POV-Ray : Newsgroups : povray.beta-test : compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in this scope Server Time
26 Jul 2026 23:45:32 EDT (-0400)
  compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in this scope (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in thisscope
Date: 15 Jul 2009 13:45:01
Message: <web.4a5e149935d6a577a95afc190@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Now, CLOCK_PROCESS_CPUTIME_ID is posix, so should we just hate freebsd 7.2 and lower
for
> not having it ? (no assertion about 8.0)
Sounds like a reasonable option :P (SCNR)
I'd say it depends on how complicated it would be to fix. At any rate, it's
worth entering into the bugtracker as a compatibility issue. As you seem to be
into details to some degree, would you mind...? kthxbye ;)
Subject: Re: compile error: 'CLOCK_PROCESS_CPUTIME_ID' was not declared in this scop=
Date: 15 Jul 2009 18:33:26
Message: <4a5e5936@news.povray.org>
clipka wrote:
> From the details I gather that you are trying to compile on some Unix/Linux
> machine;
Did anyone else see Clippy floating in the air there while reading this?
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 16 Jul 2009 04:11:54
Message: <4a5ee0ca$1@news.povray.org>
Le 15/07/2009 19:40, clipka nous fit lire :
lower for
Entry add in bugtracker, as per request.
Date: 16 Jul 2009 14:23:19
Message: <4a5f7017$1@news.povray.org>
>>> 7.2 and lower for not having it ? (no assertion about 8.0)
>> it's worth entering into the bugtracker as a compatibility issue. As
>> you seem to be into details to some degree, would you mind...? kthxbye
I thank you for it ;)
Date: 16 Jul 2009 15:33:38
Message: <4a5f8092@news.povray.org>
Povray does compile now. The patch follows. But there is another problem
which is ugly:
Making all in libraries
Making all in source
Making all in backend
Making all in base
Making all in frontend
Making all in vfe
Making all in unix
./unix/povray +i./scenes/advanced/biscuit.pov -f +d +p +v +w320 +h240
+a0.3 +L./include
povray: this pre-release version of POV-Ray for Unix has expired
*** Error code 1
Stop in /usr/home/user/sources/povray-3.7.0.beta.32.
How can I circumvent it?
Another question:
If Povray executes, how can I check if my patch is successful? Would
Povray start? Would it crash? Which checks have to be done?
Thank you in advance.
Patch:
--- vfe/unix/platformbase.cpp.old	2009-07-16 21:24:30.000000000 +0200
+++ vfe/unix/platformbase.cpp	2009-07-16 21:18:36.000000000 +0200
@@ -191,7 +191,11 @@ namespace pov_base
 #ifdef HAVE_CLOCK_GETTIME
 		struct timespec ts;
+#if defined (__FreeBSD__)
+		if (clock_gettime(m_ThreadTimeOnly ? CLOCK_THREAD_CPUTIME_ID : CLOCK_REALTIME, &ts)
== 0)
+#else
CLOCK_PROCESS_CPUTIME_ID, &ts) == 0)
+#endif
 			return (unsigned POV_LONG) (1000)*ts.tv_sec + ts.tv_nsec/1000000;
 #endif
 #ifdef HAVE_GETRUSAGE
Date: 16 Jul 2009 16:10:01
Message: <web.4a5f884435d6a577579432980@news.povray.org>
Looks like Le_Forgeron not only entered the issue, but already did a thorough
analysis; I can only agree with all his conclusions: It should be a matter of
../configure identifying that CLOCK_PROCESS_CPUTIME_ID isn't available, and in
that case not setting HAVE_CLOCK_GETTIME, but HAVE_GETRUSAGE instead; as the
code seems to be well prepared for dealing with clock_gettime() being
unavailable, issues worse than possibly misleading statistics are not to be
expected.
