>
> I had thought about a gamma of 2.2 (to closely match sRGB), or the
> File_Gammma INI setting (so that previously rendered images will be read
> in properly). But you're making a point there, too.
  It would also automatically fix the current problem with image maps
without the user having to specify anything in the scene file itself.
Date: 12 Sep 2009 10:59:42
Message: <4aabb75e$1@news.povray.org>
To make life easier that's the libpng call for getting the
sRGB chunk information. For the sole purpose of gamma correction you can
safely ignore the value that is returned as sRGB_intent.
int sRGB_intent;
if (png_get_sRGB(png_ptr, png_inf, &sRGB_intent) != 0)
	/* sRGB chunk is present, so we can ignore any gAMA chunk */
-Ive
Date: 12 Sep 2009 11:02:22
Message: <4aabb7fe$1@news.povray.org>
Ive schrieb:
> I really do not see why not simply respecting the W3C/PNG recommendation
> as every contemporary browser (meanwhile even including IE) and every
> not totally brain-dead image viewer does.
Um - misunderstanding here:
The default gamma for input files would be intended to kick in *only*
for files where no gamma information is to be had (or where
sophisticated gamma / color profile handling hasn't been implemented yet).
For PNG files, the gAMA chunk information would still take precedence.
(And as for sRGB chunks, if I'm asked the only legitimate reason to
continue ignoring them is lack of the manpower needed to implement the
proper handling; the same goes for full-fledged color profiles, by the way.)
To override the decoding gamma for files with explicit gamma information
or a fixed gamma, the user would have to explicitly specify a decoding
gamma on a per-file basis.
Date: 12 Sep 2009 11:03:53
Message: <4aabb859$1@news.povray.org>
What current problem?
Date: 12 Sep 2009 11:08:56
Message: <4aabb988$1@news.povray.org>
Ive schrieb:
>> This is actually a problem I see with most of POV-Ray's file input
>> code, as data is typically stored no wider than 8 bits per channel
>> unless the encoded data is wider already.
> I completely agree and actually for exactly this reason I did recommend
> the conversion from JPEG to 16-bps PNG files to overcome the current
> problems with image maps.
BTW, does the jpeglib provide a way to get the raw YCrCb data out of JPG
files and do all the color math on floats?
Date: 12 Sep 2009 11:45:52
Message: <4aabc230@news.povray.org>
  I can't believe you have already forgotten the superlong thread about
the subject. Are you honestly saying that you can't remember what the
problem with input images in POV-Ray 3.7 currently are? Really?
  Anyways, in short, if the input image has no gamma information, and the
user has not specified any assumed gamma for that particular input image,
then if POV-Ray used an assumed gamma equivalent to File_Gamma (or perhaps
Display_Gamma), there would be no need for this:
http://bugs.povray.org/task/10
Date: 12 Sep 2009 11:58:24
Message: <4aabc520$1@news.povray.org>
Code fragment:
FILE	*File;
struct	jpeg_decompress_struct cinfo;
jpeg_create_decompress(&cinfo);
jpeg_stdio_src(&cinfo, File);
if (jpeg_read_header(&cinfo, TRUE) == 1)
	thats it, this will force jpeglib to return
	unconverted YCbCr (or only Y for JCS_GRAYSCALE):
	cinfo.out_color_space = cinfo.jpeg_color_space;
	now the decompression stuff
But note, the jpeg_color_space is defined as
typedef enum {
	JCS_UNKNOWN,		/* error/unspecified */
	JCS_GRAYSCALE,		/* monochrome */
	JCS_RGB,		/* red/green/blue */
	JCS_YCbCr,		/* Y/Cb/Cr (also known as YUV) */
	JCS_CMYK,		/* C/M/Y/K */
	JCS_YCCK		/* Y/Cb/Cr/K */
} J_COLOR_SPACE;
where JCS_RGB, JCS_CMYK are only used for the transformation and will
*never* appear within cinfo.jpeg_color_space.
If cinfo.jpeg_color_space is JCS_UNKNOWN reject the file, could be anything.
If cinfo.jpeg_color_space is JCS_GRAYSCALE only one component (Y) is
used and stored, the most simple case.
The most common case is off course cinfo.jpeg_color_space is JCS_YCbCr.
And my recommendation would be to reject JCS_CMYK because without color
management and the usage of the ICC profile that usually accompanies
such a file there is NO transformation to rgb possible.
To see how the YCbCr -> RGB transformation is done within jpeglib have a
look at jdcolor.c"
-Ive
Date: 12 Sep 2009 12:01:19
Message: <4aabc5cf$1@news.povray.org>
Ive wrote:
> And my recommendation would be to reject JCS_CMYK because...
Err, this should be "...reject JCS_YCCK..."
-Ive
Date: 12 Sep 2009 12:13:15
Message: <4aabc89b@news.povray.org>
to cite myself:
"If no gAMA chunk and no sRGB chunk is present the PNG/W3C
recommendation says to handle the file in the same way is if a sRGB
chunk were present."
So for PNG the gamma is always defined!
Or did I miss something else in the discussion?
-Ive
Date: 12 Sep 2009 12:27:35
Message: <4aabcbf7@news.povray.org>
Ive wrote:
> did I forget something, GIF? not much to say there but usually gamma
> corrected in between 1.4 and 2.4 - its a matter of guessing again.
Oops. it seems I'm a bit biased against GIF so to be fair there is also
the usual W3C recommendation to assume GIF to be in sRGB but I have an
old GIF collection since good old Compuserve days that are obviously not.
-Ive
