POV-Ray : Newsgroups : povray.beta-test : CSG bounding box broken with arbitrary transform Server Time
16 Feb 2026 16:44:10 EST (-0500)
  CSG bounding box broken with arbitrary transform (Message 1 to 5 of 5)
Subject: CSG bounding box broken with arbitrary transform
Date: 20 Aug 2009 06:12:28
Message: <4a8d218c$1@news.povray.org>
Bounding box computation for CSG intersection appears to be broken when
one member is an arbitrarily transformed plane.
POV-Ray 3.6.2 has the same problem (can't test for 3.6.1).
// +W640 +H480 +MB1
#include "transforms.inc"
   location  <-0.2, 0.5, -4.0>
   direction 1.5*z
   look_at   <0.0, 0.0,  0.0>
sky_sphere {
     gradient y
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
light_source {
   <0, 0, 0>            // light's position (translated below)
   color rgb <1, 1, 1>  // light's color
   translate <-30, 30, -30>
plane {
   y, -1
   pigment { color rgb <0.7,0.5,0.3> }
intersection {
   sphere {
     0.0, 1 }
   plane { -x, 0 transform { Shear_Trans(x,y+x*0.3,z) } }
       radial
       frequency 8
       color_map {
         [0.00 color rgb <1.0,0.4,0.2> ]
         [0.33 color rgb <0.2,0.4,1.0> ]
         [0.66 color rgb <0.4,1.0,0.2> ]
         [1.00 color rgb <1.0,0.4,0.2> ]
     finish{
       specular 0.6
   rotate -y*5
Subject: Re: CSG bounding box broken with arbitrary transform
Date: 20 Aug 2009 07:16:02
Message: <4A8D3071.5060907@trf.de>
Without having tested the scene, could it be that the plane has simply been
flipped by the macro? Is there a minimal scene showing this problem?
	Thorsten
Date: 20 Aug 2009 08:13:32
Message: <4a8d3dec$1@news.povray.org>
> been flipped by the macro? Is there a minimal scene showing this problem?
That's the minimal scene already. Well, aside from texturing that is.
I already identified the root cause though: It turns out that when
POV-Ray checks for planes being perpendicular to an axis in order to
take them into account for intersection bounding boxes, it attempts to
test this by checking whether one of the transformed normal's components
is equal to +/-1, instead of testing the other components for 0. As the
vector isn't normalized after the transformation, this gives bad readings.
The effect kicks in whenever the transformation leaves any of the normal
vector components exactly (or sufficiently close to) +/-1; for instance,
the following will provoke the problem as well:
   plane { -x, 0 transform { scale 2 rotate z*30 } }
(Omitting the "transform" statement will solve the issue in this case,
probably because a different mechanism is then used to apply the scaling
and rotation.)
Date: 20 Aug 2009 09:55:42
Message: <4a8d55de$1@news.povray.org>
Scne with macro and include != minimal scene ;-)
> and rotation.)
Ok, yes, it should not be a problem to fix the bug my normalizing the plane
normal after all transforms then. This probably is a rather old bug...
	Thorsten
Date: 27 Aug 2009 00:36:56
Message: <4a960d68@news.povray.org>
> and rotation.)
If you use transform{}, a reverse transformation matrix is applied.
If you don't, scale and rotate will modify the vector and distance directly.
It's similar to how 'translate' in a sphere moves the sphere's center
instead of using a transformation matrix, for optimization.
