POV-Ray : Newsgroups : povray.beta-test : inside() doesn't accept solid meshes Server Time
29 Sep 2024 01:25:50 EDT (-0400)
  inside() doesn't accept solid meshes (Message 1 to 5 of 5)
Subject: inside() doesn't accept solid meshes
Date: 28 Aug 2009 15:59:18
Message: <4a983716@news.povray.org>
It seems that inside() function doesn't accept a mesh as the object, even
if it has inside_vector defined. This is so in both povray 3.6 and 3.7. Is
there any reason for this? I think it would be useful if it was supported.
Subject: Re: inside() doesn't accept solid meshes
Date: 28 Aug 2009 16:04:07
Message: <4a983837$1@news.povray.org>
You probably already know this, and it might not even help you, but as a
workaround you can make the mesh into an object pattern and test it
using eval_pigment(). Or you can turn the object pattern into a function
and test it directly that way. It might even be faster than using
eval_pigment().
Sam
Date: 28 Aug 2009 16:10:58
Message: <4a9839d2$1@news.povray.org>
> eval_pigment().
... or (untested) wrap it in a union all by itself?
Date: 28 Aug 2009 16:25:57
Message: <4a983d55@news.povray.org>
> > eval_pigment().
  Putting it inside a union doesn't work, but the object pattern trick
works. Clearly there's no technical reason to forbid solid meshes as the
parameter for inside(), so it's probably just an oversight. Maybe this could
be fixed?
Date: 28 Aug 2009 23:08:42
Message: <4a989bba$1@news.povray.org>
> be fixed?
I bet so.