So no need to loathe freebsd for this :)
Date: 16 Jul 2009 16:16:11
Message: <4a5f8a8b$1@news.povray.org>
On Thu, 16 Jul 2009 16:06:28 -0400 clipka wrote:
> 3.0.4506.2152; .NET CLR 3.5.30729)
> NNTP-Posting-Host: 203.29.75.35
> X-Trace: news.povray.org 1247775001 203.29.75.35 (16 Jul 2009 16:10:01
> -0400) Lines: 33
> X-No-Archive: Yes
> X-Copyright: This copyrighted article comes from a private news server
> and may NOT be distributed on USENET or other news servers.
> X-POV-Header: --- --- --- --- --- --- --- --- --- --- --- --- Path:
> news.povray.org!81.173.238.87
> Xref: news.povray.org povray.beta-test:10235
>> >>> freebsd 7.2 and lower for not having it ? (no assertion about 8.0)
>> >> rate, it's worth entering into the bugtracker as a compatibility
>> >> issue. As you seem to be into details to some degree, would you
>> >> mind...? kthxbye ;)
> thorough analysis; I can only agree with all his conclusions: It should
> be a matter of ../configure identifying that CLOCK_PROCESS_CPUTIME_ID
> isn't available, and in that case not setting HAVE_CLOCK_GETTIME, but
> HAVE_GETRUSAGE instead; as the code seems to be well prepared for
> dealing with clock_gettime() being unavailable, issues worse than
> possibly misleading statistics are not to be expected.
sorry, did you read all new posts in this thread?
Date: 16 Jul 2009 16:33:49
Message: <4a5f8ead@news.povray.org>
> which is ugly:
> Making all in base
> Making all in vfe
> Making all in unix
> +a0.3 +L./include
> povray: this pre-release version of POV-Ray for Unix has expired ***
> Error code 1
okay, fulfilled.
Sometimes Povray dumps core, sometimes it loops forever at this position:
Making all in base
Making all in vfe
Making all in unix
+a0.3 +L./include
povray: this pre-release version of POV-Ray for Unix expires in 3 day(s)
and 1 hour(s)
PATHS
  HOME        = /home/xxx
  SYSCONF     = /usr/local/etc/povray/3.7/povray.conf
  USERCONF    = /home/user/.povray/3.7/povray.conf
  SYSINI      = /usr/local/etc/povray/3.7/povray.ini
  SYSINI_OLD  = /usr/local/etc/povray.ini
  USERINI     = /home/xxx/.povray/3.7/povray.ini
  USERINI_OLD = /home/xxx/.povrayrc
PARSE CONF '/usr/local/etc/povray/3.7/povray.conf'
[still running@100% CPU time...]
There seems to be another problem.
GDB says:
#13 0x0yyyyyyy in SignalHandler () at unix/unixconsole.cpp:146
Previous frame identical to this frame (corrupt stack?)
(gdb) list 146
141		int      signum;
142
143		while(true)
144		{
145			sigfillset(&sigset);
146			sigwait(&sigset, &signum);  // wait till a signal
is caught
147			boost::mutex::scoped_lock lock(gSignalMutex);
148			gSignalNumber = signum;
149		}
150	}
(gdb)
Date: 16 Jul 2009 16:35:01
Message: <web.4a5f8ed435d6a577579432980@news.povray.org>
> *** Error code 1
From an older post:
1) run  ./povray --betacode  to obtain a time-limited code (integer value)
2) set the environment variable POVRAY_BETA with this code
3) repeat when the current code doesn't work anymore.
Unfortunately this information seems nowhere to be found on the official POV-Ray
beta test web pages.
> Another question:
Just check whether the timing statistics (render time and such) seem plausible;
that's all that should be affected.
Date: 16 Jul 2009 16:45:00
Message: <web.4a5f902135d6a577579432980@news.povray.org>
No, sorry - you were typing too fast ;) (I'm using the message digest on
http://news.povray.org, not a news reader, usually reading the posts on a FIFO
basis ;))
But at first glance it looks to me like we need to loathe freebsd for something
else, not the time statistics stuff.
